华三交换怎么配置单端口镜像,多端口镜像
2021-06-18提问
  • 1收藏,1765浏览
华三交换怎么配置单端口镜像,多端口镜像
华三交换怎么配置单端口镜像,多端口镜像
粉丝:124人 关注:6人
单个目的端口的可以使用本地端口镜像,以下是参考命令:
<H3C>sys
[H3C]sysname SW1
[SW1]mirroring-group 1 local   //创建本地镜像组、组号为1
[SW1]mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 both  //指定镜像口,监控进出流量
[SW1]mirroring-group 1 monitor-port GigabitEthernet 1/0/1  //指定监控口
[SW1]dis mirroring-group all   //查看镜像组信息
Mirroring group 1:
    Type: Local  //本地镜像
    Status: Active  //镜像状态为激活
    Mirroring port:
        GigabitEthernet1/0/2  Both
    Monitor port: GigabitEthernet1/0/1
如果是多个目的端口,可以使用远程端口镜像:
<SW1>system-view
[SW1]vlan 999   //创建VLAN999,将用于remote-vlan
[SW1-vlan999]quit
[SW1]mirroring-group 1 remote-source  //创建镜像组1,指定为远程源镜像组
[SW1]mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 both  //指定镜像口,镜像进出流量
[SW1]mirroring-group 1 remote-probe vlan 999  //指定remote-vlan
[SW1]mirroring-group 1 reflector-port GigabitEthernet 1/0/5  //指定反射口
This operation may delete all settings made on the interface. Continue? [Y/N]: y   //指定反射口时,会提示该端口的配置会全部被删除,是否要继续,选择Y
[SW1]int ran gi 1/0/1 gi 1/0/4  //将监控设备接入的端口都划分到remote-vlan中,相当于指定为监控口
[SW1-if-range]port link-type access
[SW1-if-range]port access vlan 999
[SW1-if-range]quit
[SW1]dis mirroring-group all  //查看镜像组状态
Mirroring group 1:
    Type: Remote source  //镜像组类型为远程源镜像组
    Status: Active  //镜像组状态为激活
    Mirroring port:
    Reflector port: GigabitEthernet1/0/5
    Remote probe VLAN: 999
粉丝:148人 关注:1人
参考这个链接
http://www.h3c.com/cn/d_201812/1141829_30005_0.htm
