H3C S5560-30C-EI ip verify source后所有电脑都上不了网
2021-06-25提问
  • 1收藏,1129浏览
已经把所有电脑 ip source binding 绑定了,但是开启后上不了网
粉丝:38人 关注:3人
配置发出来看看
display ip source binding static
看下绑定信息对应关系
[GZ-CO-S5560-02-Vlan-interface20]display ip source binding Total entries found: 14 IP Address MAC Address Interface VLAN Type 11.24.40.130 7427-eaaa-cfad Vlan20 N/A Static 11.24.40.131 7427-eaaa-d2af Vlan20 N/A Static 11.24.40.132 6c4b-9099-f6bf Vlan20 N/A Static 11.24.40.133 7427-eaee-d2c9 Vlan20 N/A Static 11.24.40.136 7427-eaee-6b03 Vlan20 N/A Static 11.24.40.139 f493-9ff1-b09a Vlan20 N/A Static 11.24.40.140 7427-eaef-d014 Vlan20 N/A Static 11.24.40.141 6c4b-90bf-e5e9 Vlan20 N/A Static 11.24.40.143 7427-eaed-fc9a Vlan20 N/A Static 11.24.40.155 7427-eaef-cfd2 Vlan20 N/A Static 11.24.40.158 6c4b-9099-0d4e Vlan20 N/A Static 11.24.40.159 f832-e4cd-33ca Vlan20 N/A Static 11.24.40.195 a4ae-1113-5194 Vlan20 N/A Static 11.24.40.200 6c4b-90f5-8c67 Vlan20 N/A Static
zhiliao_0bXXDy 发表时间:2021-06-25
interface Vlan-interface20 ip address 11.24.40.253 255.255.255.128 ospf cost 30 vrrp vrid 20 virtual-ip 11.24.40.254 packet-filter name ACL-OA inbound ip source binding ip-address 11.24.40.130 mac-address 7427-eaaa-cfad ip source binding ip-address 11.24.40.131 mac-address 7427-eaaa-d2af ip source binding ip-address 11.24.40.132 mac-address 6c4b-9099-f6bf ip source binding ip-address 11.24.40.133 mac-address 7427-eaee-d2c9 ip source binding ip-address 11.24.40.136 mac-address 7427-eaee-6b03 ip source binding ip-address 11.24.40.139 mac-address f493-9ff1-b09a ip source binding ip-address 11.24.40.140 mac-address 7427-eaef-d014 ip source binding ip-address 11.24.40.141 mac-address 6c4b-90bf-e5e9 ip source binding ip-address 11.24.40.143 mac-address 7427-eaed-fc9a ip source binding ip-address 11.24.40.155 mac-address 7427-eaef-cfd2 ip source binding ip-address 11.24.40.158 mac-address 6c4b-9099-0d4e ip source binding ip-address 11.24.40.159 mac-address f832-e4cd-33ca ip source binding ip-address 11.24.40.195 mac-address a4ae-1113-5194 ip source binding ip-address 11.24.40.200 mac-address 6c4b-90f5-8c67
不好意思,内网没法发图片出来,只能发文字
arp mac对应关系对吗
zhiiiiao_N7L84 发表时间:2021-06-25
不是只要绑定ip和mac吗?
粉丝:0人 关注:2人
IPv4静态绑定表项配置举例
图1-2所示,Host A、Host B分别与Device A的接口GigabitEthernet1/0/2、GigabitEthernet1/0/1相连。各主机均使用静态配置的IP地址。
要求通过在Device A上配置IPv4静态绑定表项,满足以下各项应用需求:
·     Device A上的所有接口都允许Host A发送的IP报文通过。
·     Device A的接口GigabitEthernet1/0/1上允许Host B发送的IP报文通过。
图1-2 配置静态表项组网图
# 配置Device A各接口的IP地址(略)。
# 在接口GigabitEthernet1/0/2上开启IPv4接口绑定功能,绑定源IP地址和MAC地址。
[DeviceA] interface gigabitethernet 1/0/2
[DeviceA-GigabitEthernet1/0/2] ip verify source ip-address mac-address
[DeviceA-GigabitEthernet1/0/2] quit
# 配置IPv4静态绑定表项,在Device A上的所有接口都允许MAC地址为0001-0203-0406、IP地址为192.168.0.1的数据终端Host A发送的IP报文通过。
[DeviceA] ip source binding ip-address 192.168.0.1 mac-address 0001-0203-0406
# 在接口GigabitEthernet1/0/1上开启IPv4接口绑定功能,绑定源IP地址和MAC地址。
[DeviceA] interface gigabitethernet 1/0/1
[DeviceA-GigabitEthernet1/0/1] ip verify source ip-address mac-address
# 配置IPv4静态绑定表项,在Device A的GigabitEthernet1/0/1上允许MAC地址为0001-0203-0407的数据终端Host B发送的IP报文通过。
[DeviceA-GigabitEthernet1/0/1] ip source binding mac-address 0001-0203-0407
[DeviceA-GigabitEthernet1/0/1] quit
# 在Device A上显示IPv4静态绑定表项,可以看出以上配置成功。
<DeviceA> display ip source binding static
Total entries found: 2
192.168.0.1     0001-0203-0406 N/A                      N/A  Static
N/A             0001-0203-0407 GE1/0/1                  N/A  Static
粉丝:124人 关注:6人
ip verify source后所有电脑都上不了网,以下是排查要点,请参考:
1、确认绑定的IP和MAC的信息是否正确。
2、确认终端是否是从这台交换机或这台交换机的端口上来的。
3、以下是配置举例,请参考:
IPv4静态绑定表项配置举例
图1-2 配置静态表项组网图
你好,ip和mac都是对的;通过dis arp可以看到那些ip和mac;我在其他交换机有试过,是正常的
