V5版本,胖AP做了两个SSID,STA之间不互通
2018-06-11提问
  • 1收藏,1788浏览
下面为AP所有配置,上层设备未作隔离,仅同AP客户端不能胡同,求解答
[AP01]dis cu
 version 5.20, Release 1508P11
 sysname AP01
 domain default enable system
 telnet server enable
 port-security enable
 password-recovery enable
 undo attack-defense tcp fragment enable
 vlan 1
vlan 31
domain system access-limit disable state active idle-cut disable self-service-url disable
user-group system group-attribute allow-guest
 local-user admin
 password cipher $c$3$ALdCBGDUE/n7zw05K3RHQyWb0Ofub0GGW8ZOuQ==
 authorization-attribute level 3
 service-type telnet service-type web
 wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
 wlan service-template 1 crypto
 ssid HandSome_5G
 cipher-suite tkip
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
 key-derivation sha1-and-sha256
 service-template enable
wlan service-template 2 crypto
 ssid printer
 beacon ssid-hide
 cipher-suite tkip
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
cwmp undo cwmp enable
 interface NULL0
interface Vlan-interface31
 ip address 192.168.31.11 255.255.255.0
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 port trunk pvid vlan 31
interface WLAN-BSS32
 port link-type hybrid
 undo port hybrid vlan 1
 port hybrid vlan 31 untagged
 port hybrid pvid vlan 31
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$uoBoL3m13P+uQU3xEqJ0E1k5/Oebw9vHTUvfhw==
interface WLAN-BSS35
 port-security preshared-key pass-phrase cipher $c$3$uGEYTUj5Uz4Hqug5Jleq3oiDhsGVkq1rPC2eiA==
interface WLAN-Radio1/0/1
 service-template 1 interface wlan-bss 32
 interface WLAN-Radio1/0/2
 service-template 2 interface wlan-bss 35
 arp-snooping enable
 load xml-configuration
 load tr069-configuration
user-interface con 0 user-interface vty 0 4 authentication-mode scheme
 return [AP01]
skylar 九段
粉丝:42人 关注:0人
胖ap默认开启了二层隔离的。可以配置此命令关闭二层隔离[WA2620X]undo wlan-client-isolation enable
已经解决,谢谢
zhiliao_EO8aN 发表时间:2018-06-11
粉丝:148人 关注:3人
客户端开防火墙了吗
