H3C SecPath F1000-S server2019网络异常
2021-06-20提问
  • 1收藏,946浏览
防火墙分配地址的网段(10.18.126.0),操作系统是server 2012以上版本的,360测速异常;server2008以下版本的操作系统,正常。server2012以上版本的,在S7510E分配地址的网段(10.18.0.0),测试正常。想知道到底是防火墙配置问题,还是操作系统需要设置什么?
[GS_F1000_1]dis cur
 sysname GS_F1000_1
 firewall packet-filter enable
 firewall packet-filter default permit
 firewall statistic system enable
radius scheme system
 server-type extended
domain system
local-user GS
 password simple GS
 service-type telnet
 level 3
aspf-policy 1
 detect tcp
 detect udp
dhcp server ip-pool 20
 network 10.18.34.0 mask 255.255.254.0
 gateway-list 10.18.34.1
 dns-list 202.99.192.68 202.99.192.66
dhcp server ip-pool 21
 network 10.18.40.0 mask 255.255.255.0
 gateway-list 10.18.40.1
 dns-list 202.99.192.66
acl number 2001
 rule 0 permit
acl number 3001
 rule 0 permit ospf
 rule 1 permit icmp
 rule 2 permit tcp destination-port eq telnet
 rule 10 deny ip
acl number 3010
 rule 0 permit ip source 10.18.35.0 0.0.0.255 destination 10.18.34.0 0.0.0.255
 rule 1 deny ip source 10.18.0.0 0.0.255.255 destination 10.18.34.0 0.0.0.255
 rule 2 deny ip source 10.18.0.0 0.0.255.255 destination 10.18.36.0 0.0.0.255
 rule 3 permit ip source 10.18.36.0 0.0.0.255 destination 10.18.36.0 0.0.0.255
 rule 10 permit ip
interface Aux0
 async mode flow
interface GigabitEthernet0/0
 ip address 10.18.253.2 255.255.255.252
 firewall packet-filter 3010 inbound
interface GigabitEthernet0/1
 firewall aspf 1 inbound
interface GigabitEthernet0/1.20
 ip address 10.18.34.1 255.255.254.0
 vlan-type dot1q vid 20
interface GigabitEthernet0/1.21
 description ceshi
 ip address 10.18.40.1 255.255.255.0
 vlan-type dot1q vid 21
interface GigabitEthernet0/1.22
 ip address 10.18.36.1 255.255.255.0
 vlan-type dot1q vid 22
interface GigabitEthernet0/1.100
 description server
 ip address 10.18.126.1 255.255.255.224
 vlan-type dot1q vid 100
interface GigabitEthernet1/0
interface GigabitEthernet1/0.100
interface GigabitEthernet1/1
interface Encrypt2/0
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 add interface GigabitEthernet0/1
 add interface GigabitEthernet0/1.20
 add interface GigabitEthernet0/1.21
 add interface GigabitEthernet0/1.22
 add interface GigabitEthernet0/1.100
 set priority 85
firewall zone untrust
 add interface GigabitEthernet0/0
 set priority 5
firewall zone DMZ
 set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
ospf 10
 area 0.0.0.0
  network 10.18.34.0 0.0.1.255
  network 10.18.36.0 0.0.0.255
  network 10.18.40.0 0.0.0.255
  network 10.18.126.0 0.0.0.255
  network 10.18.253.0 0.0.0.3
 info-center loghost 10.18.126.2
 dhcp server forbidden-ip 10.18.34.1
 dhcp server forbidden-ip 10.18.34.7
 dhcp server forbidden-ip 10.18.40.1
 snmp-agent
 snmp-agent local-engineid 800063A203000FE290048E
 snmp-agent community write GS
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 10.18.126.2 params securityname GS
 ntp-service unicast-server 10.18.253.1
user-interface con 0
user-interface aux 0
user-interface vty 0 4
 user privilege level 3
 set authentication password simple GS
return
[GS_F1000_1]
粉丝:10人 关注:0人
将防火墙内外网口的tcp mss值改小测试一下1024
麻烦说具体点,不会改。
rocdell 发表时间:2021-06-20
问题描述的不太清楚,再说一下。测速异常的时间,可以ping通,网页也可以打开,但比较慢。还有,有用友的服务器,每次都能ping通,大多数时候能打开,但它的测试工具,测试失败,连不上服务器。
粉丝:124人 关注:6人
调整下防火墙端口的TCP MSS看下,以下是参考命令:
int gi 1/0/1
tcp mss 1200
另外可以配置QOS对流量打标记,让优先级高的流量优先转发。
检查防火墙的CPU、内存、端口利用率是否高。
改了tcp mss,还是不行。检查了防火墙CPU、内存、端口利用率不高。现在的网络下,server 2008的服务器网络正常,server 2012以上版本的不正常。同样的线路,也是这样。操作系统上有什么设置吗?
