直接update ipe文件没有解开的话,先在电脑解压后再上传BIN文件吧。
以下是参考说明:
https://www.h3c.com/cn/d_201904/1166494_30005_40.htm#_Toc4403927
B.5 通过BootWare菜单升级启动文件
路由器上电和重新启动的过程中,在配置终端的屏幕上首先将显示:
DDR2 SDRAM test successful.
Press Ctrl+T to start five-step full RAM test...
Press Ctrl+Y to start nine-step full RAM test...
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing................
Done!
* H3C CR16000 BootWare, Version 1.22 *
Copyright (c) 2004-2012 New H3C Technologies Co., Ltd.
Compiled Date : Dec 13 2012
CPU Type : MPC8548E
CPU L1 Cache : 32KB
CPU L2 Cache : 512KB
CPU Clock Speed : 1000MHz
Memory Type : DDR2 SDRAM
Memory Size : 4096MB
Memory Speed : 400MHz
BootWare Size : 4MB
Flash Size : 128MB
cfa0 Size : 999MB
NVRAM Size : 1024KB
BASIC CPLD Version : 002
EXTEND CPLD Version : 002
PCB Version : Ver.B
Board self testing...........................
Board steady testing... [ PASS ]
Board SlotNo... [ 1 ]
Subcard exist testing... [ PASS ]
DX246 testing... [ PASS ]
PHY88E1111 testing... [ PASS ]
CPLD1 testing... [ PASS ]
CPLD2 testing... [ PASS ]
NS16550 register testing... [ PASS ]
The switch's Mac address... [B8:AF:67:30:32:00]
CF Card testing... [ PASS ]
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
· 为了阅读和便于理解,如果不做特殊说明,本菜单都将称为BootWare主菜单。
· 以上显示信息与设备实际情况相关,可能会略有差别。
在出现“Press Ctrl+B to enter extended boot menu...”的3秒钟之内,键入<Ctrl+B>,系统将进入BootWare扩展段主菜单,否则系统将进入程序解压过程;若程序进入解压过程后再希望进入BootWare扩展段,则需要重新启动设备,设备启动过程中再执行相关操作:
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> BootWare Operation Menu |
|<7> Clear Super Password |
|<8> Storage Device Operation |
|<9> Product Special Operation |
|<0> Reboot |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9):
该菜单含义如下:
表7 BootWare主菜单
菜单项 | 解释 |
<1> Boot System | 启动应用程序 |
<2> Enter Serial SubMenu | 进入串口子菜单 启动文件较大,通过串口(Console口)升级启动文件速度较慢,推荐您使用以太网口升级启动文件 |
<3> Enter Ethernet SubMenu | 进入以太网口子菜单 |
<4> File Control | 进入文件控制子菜单 |
<5> Restore to Factory Default Configuration | 恢复出厂配置启动 使能密码恢复功能后不支持该操作 |
<6> BootWare Operation Menu | 进入BootWare操作子菜单 |
<7> Clear Super Password | 清除Console口认证密码 关闭密码恢复功能后不支持该操作 |
<8> Storage Device Operation | 进入存储介质操作子菜单 |
<9> Product Special Operation | 进入产品专用子菜单 |
<0> Reboot | 重启设备 |
通过BootWare主菜单升级系统启动文件,主要有以下三种方式:
· 通过串口采用Xmodem协议完成BootWare以及应用程序的升级;
· 通过以太网口从TFTP服务器完成应用程序的升级;
· 通过以太网口从FTP服务器完成应用程序的升级。
B.5.2 通过串口采用Xmodem协议完成BootWare以及应用程序的升级
· Xmodem协议简介
XModem协议是一种文件传输协议,因其简单性和较好的性能而被广泛应用。XModem协议通过串口传输文件,支持128字节和1K字节两种类型的数据包,并且支持一般校验和、CRC两种校验方式,在出现数据包错误的情况下支持多次重传(一般为10次)。
XModem协议传输由接收程序和发送程序共同完成。先由接收程序发送协商字符,协商校验方式,协商通过之后发送程序就开始发送数据包,接收程序接收到完整的一个数据包之后按照协商的方式对数据包进行校验。校验通过之后发送确认字符,然后发送程序继续发送下一包;如果校验失败,则发送否认字符,发送程序重传此数据包。
· Xmodem应用
(2) 在Bootware主菜单中,键入<2>,回车后,系统进入串口子菜单:
===========================<Enter Serial SubMenu>==========================
|Note:the operating device is cfa0 |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Update User Private File |
|<6> Modify Serial Interface Parameter |
|<0> Exit To Main Menu |
Enter your choice(0-6):
(3) 在串口子菜单中,键入<6>,回车后,系统进入串口参数设置菜单:
===============================<BAUDRATE SET>=============================
|Note:'*'indicates the current baudrate |
| Change The HyperTerminal's Baudrate Accordingly |
|---------------------------<Baudrate Available>---------------------------|
|<1> 9600(Default)* |
|<2> 19200 |
|<3> 38400 |
|<4> 57600 |
|<5> 115200 |
|<0> Exit |
Enter your choice(0-5):1
(4) 在这个子菜单中可以根据实际情况,选择合适的下载速率,如上所示键入<1>,即选择9600bps的下载速率。
(5) 根据上面提示,改变配置终端设置的波特率,使其与所选的软件下载波特率一致,配置终端的波特率设置完成后,做一次终端的断开和连接操作,然后键入回车,终端再次进入串口子菜单:
Enter your choice(0-6):2
· 终端的波特率更改后,要做一次终端**程序的断开和连接操作,新的设置才能起作用;
· 如果是Win98操作系统,可以先设置完波特率后断开,再连接;如果是Win2000系统,则必须先断开才能设置参数,设置完以后再连接。
(6) 根据实际情况,用户选择升级选项,如上所示键入<2>,即将主用应用程序下载至设备,回车后,终端显示如下信息:
Please Select File .
XMODEM downloading ...CCC
(7) 此时,从终端窗口选择[传送/发送文件],在弹出的对话框(如下图)中点击[浏览]按扭,选择需要下载的软件,并将下载使用的协议改为XModem。
图2 [发送文件]对话框
(8) 选择完成后,点击[发送]按钮,系统弹出如下图所示的界面。
图3 正在发送文件界面
(9) 程序成功下载后,此时,系统将再次进入串口子菜单,用户根据自己的实际需要进行其他选择,此处不再赘述。在BootWare主菜单,执行重启操作,设备将以新加载的主用应用程序启动,完成应用程序的升级。
B.5.3 通过以太网口从TFTP服务器完成应用程序的升级
· TFTP介绍
TFTP(Trivial File Transfer Protocol,简单文件传输协议)协议适用于客户机和服务器之间不需要复杂交互的环境。
TFTP协议传输由客户端发起,当需要下载文件时,客户端向TFTP服务器发送读请求包,然后从服务器接收数据包,并向服务器发送确认信息;当需要上传文件时,由客户端向TFTP服务器发送写请求包,然后向服务器发送数据包,并接收服务器的确认信息。TFTP传输文件有两种模式:一种是二进制模式,用于传输程序文件;另一种是ASCII码模式,用于传输文本文件。
下面升级描述以设备作为TFTP客户端(Client)为例。
· TFTP升级步骤
(1) 将设备通过网络管理口与下载文件所在PC相连(需要知道该PC的IP地址),同时设备通过配置口外接一台PC(此PC与下载文件所在PC可以是同一台)。
(2) 在与网络管理口相连的PC上运行TFTP Server程序,并指定升级程序的文件路径。
(3) 在与配置口相连的PC上运行终端**程序,启动设备,进入BootWare主菜单。
(4) 在BootWare主菜单中,键入<3>,回车后,系统进入以太网口子菜单:
==========================<Enter Ethernet SubMenu>=========================
|<6> Modify Ethernet Parameter |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-6):6
(5) 若操作文件下载,请键入<6>,修改以太网口相关参数的设置,系统界面如下:
==========================<ETHERNET PARAMETER SET>=========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
上面的信息提示用户,在菜单项中键入“.”将清除该项设置,键入“-”将返回上一个设置项,键入<Ctrl+D>表示退出设置。
Protocol (FTP or TFTP) :TFTP
Load File Name :bootware
:test.bin
Target File Name :bootware
:test.bin
Server IP Address :192.168.1.1
Local IP Address :192.168.1.253
Gateway IP Address :0.0.0.0
(6) 用户根据实际情况,完成上面相关信息的输入后,系统再次进入以太网口子菜单:
(7) 在如上所示的以太网口子菜单中键入<2>,即将主用应用程序下载至设备中,回车后,终端显示如下信息:
Loading...................................................................
..................................Done!
47979456 bytes downloaded!
Updating File cfa0:/test.bin..............................................
..Done!
(8) 上面的信息,表明文件下载成功!此时,系统将再次进入以太网口子菜单,用户根据自己的实际需要进行选择,此处不再赘述。
B.5.4 通过以太网口从FTP服务器完成应用程序的升级
· FTP介绍
通过以太网口,设备还可通过FTP(File Transfer Protocol,文件传输协议)来完成软件升级。
(0)
您好,可以的,参考
Done!
CPU Type : MPC8548E
CPU L1 Cache : 32KB
BootWare Size : 4MB
Flash Size : 128MB
cfa0 Size : 999MB
NVRAM Size : 1024KB
PCB Version : Ver.B
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
该菜单含义如下:
表7 BootWare主菜单
菜单项 | 解释 |
<0> Reboot | 重启设备 |
· Xmodem协议简介
· Xmodem应用
|<2> 19200 |
|<3> 38400 |
|<4> 57600 |
|<5> 115200 |
|<0> Exit |
图2 [发送文件]对话框
图3 正在发送文件界面
· TFTP介绍
· TFTP升级步骤
| Ctrl+D = Quit. |
:test.bin
:test.bin
..Done!
· FTP介绍
(0)
版本跨度大,解不开ipe文件,上传boot和system的bin文件后,bootware版本升级了,重启后然后两个bin文件又识别不了,再升级ipe文件,直接自动解压了,升级成功
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
