WAP712C 不断重启
2021-07-14提问
  • 1收藏,696浏览
AP不停的自己重启,不知道咋回事啊,也没报错。。
<WAP712C> #Jan 1 12:00:09:517 2009 WAP712C SHELL/4/LOGIN: Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console %Jan 1 12:00:09:517 2009 WAP712C SHELL/5/SHELL_LOGIN: Console logged in from con0. %Jan 1 12:00:10:022 2009 WAP712C IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/1 link status is UP. %Jan 1 12:00:10:022 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing......................Done! **************************************************************************** * * * H3C WAP712C BootWare, Version 1.04 * * * **************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Mar 18 2016 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fat.bin!.......... ............................................................................ ............................................................................ ........ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ..........................Done! System application is starting... System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing......................Done! **************************************************************************** * * * H3C WAP712C BootWare, Version 1.04 * * * **************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Mar 18 2016 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fat.bin!.......... ............................................................................ ............................................................................ ........ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ..........................Done! System application is starting...
粉丝:124人 关注:6人
从反馈来看,AP没有注册到AC,AP无法上线,以下是排查要点,请参考:
1、检查AP出来的网线、水晶头是否有问题。
2、检查基础网络是否可达,比如VLAN透传。
3、检查AC内的授权是否足够使用。
4、检查AC的软件版本是否适配AP。
5、检查AC内是否注册了AP的型号和序列号。
6、检查DHCP内的IP地址是否足够使用。
我这个是胖AP。。。
zhiliao_Jjlkf 发表时间:2021-07-14
重新导入一个新的软件版本进去看下是否能启动,不排除是FAT版本文件损坏了。
得闲饮茶013 发表时间:2021-07-14
aUtiSm 九段
粉丝:48人 关注:1人
ap有没有注册到控制器
如果没有注册到控制器就会一直重启
粉丝:144人 关注:0人
您好,瘦AP需要搭配AC使用
zhiliao_Jjlkf 知了小白
我这个是胖AP,系统现在终端一直打印如下字符:
Press Ctrl+D to a#
