S5500v2_SI 交换机 不同VLAN之间如何互访,还有 我想给19、20设置特定的IP
2018-06-15提问
  • 1收藏,1298浏览
粉丝:1人 关注:1人
大家好,我这边新买了个 H3C_S5500 V2_SI 的交换机,我配置了 多个VLAN,这个交换机现在的web后台没有虚拟VLAN,配置不了跨VLAN间的互访。请问如何设置。
还有想给 19、20 这2个特定端口设置一个固定的IP以便用作同城互联,配置如下,谢谢,
# version 7.1.045, Release 3116
# sysname H3C_701-3
 # clock timezone Lisbon add 00:00:00 clock protocol none
 # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1
# dhcp enable # lldp global enable
# password-recovery enable
# vlan 1
 description Manager
# vlan 3
 description VLAN 3
# vlan 50
 description VLAN50
# vlan 60
 description VLAN60
 # vlan 70
 description VLAN70
# vlan 80
 description VLAN80
# vlan 120
 description VLAN120
# vlan 130
 description VLAN130
 # stp global enable
# dhcp server ip-pool 3
# dhcp server ip-pool VLAN50
 network 172.18.5.0 mask 255.255.255.0
 # dhcp server ip-pool VLAN60
 network 172.18.6.0 mask 255.255.255.0
 # dhcp server ip-pool VLAN70
 network 172.18.7.0 mask 255.255.255.0
 # dhcp server ip-pool VLAN80
 network 172.18.8.0 mask 255.255.255.0
 # dhcp server ip-pool VLAN120
network 172.18.12.0 mask 255.255.255.0
# dhcp server ip-pool VLAN130
 network 172.18.13.0 mask 255.255.255.0
# interface NULL0
# interface Vlan-interface1
 ip address 192.168.1.10 255.255.255.0
# interface Vlan-interface50
 ip address 172.18.5.1 255.255.255.0
 # interface Vlan-interface60
 ip address 172.18.6.1 255.255.255.0
# interface Vlan-interface70
 ip address 172.18.7.1 255.255.255.0
 # interface Vlan-interface80
 ip address 172.18.8.1 255.255.255.0
# interface Vlan-interface120
 ip address 172.18.12.1 255.255.255.0
# interface Vlan-interface130
 ip address 172.18.13.1 255.255.255.0
 # interface GigabitEthernet1/0/1
 port access vlan 50
 # interface GigabitEthernet1/0/2
 port access vlan 50
 # interface GigabitEthernet1/0/3
 port access vlan 50
# interface GigabitEthernet1/0/4
 port access vlan 60
# interface GigabitEthernet1/0/5
 port access vlan 60
# interface GigabitEthernet1/0/6
 port access vlan 60
 # interface GigabitEthernet1/0/7
 port access vlan 70
# interface GigabitEthernet1/0/8
 port access vlan 70
# interface GigabitEthernet1/0/9
 port access vlan 70
# interface GigabitEthernet1/0/10
 port access vlan 80
# interface GigabitEthernet1/0/11
 port access vlan 80
# interface GigabitEthernet1/0/12
 port access vlan 80
 # interface GigabitEthernet1/0/13
 port access vlan 80
 # interface GigabitEthernet1/0/14
 port access vlan 80
# interface GigabitEthernet1/0/15
 port access vlan 120
# interface GigabitEthernet1/0/16
 port access vlan 130
# interface GigabitEthernet1/0/17
# interface GigabitEthernet1/0/18
# interface GigabitEthernet1/0/19
 port access vlan 3
# interface GigabitEthernet1/0/20
port access vlan 3
# interface GigabitEthernet1/0/21
 # interface GigabitEthernet1/0/22
# interface GigabitEthernet1/0/23
# interface GigabitEthernet1/0/24
 # interface GigabitEthernet1/0/25
# interface GigabitEthernet1/0/26
# interface Ten-GigabitEthernet1/0/27
 # interface Ten-GigabitEthernet1/0/28
# scheduler logfile size 16
# line class aux
 user-role network-admin
 # line class vty
 user-role network-operator
# line aux 0
 # line vty 0 63
 # snmp-agent
 snmp-agent local-engineid 800063A28038ADBE5E887A00000001
 snmp-agent sys-info location 701_3
 snmp-agent sys-info version v3
 # radius scheme system user-name-format without-domain
 # domain system
 # domain default enable system
 # role name level-0 description Predefined level-0 role
 # role name level-1 description Predefined level-1 role
# role name level-2 description Predefined level-2 role
# role name level-3 description Predefined level-3 role
 # role name level-4 description Predefined level-4 role
 # role name level-5 description Predefined level-5 role
 # role name level-6 description Predefined level-6 role
# role name level-7 description Predefined level-7 role
# role name level-8 description Predefined level-8 role
 # role name level-9 description Predefined level-9 role
 # role name level-10 description Predefined level-10 role
# role name level-11 description Predefined level-11 role
 # role name level-12 description Predefined level-12 role
 # role name level-13 description Predefined level-13 role
 # role name level-14 description Predefined level-14 role
 # user-group system
# local-user ADMIN class manage
 # local-user admin class manage
 password hash
 service-type ssh http authorization-attribute user-role level-15
 # ip http enable ip https enable
 # return
这你个配置就能三层互访啊。配置了三层vlan虚接口,并且接口下绑定了vlan,那么这台设备就是下面PC的网关,可以直接三层互访了。
粉丝:19人 关注:0人
跨VLAN三层互访吗?有对应的路由吗
是的呢,什么对应的路由,全部配置就这些了
烟花里的尘埃 发表时间:2018-06-15
首先说你要互访的地址是哪两个
时光记忆srp 发表时间:2018-06-15
是这样子的,例如我上面设置了的v网段 172.18.5.1/24 要与 172.18.6.1/24 互访,现在是ping不同不同网段的
如果不通网段内的终端无法互相ping通,你先看看终端的网关是否设置正确了。首先就是要两个ping的设备直接都有对应互访的路由
时光记忆srp 发表时间:2018-06-17
