交换机
2021-07-05提问
  • 1收藏,1608浏览
交换机开启链路聚合的命令
粉丝:124人 关注:6人
直接配置端口聚合即可,以下是配置参考案例:
网络拓扑图说明:SW1为接入交换机,MSW为汇聚交换机。SW1交换机与MSW交换机采用二层链路聚合互联实现增加带宽、链路冗余的作用。PC接入SW1,属于VLAN 10
配置步骤
1、SW1交换机创建VLAN 10,G1/0/3端口为PC的接入。GI1/0/1和GI1/0/2端口与MSW交换机互联,同时使用二层链路聚合的技术实现捆绑,采用trunk进行数据的传输。
2、MSW交换机创建VLAN 10,并设置VLAN 10的IP和子网掩码,提供终端网关的接入,GI1/0/1和GI1/0/2端口与SW1交换机互联,同时使用二层链路聚合技术实现捆绑,采用trunk进行数据传输。
配置关键点
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]int gi 1/0/3
[SW1-GigabitEthernet1/0/3]port link-type access
[SW1-GigabitEthernet1/0/3]port access vlan 10
[SW1-GigabitEthernet1/0/3]description <connect to PC>
[SW1-GigabitEthernet1/0/3]quit
[SW1]int Bridge-Aggregation 1   //创建链路聚合组1
[SW1-Bridge-Aggregation1]quit
[SW1]int range gi 1/0/1 to gi 1/0/2
[SW1-if-range]port link-aggregation group 1  //将链路聚合组应用到接口
[SW1-if-range]quit
[SW1]int Bridge-Aggregation 1  //继续配置链路聚合组1
[SW1-Bridge-Aggregation1]port link-type trunk
Configuring GigabitEthernet1/0/1 done.
Configuring GigabitEthernet1/0/2 done.
[SW1-Bridge-Aggregation1]undo port trunk permit vlan 1
[SW1-Bridge-Aggregation1]port trunk permit vlan 10
MSW:
<H3C>sys
[H3C]sysname MSW
[MSW]vlan 10
[MSW-vlan10]quit
[MSW]int vlan 10
[MSW-Vlan-interface10]ip address 192.168.10.1 24
[MSW-Vlan-interface10]quit
[MSW]int Bridge-Aggregation 1
[MSW-Bridge-Aggregation1]quit
[MSW]int range gi 1/0/1 to gi 1/0/2
[MSW-if-range]port link-aggregation group 1
[MSW-if-range]quit
[MSW-Bridge-Aggregation1]port link-type trunk
[MSW-Bridge-Aggregation1]undo port trunk permit vlan 1
[MSW-Bridge-Aggregation1]port trunk permit vlan 10
查看链路聚合的状态均为选中状态(S):
[SW1]dis link-aggregation verbose
Port: A -- Auto
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
  Port             Status  Priority Oper-Key
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
[SW1]
[MSW]dis link-aggregation verbose
Port: A -- Auto
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
[MSW]
查看链路聚合后的速率为2G:
[MSW]dis int brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
InLoop0              UP   UP(s)    --
MGE0/0/0             DOWN DOWN     --
NULL0                UP   UP(s)    --
REG0                 UP   --       --
Vlan10               UP   UP       192.168.10.1
Speed: (a) - auto
Interface            Link Speed   Duplex Type PVID Description
BAGG1                UP   2G(a)   F(a)   T    1
FGE1/0/53            DOWN 40G     A      A    1
FGE1/0/54            DOWN 40G     A      A    1
GE1/0/1              UP   1G(a)   F(a)   T    1
GE1/0/2              UP   1G(a)   F(a)   T    1
GE1/0/3              DOWN auto    A      A    1
GE1/0/4              DOWN auto    A      A    1
[MSW]
[SW1]dis int brief
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
REG0                 UP   --       --
Speed: (a) - auto
GE1/0/3              DOWN auto    A      A    10   <connect to PC>
GE1/0/5              DOWN auto    A      A    1
PC设置IP,能PING通网关即可:
4 个回答
粉丝:119人 关注:1人
没有单独开启的命令,都是基于接口直接配置就行了
参考文档:
http://www.h3c.com/cn/d_201905/1184396_30005_0.htm
zhiliao_dYfMvl 知了小白
有没有配置命令,可以参考一下
没有单独命令 加入到聚合组就是配置了
zhiiiiao_N7L84 发表时间:2021-07-05
粉丝:11人 关注:0人
二层链路捆绑
int Bridge-Aggregation1
int g0/0/0
int g0/0/1
port trunk permit vlan all
三层链路捆绑
int route-aggregation 1
int g1/0/1
port link-mode route
int g2/0/1
ip add xxxx
dis link-aggregation summary ---查看链路聚合的概要信息
dis int Bridge-Aggregation brief --查看聚合后的链路
dis link-aggregation verbose --聚合后各端口的状态
