华三msr3610-x1配置L2TP VPN
2021-07-19提问
  • 1收藏,2909浏览
这台路由器连接专线有固定地址,外出员工想通过L2TP VPN 连接到内网,来访问公司服务器,这个要怎么配置呢,有具体的配置案例分析吗
路由器到防火墙到核心到汇聚到服务器
粉丝:124人 关注:6人
以下是L2TP VPN客户端LAC的配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器来实现客户LAC模式的组网实验。内网和外网在网络拓扑图已有明确的标识。由于模拟器及本物理机的局限性,因此采用S5820交换机开启WEB功能来模拟成为WEB服务器。LNS模拟成为L2TP的LNS,物理机通过拨号的方式接入内网。
特别说明:
本实验仅仅是测试L2TP VPN(客户LAC模式)的实现效果,不作为真实组网的案例。
配置步骤
1、按照网络拓扑图正确配置IP地址
2、SW1开启WEB功能,并创建相应账户及赋予权限
3、SW1配置默认路由指向到LNS
4、LNS配置NAT地址转换,在配置L2TP前,外网终端无法访问内网的SW1
5、LNS配置L2TP,外网终端通过设置拨号,拨号进入内网访问内网的SW1的WEB服务
配置关键点
1、第一阶段配置(基础网络调试,配置L2TP前):
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]ip http enable
[SW1]ip https enable
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-mode route
[SW1-GigabitEthernet1/0/1]ip address 10.0.0.1 30
[SW1-GigabitEthernet1/0/1]des <connect to LNS>
[SW1-GigabitEthernet1/0/1]quit
[SW1]ip route-static 0.0.0.0 0.0.0.0 10.0.0.2
[SW1]local-user admin
New local user added.
[SW1-luser-manage-admin]password simple admin
[SW1-luser-manage-admin]service-type http https
[SW1-luser-manage-admin]authorization-attribute user-role network-admin
[SW1-luser-manage-admin]quit
[SW1]
LNS:
<H3C>sys
[H3C]sysname LNS
[LNS]int gi 0/0
[LNS-GigabitEthernet0/0]des <connect to SW1>
[LNS-GigabitEthernet0/0]ip address 10.0.0.2 30
[LNS-GigabitEthernet0/0]quit
[LNS]ip route-static 192.168.10.0 255.255.255.0 10.0.0.1
[LNS]acl basic 2000
[LNS-acl-ipv4-basic-2000]rule 0 permit source any
[LNS-acl-ipv4-basic-2000]quit
[LNS]int gi 0/1
[LNS-GigabitEthernet0/1]ip address 202.1.100.2 28
[LNS-GigabitEthernet0/1]nat outbound 2000
[LNS-GigabitEthernet0/1]quit
[LNS]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
ISP:
<H3C>sys
[H3C]sysname ISP
[ISP]int gi 0/1
[ISP-GigabitEthernet0/1]des <connect to LNS>
[ISP-GigabitEthernet0/1]ip address 202.1.100.1 28
[ISP-GigabitEthernet0/1]quit
[ISP]int gi 0/0
[ISP-GigabitEthernet0/0]ip address 202.103.224.254 24
[ISP-GigabitEthernet0/0]quit
[ISP]ip route-static 202.1.100.0 255.255.255.240 202.1.100.2
[ISP]
第一阶段测试:
所有终端都设置IP地址:
内网PC能PING外网终端:
外网终端仅能PING通到LNS的外网口IP,无法PING通到内网:
2、第二阶段配置(L2TP关键配置点):
[LNS]local weijianing class network  //创建用户名、密码,并赋予PPP认证的方式
[LNS-luser-network-weijianing]password simple weijianing
[LNS-luser-network-weijianing]service-type ppp
[LNS-luser-network-weijianing]quit
[LNS]domain name system  //配置域,验证方式为本地PPP
[LNS-isp-system]authentication ppp local
[LNS-isp-system]quit
[LNS]ip pool weijianing 192.168.0.2 192.168.0.100  //创建地址池,用于VPN拨号用户的IP地址分配
[LNS]int Virtual-Template 1  //创建虚拟模板1
[LNS-Virtual-Template1]ip address 192.168.0.1 255.255.255.0  //配置模板的IP地址
[LNS-Virtual-Template1]ppp authentication-mode chap domain system  //PPP认证方式为CHAP,并调用system的domain域
[LNS-Virtual-Template1]remote address pool weijianing  //调用地址池
[LNS-Virtual-Template1]quit
[LNS]l2tp enable  //开启L2TP
[LNS]l2tp-group 1 mode lns  //创建L2TP组1,模式为LNS
[LNS-l2tp1]tunnel name LNS  //配置隧道名称为LNS
[LNS-l2tp1]allow l2tp virtual-template 1  //调用虚拟模板1到L2TP组
[LNS-l2tp1]undo tunnel authentication  //关闭隧道功能
[LNS-l2tp1]quit
[LNS]domain default enable system
第二阶段测试:
本物理机是windows 7 32的操作系统,因此需要提前设置VPN拨号。
打开网络和共享中心,点击“设置新的连接或网络”:
选择“连接到工作区”后,点击“下一步”:
选择“使用我的Internet连接(VPN)”
选择“我稍后决定”,点击“下一步”:
输入inernet地址后,点击“下一步”
输入用户名,密码,点击“连接”:
右键,选择“属性”:
选择“安全”,设置VPN类型,在设置“数据加密”,如下图所示:
打开之前创建的“VPN”连接
输入用户名、密码,点击连接:
VPN已连接上,并查看VPN信息:
此时,外网终端已能ping通内网:
同时,也可以打开内网的WEB服务
在LNS上查看VPN的信息:
粉丝:119人 关注:1人
http://www.h3c.com/cn/d_201804/1074591_30005_0.htm
参考这个anli
zhiliao_OWS8w1 知了小白
还是不要多说什么了,
了解新华三(h3c)的产品先看下这个吧。
https://zhiliao.h3c.com/questions/dispcont/254273
