不同错包代表的意思
2021-07-27提问
  • 1收藏,2387浏览
粉丝:0人 关注:12人
在dis int 查看端口详情,可以看到端口下有好几种错包,这些错包代表的意思分别是什么?
有人可以帮忙解答一下吗?
粉丝:38人 关注:3人
interface-type:指定接口类型。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口FortyGigE1/0/1的运行状态和相关信息。
<Sysname> display interface fortygige 1/0/1
FortyGigE1/0/1
Line protocol state: DOWN
Description: FortyGigE1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is twisted pair, port hardware type is 1000_BASE_T
Ethernet port mode: LAN
Port priority: 2
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 6 hours 39 minutes 28 seconds
 Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Last 300 second input:  0 packets/sec 0 bytes/sec  0%
 Last 300 second output: 0 packets/sec 0 bytes/sec  0%
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
# 查看二层以太网接口FortyGigE1/0/1的运行状态和相关信息。
FortyGigE1/0/1
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last 300 second input:  0 packets/sec 0 bytes/sec -%
 Last 300 second output:  0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
表1-4 display interface命令显示信息描述表
FortyGigE1/0/1
接口FortyGigE1/0/1的相关信息
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭
·     DOWN ( Tunnel-Bundle administratively down ):表示该接口所属的Tunnel-Bundle接口已经通过shutdown命令被关闭
·     Link-Flap DOWN:表示接口被链路震荡保护功能关闭
·     IRF-link-down:接口属于某MDC时,由于接口所在成员设备上划分到该MDC的所有IRF链路状态为DOWN或ADM,接口被IRF链路检测功能关闭
·     mac-address moving down:由于MAC地址迁移抑制导致接口被关闭
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为MAD ShutDown
·     OFP DOWN:表示接口开启了OpenFlow的关闭接口功能
·     Storm-Constrain:表示端口上因为未知单播、组播或广播报文中某类报文的流量大于其上限阈值而被关闭
·     STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
·     DOWN:表示数据链路层协议状态为关闭
·     DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为DLDP、OAM、LAGG、BFD和MACSEC的任意组合:
¡     DLDP:表示由于DLDP模块检测到单通而关闭接口的数据链路层
¡     OAM:表示由于以太网OAM模块检测到远端链路故障而关闭接口的数据链路层
¡     LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层
¡     BFD:表示由于BFD模块检测到链路故障而关闭接口的数据链路层
¡     MACSEC:表示由于MACSEC模块还未协商成功接口的通信加密参数而关闭接口的数据链路层
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
Internet address
接口的主IP地址
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
Port hardware type is
接口的硬件类型
Port priority
接口优先级
Loopback is set internal
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关
Loopback is set external
对以太网接口进行对外环回测试,该显示信息与用户的配置有关
Loopback is not set
接口上未配置环回测试,该显示信息与用户的配置有关
10Mbps-speed mode
接口速率为10Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Mbps-speed mode
接口速率为100Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
1000Mbps-speed mode
接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关
10Gbps-speed mode
接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
40Gbps-speed mode
接口速率为40Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
100Gbps-speed mode
接口速率为100Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
Unknown-speed mode
速率未知,可能因为速率协商失败或者接口物理未连通
full-duplex mode
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
unknown-duplex mode
未知双工模式,可能因为双工模式协商失败或者接口物理未连通
当用户配置了speed auto时显示该信息
Link speed type is force link
当用户使用speed命令配置了具体的速率时显示该信息,例如1000M等
当用户配置了duplex auto时显示该信息
link duplex type is force link
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
接口允许通过的最大以太网帧长度
允许长帧通过
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
PVID
接口所在的缺省VLAN ID
MDI type
网线类型,取值为automdix、mdi或mdix,与用户的配置有关
Port link-type
链路类型,取值为access、trunk或hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN)
VLAN permitted
接口允许通过的VLAN报文
Trunk port encapsulation
Trunk接口的封装格式
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
如果值显示为“-”,则表示不支持该统计项
Input(total):  0 packets, 0 bytes
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input(normal):  0 packets, 0 bytes
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧
giants
接收到的超大帧的数量
超大帧是指有效长度大于端口允许通过最大报文长度的帧:
·     对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧
·     对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧
throttles
接收到的长度为非整数字节的帧的个数
CRC
接收到的CRC校验错误、长度正常的帧的数量
frame
接收到的CRC校验错误、且长度不是整字节数的帧的数量
overruns
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃
aborts
接收到的非法报文总数,非法报文包括:
·     报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧
·     jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧
·     符号错误帧:报文中至少包含1个错误的符号
·     操作码未知帧:报文是MAC控制帧,但不是Pause帧
·     长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配
ignored
由于端口接收缓冲区不足等原因而丢弃的报文数量
parity errors
接收到的奇偶校验错误的帧的数量
Output(total): 0 packets, 0 bytes
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output(normal): 0 packets, 0 bytes
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
output errors
各种发送错误的报文总数
underruns
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败
deferred
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
collisions
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
late collisions
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
lost carrier
载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
no carrier
无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
Peak input rate
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Peak output rate
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
你好,那几种错包在物理环境中,是什么原因产生的可以大概知道吗
椰奶怪 发表时间:2021-07-28
粉丝:124人 关注:6人
参考举例和说明如下:
1.1.10  display interface
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
如果不指定接口类型和接口编号,则显示除VA(Virtual Access,虚拟访问)接口外的所有接口的信息。有关VA接口的详细介绍,请参见“二层技术-广域网接入配置指导”中的“PPP”。
# 查看三层以太网接口GigabitEthernet1/0/1的运行状态和相关信息。
<Sysname> display interface gigabitethernet 1/0/1
Description: GigabitEthernet1/0/1 Interface
Multicast max-ratio: 100%
Media type: Twisted pair, loopback: Not set, promiscuous mode: Not set
1000Mbps-speed mode, full-duplex mode
Flow-control: Disabled
Port priority: 0
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Current system time:2017-12-09 10:46:24
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-09 10:25:30
# 查看二层以太网接口GigabitEthernet1/0/1的运行状态和相关信息。
Current state: DOWN
Loopback is not set
PVID: 1
MDI type: Automdix
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Current system time:2017-12-09 10:59:08
Last time when physical state changed to down:2017-12-09 10:59:07
接口GigabitEthernet1/0/1的相关信息
Current state
接口的物理状态,状态可能为:
·     ETH-rddc Shutdown:表示该接口被冗余组模块关闭,即接口状态为冗余关闭
Line protocol state
·     UP:表示数据链路层协议状态为开启
The peer line protocol state is DOWN(Bit-error down)
远端接口发生误码故障,其链路层协议状态置为关闭
本端接口收到远端接口误码故障消息时显示本字段
Link quality grade
链路质量等级:
·     GOOD:链路质量优。误码率未达到高误码率门限或者误码率从大于等于高误码率门限回落到小于低误码率门限时,显示为GOOD
·     LOW:链路质量差。误码率达到高误码率门门限时,链路质量显示为LOW
未配置link-quality crc-error bit-error-ratio命令时,不显示本字段
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
Internet address: ip-address/mask-length (Type)
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     PPP-negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“二层技术-广域网接入配置指导”中的“PPP”
·     Unnumbered:借用其他接口的IP地址
·     Cellular-allocated:通过Modem私有协议获取的IP地址,详细介绍请参见“二层技术-广域网接入配置指导”中的“移动通信Modem管理”
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF”
·     MTunnel:组播隧道接口的IP地址(采用的是MD源接口的IP地址),关于MD源接口的详细介绍请参见“IP组播配置指导”中的“组播VPN”
Type的取值情况与接口类型有关,请以实际情况为准
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
接口的硬件类型
输出队列中——紧急队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
输出队列中——协议队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
输出队列中——FIFO队列的信息:队列中当前缓存的报文的个数/队列最多可缓存的报文个数/队列已丢弃的报文的个数
Port priority
接口优先级
Loopback is not set
10Mbps-speed mode
100Mbps-speed mode
1000Mbps-speed mode
10Gbps-speed mode
Unknown-speed mode
half-duplex mode
接口工作在半双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
full-duplex mode
unknown-duplex mode
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关‌
接口允许通过的最大以太网帧长度
允许长帧通过
Broadcast max-
Multicast max-
Unicast max-
PVID
接口所在的缺省VLAN ID
MDI type
Port link-type
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
VLAN permitted
接口允许通过的VLAN报文
Trunk接口的封装格式
Last link flapping
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,时间显示格式为YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS
最近一次接口物理状态变为UP的时刻
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
giants
接收到的超大帧的数量
throttles
接收到的长度为非整数字节的帧的个数
CRC
frame
overruns
aborts
接收到的非法报文总数,非法报文包括:
ignored
parity errors
接收到的奇偶校验错误的帧的数量
output errors
各种发送错误的报文总数
underruns
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Peak input rate
Peak output rate
粉丝:145人 关注:1人
简单准确的答题:
参考如下:
output errors
各种发送错误的报文总数
underruns
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Peak input rate
Peak output rate
椰奶怪 发表时间:2021-07-28
回复椰奶怪:
多半是物理连接问题
叫我靓仔 发表时间:2021-07-28
