ER3200G3 经常会断线不能访问外网,需要重新连接才能正常
2021-06-19提问
  • 1收藏,1797浏览
如题所述,用双wan口,其中WAN1是移动固定IP,WAN2教育网的固定IP,不能访问外网的时候也PING不同外网的网关,重新连接后正常
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
下面是部分日志:
  1. Sat Jun 19 18:31:26 2021 user.notice Network: WAN1 connected Sat Jun 19 18:31:24 2021 ***.*** Network: WAN1 set Up Sat Jun 19 18:31:23 2021 ***.*** Network: WAN1 set Down Sat Jun 19 18:31:23 2021 user.notice Network: WAN1 disconnected Fri Jun 18 21:45:05 2021 user.notice Network: WAN1 connected Fri Jun 18 21:45:02 2021 ***.*** Network: WAN1 set Up Fri Jun 18 21:45:02 2021 ***.*** Network: WAN1 set Down Fri Jun 18 21:45:02 2021 user.notice Network: WAN1 disconnected Fri Jun 18 08:14:53 2021 user.notice Network: WAN1 connected Fri Jun 18 08:14:51 2021 ***.*** Network: WAN1 set Up Fri Jun 18 08:14:50 2021 ***.*** Network: WAN1 set Down Fri Jun 18 08:14:50 2021 user.notice Network: WAN1 disconnected Fri Jun 18 08:14:36 2021 user.notice Network: WAN2 connected Fri Jun 18 08:14:32 2021 ***.*** Network: WAN2 set Up Fri Jun 18 08:14:32 2021 ***.*** Network: WAN2 set Down Fri Jun 18 08:14:32 2021 user.notice Network: WAN2 disconnected Wed Jun 16 08:17:34 2021 user.notice Network: WAN2 connected Wed Jun 16 08:17:32 2021 user.notice Network: WAN2 disconnected Wed Jun 16 08:17:30 2021 ***.*** Network: WAN2 set Up Wed Jun 16 08:17:30 2021 ***.*** Network: WAN2 set Down Wed Jun 16 08:17:27 2021 user.notice Network: WAN1 connected Wed Jun 16 08:17:25 2021 ***.*** Network: WAN1 set Up Wed Jun 16 08:17:24 2021 ***.*** Network: WAN1 set Down Wed Jun 16 08:17:24 2021 user.notice Network: WAN1 disconnected Sun Jun 13 09:54:13 2021 user.notice Network: WAN2 connected Sun Jun 13 09:54:10 2021 ***.*** Network: WAN2 modify succeed! Sun Jun 13 09:54:10 2021 ***.*** Network: WAN2 set static mode ip:10.54.1.113 netmask:255.255.255.240 Sun Jun 13 08:40:01 2021 ***.*** Network: VLAN1 modify succeed! Sun Jun 13 08:40:01 2021 ***.*** Network: DHCPSERVER on VLAN1 delete succeed! Sun Jun 13 08:40:01 2021 ***.*** Network: VLAN1 set static mode ip:10.50.13.200 netmask:255.255.255.0 Fri Jan 1 00:24:16 2010 user.notice Network: WAN1 connected Fri Jan 1 00:24:14 2010 ***.*** Network: WAN1 modify succeed! Fri Jan 1 00:24:14 2010 ***.*** Network: WAN1 set static mode ip:223.78.104.28 netmask:255.255.255.0
粉丝:124人 关注:6人
经常掉线,以下是排查要点,请参考:
1、检查物理链路是否有问题。
2、检查设备的CPU、内存、端口利用率是否高。
3、检查下行网络中是否有可能存在环路或ARP攻击。
4、检查路由器内是否有相应的日志反馈。
5、看下路由器的软件版本是否最新,可考虑升级到最新。
6、如果是双链路的接入,检查路由来回路径是否一致。其次检查下多WAN工作模式的配置。
粉丝:19人 关注:3人
ping不通外网关看下ARP还有没有,有可能ARP没有了,重启设备up/down了一下端口重新学习了arp
