现有一台S7003E三层交换机 接口下直连59台MS4024P MS4024P直连多个网段设备
网段1:192.168.1.0 24
网段2:192.168.2.0 24
网段3:192.168.3.0 24
网段4:192.168.4.0 24
网段5:192.168.5.0 24
需求:采用基于子网的方式 实现各网段互通 交换机上的接口即插即用 可自动获取对应网段地址
(0)
1、组网如下:
2、S7003E 的配置 ( 以 192.168.1.0/24 为例 )
sys |
port g1/0/1 |
port link-type trunk |
port trunk permit vlan all |
vlan 10 |
int vlan 10 |
ip add 192.168.1.1 24 |
dhcp enable |
dhcp server ip-pool 10 |
network 192.168.1.0 mask 255.255.255.0 |
gateway-list 192.168.1.1 |
dns-list 114.114.114.114 |
sa f |
3、MS4024P 的配置 ( 以 192.168.1.0/24 为例 )
sys |
vlan 10 |
port g1/0/2 to g1/0/24 |
int g1/0/1 |
sa f |
4、电脑到 MS4024P 的 2-24口,即可自动获取1段的ip
(0)
可以参考如下命令将VLAN划分到端口,并配置VLAN IP和DHCP。
将交换机的名字修改为SW1:
[H3C]sysname SW1
在交换机分别创建VLAN 10、VLAN 20:
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
VLAN 10的IP设置为:192.168.10.1 255.255.255.0:
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
VLAN 20的IP设置为:192.168.20.1 255.255.255.0:
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 192.168.20.1 24
[SW1-Vlan-interface20]quit
将GI1/0/1端口划分到VLAN 10:
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 10
[SW1-GigabitEthernet1/0/1]quit
将GI1/0/2端口划分到VLAN 20:
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 20
[SW1-GigabitEthernet1/0/2]quit
开启DHCP功能:
[SW1]dhcp enable
创建DHCP地址池,命名为VLAN10,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan10]quit
[SW1]
创建DHCP地址池,命名为VLAN20,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan20
[SW1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[SW1-dhcp-pool-vlan20]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan20]quit
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
具体如何配置呀
