IPSEC VPN
2021-07-21提问
  • 1收藏,939浏览
白熊 三段
粉丝:2人 关注:3人
ipsec VPN建好没反应      pc_4能PING通F1060_3的公网IP        pc_5能PING通F1060_1的公网IP            两FW也能互相PING通   两FW配置见附件
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
粉丝:124人 关注:6人
没有看到附件。
IPSEC VPN故障排查:
1、检查公网地址的连通性
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
<f1060_1>dis cu # version 7.1.064, Alpha 7164 # sysname f1060_1 # context Admin id 1 # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # nat address-group 10 address 55.55.55.55 55.55.55.55 # xbar load-single password-recovery enable lpu-type f-series # vlan 1 # interface NULL0 # interface GigabitEthernet1/0/0 port link-mode route combo enable copper ip address 55.55.55.55 255.255.255.0 nat outbound 3001 address-group 10 ipsec apply policy vpn # interface GigabitEthernet1/0/1 port link-mode route combo enable copper ip address 192.168.0.1 255.255.255.0 # interface GigabitEthernet1/0/2 port link-mode route combo enable copper ip address 10.10.10.1 255.255.255.0 # interface GigabitEthernet1/0/3 port link-mode route combo enable copper # interface GigabitEthernet1/0/4 port link-mode route combo enable copper # interface GigabitEthernet1/0/5 port link-mode route combo enable copper # interface GigabitEthernet1/0/6 port link-mode route combo enable copper # interface GigabitEthernet1/0/7 port link-mode route combo enable copper # interface GigabitEthernet1/0/8 port link-mode route combo enable copper # interface GigabitEthernet1/0/9 port link-mode route combo enable copper # interface GigabitEthernet1/0/10 port link-mode route combo enable copper # interface GigabitEthernet1/0/11 port link-mode route combo enable copper # interface GigabitEthernet1/0/12 port link-mode route combo enable copper # interface GigabitEthernet1/0/13 port link-mode route combo enable copper # interface GigabitEthernet1/0/14 port link-mode route combo enable copper # interface GigabitEthernet1/0/15 port link-mode route combo enable copper # interface GigabitEthernet1/0/16 port link-mode route combo enable copper # interface GigabitEthernet1/0/17 port link-mode route combo enable copper # interface GigabitEthernet1/0/18 port link-mode route combo enable copper # interface GigabitEthernet1/0/19 port link-mode route combo enable copper # interface GigabitEthernet1/0/20 port link-mode route combo enable copper # interface GigabitEthernet1/0/21 port link-mode route combo enable copper # interface GigabitEthernet1/0/22 port link-mode route combo enable copper # interface GigabitEthernet1/0/23 port link-mode route combo enable copper # security-zone name Local # security-zone name Trust import interface GigabitEthernet1/0/2 # security-zone name DMZ # security-zone name Untrust import interface GigabitEthernet1/0/0 # security-zone name Management # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-admin # line con 0 authentication-mode scheme user-role network-admin # line vty 0 4 authentication-mode scheme user-role network-admin # line vty 5 63 user-role network-operator # ip route-static 0.0.0.0 0 55.55.55.1 # acl advanced 3000 rule 0 permit ip source 10.10.10.0 0.0.0.255 destination 10.10.20.0 0.0.0.255 # acl advanced 3001 rule 10 deny ip source 10.10.10.0 0.0.0.255 destination 10.10.20.0 0.0.0.255 rule 100 permit ip # domain system # aaa session-limit ftp 16 aaa session-limit telnet 16 aaa session-limit ssh 16 domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ== service-type telnet terminal http authorization-attribute user-role level-3 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # ipsec transform-set 10 esp encryption-algorithm aes-cbc-128 esp authentication-algorithm sha1 # ipsec policy vpn 10 isakmp transform-set 10 security acl 3000 local-address 55.55.55.55 remote-address 66.66.66.66 ike-profile 10 # ike profile 10 keychain 10 match remote identity address 66.66.66.66 255.255.255.0 proposal 10 # ike proposal 10 encryption-algorithm 3des-cbc dh group2 authentication-algorithm md5 # ike keychain 10 pre-shared-key address 66.66.66.66 255.255.255.0 key cipher $c$3$/wKmB/keK8koduFW8B2q1aO7gMUYQ48+ssy1w2Y= # ip http enable ip https enable # security-policy ip rule 0 name any action pass # return
白熊 发表时间:2021-07-21
我在回答里加了。
白熊 发表时间:2021-07-21
白熊 三段
粉丝:2人 关注:3人
<f1060_1>dis cu
sysname f1060_1
context Admin id 1
undo irf link-delay
xbar load-single
lpu-type f-series
vlan 1
interface NULL0
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
line class aux
line class console
line class tty
line class vty
line aux 0
line con 0
line vty 0 4
line vty 5 63
acl advanced 3000
acl advanced 3001
rule 100 permit ip
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
transform-set 10
security acl 3000
ike-profile 10
ike profile 10
keychain 10
proposal 10
ike proposal 10
dh group2
ike keychain 10
ip http enable
ip https enable
security-policy ip
rule 0 name any
action pass
return
[f1060_3]DIS CU
sysname f1060_3
context Admin id 1
undo irf link-delay
address 66.66.66.66 66.66.66.66
xbar load-single
lpu-type f-series
vlan 1
interface NULL0
combo enable copper
ip address 66.66.66.66 255.255.255.0
combo enable copper
combo enable copper
ip address 10.10.20.1 255.255.255.0
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
line class aux
line class console
line class tty
line class vty
line aux 0
line con 0
line vty 0 4
line vty 5 63
ip route-static 0.0.0.0 0 66.66.66.1
acl advanced 3000
rule 0 permit ip source 10.10.20.0 0.0.0.255 destination 10.10.10.0 0.0.0.255
acl advanced 3001
rule 50 deny ip source 10.10.20.0 0.0.0.255 destination 10.10.10.0 0.0.0.255
rule 100 permit ip
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
transform-set 10
security acl 3000
local-address 66.66.66.66
remote-address 55.55.55.55
ike-profile 10
ike profile 10
keychain 10
match remote identity address 55.55.55.55 255.255.255.0
proposal 10
ike proposal 10
dh group2
ike keychain 10
pre-shared-key address 55.55.55.55 255.255.255.0 key cipher $c$3$tzlmO4EF6dIhx5iYWEtfFYuVyh72QzdKUsrAkBE=
ip http enable
ip https enable
security-policy ip
rule 0 name any
action pass
return
[f1060_3]
