WA5530胖AP掉线
2021-07-30提问
  • 1收藏,928浏览
WA5530胖模式,客户端使用***.***网站测速,点开始后无线掉线
%Jul 29 16:52:07:879 2021 test STAMGR/6/STAMGR_CLIENT_OFFLINE: Client b283-9b18-a0b1 went offline from BSS 48bd-3d61-6a70 with SSID xuanwu on AP fatap Radio ID 1. State changed to Unauth. Reason: Received disassociation frame in Run state: reason code=8 %Jul 29 16:52:09:821 2021 test STAMGR/6/STAMGR_CLIENT_ONLINE: Client b283-9b18-a0b1 went online from BSS 48bd-3d61-6a70 vlan 1 with SSID xuanwu on AP fatap Radio ID 1. State changed to Run. %Jul 29 16:52:10:061 2021 test STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: b283-9b18-a0b1, IP: 192.168.2.12, -NA-, -NA-, -NA-, Username: -NA-, AP name: fatap, Radio ID: 1, Channel number: 44, SSID: xuanwu, BSSID: 48bd-3d61-6a70.
显示为code8
debug wlan client结果如下:
<test>*Jul 29 16:52:44:857 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received deauthentication or disassociation request from client in Run state: Reason code=8. *Jul 29 16:52:44:858 2021 test STAMGR/7/PktRcv: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received disassociation frame with the reason code 8 in Run state. *Jul 29 16:52:44:858 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Can't send delete mobile message to uplink device: Reached the end of the IOCTL tunnel. *Jul 29 16:52:44:858 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Sent delete mobile message to downlink device. *Jul 29 16:52:44:858 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Sent delete mobile message to downlink device successfully. *Jul 29 16:52:44:858 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [State: 3, Offline type: 0, Delete type: 0, UP delete type: 0] Processing station delete event. *Jul 29 16:52:44:874 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The mac address of client need to be added or deleted. %Jul 29 16:52:44:876 2021 test STAMGR/6/STAMGR_CLIENT_OFFLINE: Client b283-9b18-a0b1 went offline from BSS 48bd-3d61-6a70 with SSID xuanwu on AP fatap Radio ID 1. State changed to Unauth. Reason: Received disassociation frame in Run state: reason code=8 *Jul 29 16:52:44:874 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [IFIndex: 11, VLAN ID: 1] Delete the mac address of client successfully. *Jul 29 16:52:44:875 2021 test STAMGR/7/Timer: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Deleted the keep alive timer when receive deactive sta. *Jul 29 16:52:44:876 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Changed the client's state from Run to Unauth. *Jul 29 16:52:44:876 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Downlink delete mobile message callback. *Jul 29 16:52:46:815 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The Sta had exist when proc auth request. *Jul 29 16:52:46:815 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received authentication request in the Unauth state. *Jul 29 16:52:46:816 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Processed authentication request successfully, and sent authentication response. *Jul 29 16:52:46:816 2021 test STAMGR/7/Timer: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Created state timer. *Jul 29 16:52:46:816 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Changed the client's state from Unauth to Auth. *Jul 29 16:52:46:817 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received association request in the Auth state. *Jul 29 16:52:46:817 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Client state: Auth. *Jul 29 16:52:46:818 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Checking (re)association load of the device. *Jul 29 16:52:46:818 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Processing fields and IE in the (re)association request. *Jul 29 16:52:46:819 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Proccess association request without pmk caching in auth state. *Jul 29 16:52:46:819 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Processed (re)association request successfully when the client was in Auth state. *Jul 29 16:52:46:819 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Processed (re)association request successfully, and sent (re)association response. *Jul 29 16:52:46:821 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Sent add mobile message to downlink device successfully. *Jul 29 16:52:46:821 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] AC doesn't need to send client information to uplink device:Client information already arrived at the end of the IOCTL tunnel. *Jul 29 16:52:46:822 2021 test STAMGR/7/Timer: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Deleted state timer. *Jul 29 16:52:46:822 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received add mobile response message from downlink device. *Jul 29 16:52:46:822 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Changed the client's state from Auth to Userauth. *Jul 29 16:52:46:822 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [Sent association flag: 1] Process association response before start userauth. *Jul 29 16:52:46:823 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The forwarding mode of client has been set local. *Jul 29 16:52:46:824 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The forwarding mode of client has been set local. *Jul 29 16:52:46:824 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The forwarding mode of client has been set local. *Jul 29 16:52:46:955 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Sent add mobile message to downlink device successfully. *Jul 29 16:52:46:956 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] AC doesn't need to send client information to uplink device:Client information already arrived at the end of the IOCTL tunnel. *Jul 29 16:52:46:958 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The forwarding mode of client has been set local. *Jul 29 16:52:46:960 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [IFIndex: 11, VLAN ID: 1] Add new mac address successfully. *Jul 29 16:52:46:962 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] The mac address of client need to be added or deleted. *Jul 29 16:52:46:963 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [VLAN ID 1] Add vlan to BSS interface successfully. *Jul 29 16:52:46:968 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Sent add mobile message to downlink device successfully. *Jul 29 16:52:46:970 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] AC doesn't need to send client information to uplink device:Client information already arrived at the end of the IOCTL tunnel. *Jul 29 16:52:46:970 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Changed the client's state from Userauth to Run. %Jul 29 16:52:46:972 2021 test STAMGR/6/STAMGR_CLIENT_ONLINE: Client b283-9b18-a0b1 went online from BSS 48bd-3d61-6a70 vlan 1 with SSID xuanwu on AP fatap Radio ID 1. State changed to Run. *Jul 29 16:52:47:029 2021 test STAMGR/7/Timer: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Created keep-alive timer. *Jul 29 16:52:47:030 2021 test STAMGR/7/Timer: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Created idle timer. *Jul 29 16:52:47:089 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received add mobile response message from downlink device. *Jul 29 16:52:47:090 2021 test STAMGR/7/Event: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] Received add mobile response message from downlink device. *Jul 29 16:52:47:093 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [Category: 3] Received action in the Run state. *Jul 29 16:52:47:217 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [Category: 3] Received action in the Run state. %Jul 29 16:52:47:283 2021 test STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: b283-9b18-a0b1, IP: 192.168.2.12, -NA-, -NA-, -NA-, Username: -NA-, AP name: fatap, Radio ID: 1, Channel number: 44, SSID: xuanwu, BSSID: 48bd-3d61-6a70. *Jul 29 16:52:47:764 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [Category: 3] Received action in the Run state. *Jul 29 16:52:50:634 2021 test STAMGR/7/FSM: [APID: 1] [MAC: b283-9b18-a0b1, BSSID: 48bd-3d61-6a70] [Category: 3] Received action in the Run state. undo debugging all
设备当前版本
H3C Comware Software, Version 7.1.064, Release 2444P01 Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved. H3C WA5530 uptime is 0 weeks, 0 days, 0 hours, 50 minutes Last reboot reason : Power on Boot image: flash:/wa5300-fat-boot.bin Boot image version: 7.1.064, Release 2444P01 Compiled Jun 04 2021 16:00:00 System image: flash:/wa5300-fat-system.bin System image version: 7.1.064, Release 2444P01 Compiled Jun 04 2021 16:00:00 with 1 ARM 710MHz Processor 512M bytes DDR3 4M bytes NorFlash Memory 128M bytes NandFlash Memory Hardware Version is Ver.A Basic Bootrom Version is 7.27 Extend Bootrom Version is 7.27 [Subslot 0]H3C WA5530 Hardware Version is Ver.A [SLOT 1]GE1/0/1 (Hardware)Ver.A, (Driver)1.0 [SLOT 1]GE1/0/2 (Hardware)Ver.A, (Driver)1.0 [SLOT 1]RADIO1/0/1 (Hardware)Ver.A, (Driver)1.0 [SLOT 1]RADIO1/0/2 (Hardware)Ver.A, (Driver)1.0 [SLOT 1]RADIO1/0/3 (Hardware)Ver.A, (Driver)1.0
粉丝:23人 关注:2人
看着下线原因是终端主动下线。选择不加密的服务试一下,另外可以多找几个终端试试。
测试了 一样掉线
zhiliao_16SA7 发表时间:2021-07-30
目前发现安卓的终端都掉线,只要流量一大就掉了
回复zhiliao_16SA7:
可以关注一下ap的cpu和内存值是否正常,看一下是否测速时,ap上所有终端同时掉线。
爱吃胡萝卜 发表时间:2021-07-30
粉丝:17人 关注:5人
有一个还是多个AP?
是都有问题吗,还是个别的。
可以多找几个终端测试下,也可以设置无线不加密,免密码连接。
也可以升级下胖AP的版本,升级到最新的版本,
目前已经是最新版本了
粉丝:39人 关注:7人
无线网络不稳定,以下是优化要点,请参考:
1、调整功率和信道。
2、有线网络和无线网络使用不同的VLAN来实现广播域上的隔离。
3、关闭低速率的协议。
4、确保DHCP内的地址池空间足够使用。
5、升级无线设备的软件版本到最新。
6、做好无线网络接入的安全设置,避免非法终端接入。
