IMC 数据库备份失败
2021-07-20提问
  • 1收藏,1122浏览
IMC备份失败,查看dbman_debug,是什么问题?
2021-07-22021-07-20 04:06:09 [INFO] [RemoveReservedFile] Begin Remove Reserved File
2021-07-20 04:06:09 [INFO] [ClearFile] ClearFile
2021-07-20 04:06:09 [INFO] [Client::connect_to_server] Starting connect to X.X.X.X: 2810
 2021-07-20 04:06:30 [DEBUG] [Client::connect_to_server] errno: 10060, strerror: connection timed out
 2021-07-20 04:06:30 [ERROR] [Client::connect_to_server] Connection failed
 2021-07-20 04:06:30 [ERROR] [send_removeReservedFile_msg] Fail to connect
 2021-07-20 15:04:01 [DEBUG] [My_Accept_Handler::handle_input] Connection established 127.0.0.1
2021-07-20 15:04:01 [DEBUG] [CDataConnStreamQueueT::deal_msg] Receive command code: 10000
 2021-07-20 15:04:01 [DEBUG] [CDataConnStreamQueueT::deal_msg] Succeed to create SendBakConfigFileReq thread
2021-07-20 15:04:02 [INFO] [SendBakConfigFileReq] Reload config from file: C:\Program Files\iMC\dbman\bin\..\etc\dbman.conf
 2021-07-20 15:04:02 [INFO] [Client::connect_to_server] Starting connect to 127.0.0.1: 2810
 2021-07-20 15:04:02 [INFO] [Client::connect_to_server] Established connection to 127.0.0.1: 2810
2021-07-20 15:04:02 [DEBUG] [My_Accept_Handler::handle_input] Connection established 127.0.0.1
 2021-07-20 15:04:02 [DEBUG] [CDataConnStreamQueueT::deal_msg] Receive command code: 10020
2021-07-20 15:04:02 [ERROR] [response_err_code] errCode = 0
2021-07-20 15:04:02 [DEBUG] [CDataConnStreamQueueT::deal_msg] Success to create directory
2021-07-20 15:04:02 [INFO] [Client::connect_to_server] Starting connect to x.x.x.x: 2810
2021-07-20 15:04:23 [DEBUG] [Client::connect_to_server] errno: 10060, strerror: connection timed out
 2021-07-20 15:04:23 [ERROR] [Client::connect_to_server] Connection failed
2021-07-20 15:04:23 [ERROR] [Client::send_make_directory_msg] Fail to connect
2021-07-20 15:04:23 [INFO] [SendBakConfigFileReq] Fail to create directory
2021-07-20 15:04:23 [INFO] [SendBakConfigFileReq] Reload config from file: C:\Program Files\iMC\dbman\bin\..\etc\dbman.conf-
2021-07-20 15:04:23 [INFO] [SendBakConfigFileReq] ret: -1
2021-07-20 15:04:23 [ERROR] [response_err_code] errCode = -1
2021-07-20 15:05:33 [DEBUG] [My_Accept_Handler::handle_input] Connection established 127.0.0.1
2021-07-20 15:05:33 [DEBUG] [CDataConnStreamQueueT::deal_msg] Receive command code: 10000
2021-07-20 15:05:33 [DEBUG] [CDataConnStreamQueueT::deal_msg] Succeed to create SendBakConfigFileReq thread
2021-07-20 15:05:33 [INFO] [SendBakConfigFileReq] Reload config from file: C:\Program Files\iMC\dbman\bin\..\etc\dbman.conf
 2021-07-20 15:05:33 [INFO] [Client::connect_to_server] Starting connect to 127.0.0.1: 2810
2021-07-20 15:05:33 [INFO] [Client::connect_to_server] Established connection to 127.0.0.1: 2810
2021-07-20 15:05:33 [DEBUG] [CDataConnStreamQueueT::deal_msg] Receive command code: 10020
2021-07-20 15:05:33 [ERROR] [response_err_code] errCode = 0
2021-07-20 15:05:33 [DEBUG] [CDataConnStreamQueueT::deal_msg] Success to create directory
2021-07-20 15:05:33 [INFO] [Client::connect_to_server] Starting connect to x.x.x.x: 2810
 2021-07-20 15:05:54 [DEBUG] [Client::connect_to_server] errno: 10060, strerror: connection timed out
2021-07-20 15:05:54 [ERROR] [Client::connect_to_server] Connection failed
2021-07-20 15:05:54 [ERROR] [Client::send_make_directory_msg] Fail to connect
2021-07-20 15:05:54 [INFO] [SendBakConfigFileReq] Fail to create directory
2021-07-20 15:05:54 [INFO] [SendBakConfigFileReq] Reload config from file: C:\Program Files\iMC\dbman\bin\..\etc\dbman.conf-
2021-07-20 15:05:54 [INFO] [SendBakConfigFileReq] ret: -1
2021-07-20 15:05:54 [ERROR] [response_err_code] errCode = -1
粉丝:8人 关注:16人
像是连接数据库失败,检查数据库的配置是否有问题
粉丝:16人 关注:14人
dbman_debug.log里的error是什么报错呢?
粉丝:124人 关注:6人
检查下各IMC的组件是否启动完成。
如果是有备机,检查与备机的通信是否正常,备机的IMC各组件是否启动完成。
组件都启动了,数据库不是本地的,应该有单独服务器
zhiliao_b8mub 发表时间:2021-07-20
没有备机
