H3C路由器策略路由不生效
2018-06-19提问
  • 1收藏,5307浏览
 从VPN路由器访问核心下面的PC机,策略路由不生效?
VPN与核心交换机存在2条链路,经过防火墙的那条作为主链路,与核心直连的这条作为备用链路,当主链路出现故障,切换到备用链路。
生产环境VPN与FW之间只开启了RIP协议。。。。
  1. 问题描述:因VPN路由器到核心存在直连路由192.168.70.0/24. 服务器(PC)假设地址为192.178.70.253,从VPN路由器访问核心下面的PC机,策略路由不生效?通过抓包看还是通过直连路由发往核心?
  2. 配置文件如下:
  • [VPN]dis current-configuration
 version 7.1.075, Alpha 7571
 sysname vpn
rip 1
 version 2
 network 10.0.0.0
 network 192.168.104.0
 network 192.168.105.0
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
policy-based-route VLan700 permit node 10
 if-match acl 3000
 apply next-hop 10.1.0.221
policy-based-route vlan700 permit node 10
nqa entry admin test
 type icmp-echo
  destination ip 10.1.0.221
  frequency 100
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only
 nqa schedule admin test start-time now lifetime forever
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface LoopBack0
 ip address 192.168.105.254 255.255.255.0
interface LoopBack1
 ip address 192.168.104.254 255.255.255.0
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 10.1.0.222 255.255.255.252
 rip 1 enable
interface GigabitEthernet0/1
 combo enable copper
 ip address 192.168.70.252 255.255.255.0
 ip policy-based-route VLan700
interface GigabitEthernet0/2
 combo enable copper
interface GigabitEthernet5/0
 combo enable copper
interface GigabitEthernet5/1
 combo enable copper
interface GigabitEthernet6/0
 combo enable copper
interface GigabitEthernet6/1
 combo enable copper
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 172.16.0.0 16 192.168.70.254 preference 150
 ip route-static 192.168.70.0 24 10.1.0.221 track 1 preference 50
acl advanced 3000
 rule 5 permit ip destination 192.168.70.0 0.0.0.255
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
 track 1 nqa entry admin test reaction 1
return
你试试配置ip local policy-based-route VLan700
 或者你VPN路由器下联一个电脑,以下边电脑的报文做测试,应该没有问题的。当前的0/1口有点相当于本地的发出的报文
你好,我是在VPN路由器下的0/1口上应用的PBR, 同时我在VPN路由器下面接一个电脑,测试发现去往核心的流量还是走直连路由,没有经过防火墙; 但是回来的包却经过防火墙。
zhiliao_bFxfc 发表时间:2018-06-20
zhiliao_bFxfc 知了小白
@哼哼哈嘿,你好,我是在VPN路由器下的0/1口上应用的PBR,
但是回来的包却经过防火墙。
