交换机告警信息
  • 1收藏,1950浏览
粉丝:0人 关注:4人
各位大神,我现在遇到一个问。就是我的交换机内部局域网是通的,但是光模块连接的上级交换机无法通讯并且交换机一直在刷这些告警信息。请问这些信息代表了什么。另外请问如何查询光模块收发的是否正常。交换机型号为H3C    5600
#Jul 12 22:14:02:687 2021 10-GTB-SS-01 DEV/2/POWER REMOVED:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.5: power ID is 1
 #Jul 12 22:14:02:830 2021 10-GTB-SS-01 DEV/2/POWER INSERT:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.23: power ID is 1
 #Jul 12 22:14:02:975 2021 10-GTB-SS-01 DEV/2/POWER STATE CHANGE TO NORMAL:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.2: power ID is 1 %Jul 12 22:14:03:142 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Power 1 is absen
t %Jul 12 22:14:03:225 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Power 1 recovered
 #Jul 12 22:14:30:778 2021 10-GTB-SS-01 DEV/2/FAN STATE CHANGE TO FAILURE:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.6: fan ID is 1
 #Jul 12 22:14:30:929 2021 10-GTB-SS-01 DEV/2/FAN STATE CHANGE TO FAILURE:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.6: fan ID is 2
 #Jul 12 22:14:31:075 2021 10-GTB-SS-01 DEV/2/FAN STATE CHANGE TO FAILURE:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.6: fan ID is 3
 %Jul 12 22:14:31:225 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Fan 1 failed
%Jul 12 22:14:31:308 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Fan 2 failed
%Jul 12 22:14:31:392 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Fan 3 failed
#Jul 12 22:14:42:231 2021 10-GTB-SS-01 DEV/2/POWER REMOVED:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.5: power ID is 1
 #Jul 12 22:14:42:382 2021 10-GTB-SS-01 DEV/2/POWER INSERT:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.23: power ID is 1
 #Jul 12 22:14:42:525 2021 10-GTB-SS-01 DEV/2/POWER STATE CHANGE TO NORMAL:- 1 - Trap 1.3.6.1.4.1.2011.2.23.1.12.1.2: power ID is 1 %Jul 12 22:14:42:692 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Power 1 is absent
 %Jul 12 22:14:42:775 2021 10-GTB-SS-01 DEV/5/DEV_LOG:- 1 - Power 1 recovered
粉丝:4人 关注:0人
配了SNMP,检查一下设备电源以及风扇是否异常。
查看光模块收发光功率: display transceiver diagnosis interface ten-GigabitEthernet 1/0/25
zhiliao_z5rqq 发表时间:2021-07-12
谢谢您的答案
zhiliao_5gcO2 发表时间:2021-07-12
回复zhiliao_5gcO2:
不客气
IP address 172.16.219.2 collision detected, sourced by 80e4-55bc-5ae0 on GigabitEthernet1/0/1 of VLAN20 and 80e4-55bc-4ea0 on GigabitEthernet1/0/51 of VLAN20 请问这个告警的说IP地址冲突么?
对的
粉丝:124人 关注:6人
从反馈的信息来看是配置了SNMP.
具体检查下风扇、电源、光口收发光看下是否正常。
Eugene 四段
这个告警和你上行不通没关系,上行不通display tran diag inter xxx看看收发光,确认端口起来没
粉丝:226人 关注:0人
您好,这是snmp,电源,风扇的信息,检查电源风扇是否故障
