s512028p stp报错
2021-07-08提问
  • 1收藏,1292浏览
longbd 二段
交接机不断提示如下:
#Jul 25 17:22:00:716 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437187 has been set to forwarding state!
#Jul 25 17:22:00:718 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437188 has been set to forwarding state!
#Jul 25 17:22:00:719 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437189 has been set to forwarding state!
#Jul 25 17:22:00:720 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437190 has been set to forwarding state!
#Jul 25 17:22:00:721 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437191 has been set to forwarding state!
#Jul 25 17:22:00:723 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437192 has been set to forwarding state!
#Jul 25 17:22:00:724 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437193 has been set to forwarding state!
 #Jul 25 17:22:00:725 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437194 has been set to forwarding state!
#Jul 25 17:22:00:726 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437195 has been set to forwarding state!
#Jul 25 17:22:00:727 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437196 has been set to forwarding state!
Jul 25 17:22:00:728 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437197 has been set to forwarding state!
#Jul 25 17:22:00:729 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437198 has been set to forwarding state!
#Jul 25 17:22:00:730 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437201 has been set to forwarding state!
#Jul 25 17:22:00:731 2006 SWMGT01 MSTP/1/PFWD:hwPortMstiStateForwarding: Instance 0's Port 0.9437206 has been set to forwarding state!
Jul 25 17:22:00:731 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/1 has been set to forwarding state!
%Jul 25 17:22:00:732 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/4 has been set to forwarding state!
Jul 25 17:22:00:733 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/5 has been set to forwarding state!
 %Jul 25 17:22:00:733 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/6 has been set to forwarding state!
%Jul 25 17:22:00:734 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/7 has been set to forwarding state!
 %Jul 25 17:22:00:735 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/8 has been set to forwarding state!
%Jul 25 17:22:00:735 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/9 has been set to forwarding state!
%Jul 25 17:22:00:736 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/10 has been set to forwarding state!
 %Jul 25 17:22:00:736 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/11 has been set to forwarding state!
%Jul 25 17:22:00:737 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/12 has been set to forwarding state!
%Jul 25 17:22:00:738 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/13 has been set to forwarding state!
%Jul 25 17:22:00:738 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/14 has been set to forwarding state!
%Jul 25 17:22:00:739 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/15 has been set to forwarding state!
%Jul 25 17:22:00:740 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/18 has been set to forwarding state!
%Jul 25 17:22:00:740 2006 SWMGT01 MSTP/2/PFWD:Instance 0's GigabitEthernet1/0/23 has been set to forwarding state!
核心交换机-------- 5120
   I
   I
S5120
核心交换机上接有两台5120.两台交换机同样报stp的信息,麻烦各位高手帮忙分析下,感谢!
粉丝:124人 关注:6人
看到端口的STP状态切换到了转发状态,以下是排查要点,请参考:
1、检查设备的物理链路是否正常。
2、检查是否有可能存在环路。
3、终端接入的端口配置为STP边缘端口。
aUtiSm 九段
粉丝:48人 关注:1人
将接入交换机的所有接终端的接口都开始边缘端口,然后在核心交换机上面查看dis stp brief看下是都都是转发状态
粉丝:226人 关注:0人
您好,要确认是否是有地址冲突或者环路
其次,接入终端接口建议设置为边缘端口
边缘端口(portfast)是指不直接与任何交换机连接,也不通过端口所连接的网络间接与任何交换机相连的端口。 常见:连接PC的端口建议开启
[h3c]int G1/0/3
[h3c -g1/0/3]stp disable
[h3c-g1/0/3]stp edged-port enable
[h3c-g1/0/3]quit
[h3c]stp bpdu-protection
