请问S5130管理口的默认IP地址和默认登录账号密码是多少? 另外,为什么console登录不了呢? 多谢了。
2021-07-18提问
  • 1收藏,3586浏览
WL_ZXY 四段
粉丝:5人 关注:0人
5130设备出厂不带console口密码,可以直接登录。
密码恢复:
3.1 进入bootroom菜单清除Consle密码
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择<6> Skip Current System Configuration跳过当前配置启动,不同设备可能不是数字6
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
<H3C>save
The current configuration will be written to the device. Are you sure? [Y/N]:y
Please input the file name(*.cfg)[flash:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):(输入回车)
flash:/startup.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait...
Configuration is saved to device successfully.
<H3C>reboot
Start to check configuration with next startup configuration file, please wait.........DONE!
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
This command will reboot the device. Continue? [Y/N]:y
关键是我连上console线后,无法连上华三交换机,,却可以连上华为的交换机。 我现在想要进入交换机做配置,要么用默认IP及账号密码进入,要么解决为什么不能登录console线的问题,不然就只能把华三这破交换机扔了!
zhiliao_zaAEs4 发表时间:2021-07-18
没有默认ip,缺省web、telnet、ssh都是关闭的。 console口登录是不需要ip的 若接上没反应可以更换console线试试
WL_ZXY 发表时间:2021-07-18
粉丝:3人 关注:0人
默认无IP地址,console可一直接登录的。不能登请查是否插错接口,或CRT有问题了
粉丝:124人 关注:6人
1、如果忘记远程登陆密码,可通过console登录修改,参考命令如下:
local-user admin
password simple admin
2、如果所有密码都忘记了,可通过重启,按下“ctrl+b”进入bootrom,选择跳过console密码选项进入设备后修改。
2、如果没有跳过console密码的选项,则选择跳过当前配置启动,将startup.cfg这个文件导出,用TXT方式打开后,将密码部分删除,保存,导入设备重启后再登陆看看。
console登陆方法如下:
一、准备工作
1、  console线一条,样子如下所示,一遍为RJ45的水晶头,一遍为DB9的串口
2、  查看电脑上有没有DB9的公头接口,如下所示,一般台式机会有,笔记本自带的很少:
3、  如果没有串口的话,可以购买usbconsole调试线,如下图所示,扁头的部分和console线互联,usb部分查到电脑的usb接口上,最后连接效果就是:
设备的console----console线-------usb转换线------电脑usb接口
4、  电脑准备CRT或者putty程序,下面以CRT为例,CRT长这个样子:
下一步查看驱动是否装好,邮件点击计算机(或者叫我的电脑),选择管理
然后点击左侧导航栏里的设备管理器,查看是否有”COMLPT”选项,如下图所示:
如果没有也不用急,没有说明是驱动没装好,可以通过下面几种方法解决:
方法一:通过自带的驱动光盘安装
方法二:通过windows更新驱动程序
在设备管理器里会看到一个未知设备,邮件选择更新驱动程序软件:
然后选择通过internet安装驱动
方法三:安装驱动精灵
如果,提示安装失败,或者找不到驱动程序,那就下载一个驱动精灵,扫描一下电脑驱动,肯定是可以找到的。
二、登录设备:
1、  以上准备工作完成后,就可以通过在计算机---管理---设备管理器中看到当前用的是那个com接口,例如下图中识别到的是com5
2、  设置CRT,点击快速连接,协议选择Serial,端口选择上一步中确认端口,波特率一定要选择9600,流控都不需要勾选,点击链接后,打几次回车,就可以登录上去了,如下面两个图所示
