S5560-28P-SI
2021-07-05提问
  • 1收藏,843浏览
与华为对接
XF 知了小白
两边都创建二层聚合口模式改成LACP动态就行了
粉丝:5人 关注:1人
对接做什么?
打trunk吗?
接口下:
port link-t tr
port tr permit vlan all
粉丝:226人 关注:0人
您好,对接聚合吗?两边都配置动态聚合
粉丝:124人 关注:6人
以下是与华为交换机对接链路聚合的配置案例,请参考:
组网说明:
本案例采用H3C S5500与华为S5720对接二层链路聚合的典型组网。
H3C S5500的版本信息如下:
<H3C>dis version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 5206
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-58C-HI uptime is 0 week, 0 day, 0 hour, 5 minutes
H3C S5500-58C-HI with 2 Processors
1024M   bytes SDRAM
4096K   bytes Nor Flash Memory
512M    bytes Nand Flash Memory
Hardware Version is REV.C
CPLD Version is 003
Bootrom Version is 211
[SubSlot 0] 48GE+4SFP+2SFP PLUS Hardware Version is REV.C
<H3C>
华为5720的版本信息如下:
<HUAWEI>dis version
Huawei Versatile Routing Platform Software
VRP (R) software, Version 5.160 (S5720 V200R007C00SPC500)
Copyright (C) 2000-2014 HUAWEI TECH CO., LTD
HUAWEI S5720-56C-EI-AC Routing Switch uptime is 0 week, 0 day, 0 hour, 5 minutes
ES5D2T52C002 0(Master) : uptime is 0 week, 0 day, 0 hour, 5 minutes
2048M bytes DDR Memory
344M bytes FLASH
Pcb      Version :  VER.C
Basic  BootROM  Version : 0207.0001 Compiled at Oct 20 2014, 19:19:38
BootLoad  Version : 0207.0001 Compiled at Feb 27 2015, 15:34:21
CPLD   Version : 268
Software Version : VRP (R) Software, Version 5.160 (V200R007C00SPC500)
PWR1 information
Pcb      Version : PWR VER.B
FAN1 information
Pcb      Version : NA
<HUAWEI>
配置步骤
H3C S5500与华为S5720分别使用交换机的1口和2口进行互联。
配置关键点
H3C S5500链路聚合配置如下:
<H3C>sys
[H3C]int Bridge-Aggregation 1
[H3C-Bridge-Aggregation1]port link-type trunk
[H3C-Bridge-Aggregation1]port trunk permit vlan all
[H3C-Bridge-Aggregation1]quit
[H3C]int range GigabitEthernet 1/0/1 to GigabitEthernet 1/0/2
[H3C-if-range]port link-type trunk
[H3C-if-range]port trunk permit vlan all
[H3C-if-range]port link-aggregation group 1
[H3C-if-range]quit
华为S5720链路聚合配置如下:
<HUAWEI>sys
Enter system view, return user view with Ctrl+Z.
[HUAWEI]int Eth-Trunk 1
[HUAWEI-Eth-Trunk1]port link-type trunk
[HUAWEI-Eth-Trunk1]port trunk allow-pass vlan all
[HUAWEI-Eth-Trunk1]quit
[HUAWEI]int gi 0/0/1
[HUAWEI-GigabitEthernet0/0/1]eth-trunk 1
[HUAWEI-GigabitEthernet0/0/1]quit
[HUAWEI]int GigabitEthernet 0/0/2
[HUAWEI-GigabitEthernet0/0/2]eth-trunk 1
[HUAWEI-GigabitEthernet0/0/2]quit
查看S5500的链路聚合状态均为S
[H3C]dis link-aggregation verbose
Port Status: S -- Selected, U -- Unselected
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
  Port             Status  Priority  Oper-Key
  GE1/0/1          S       32768     1
  GE1/0/2          S       32768     1
查看华为S5720链路聚合的状态:
[HUAWEI]dis eth-trunk
Eth-Trunk1"s state information is:
WorkingMode: NORMAL         Hash arithmetic: According to SIP-XOR-DIP
Least Active-linknumber: 1  Max Bandwidth-affected-linknumber: 8
Operate status: up          Number Of Up Port In Trunk: 2
PortName                      Status      Weight
GigabitEthernet0/0/1          Up          1
GigabitEthernet0/0/2          Up          1
[HUAWEI]
至此,H3C S5500与华为S5720对接二层链路聚合典型组网配置案例已完成!
