整体网络的交换机都是cisco的(核心和接入),生成树是默认的PVST,现在要增加几台H3C的接入交换机,单路直连核心的,请问接入交换机的生成树可以直接使用PVST吗?还有什么配置需要特殊调整吗?
2021-08-02提问
  • 1收藏,1264浏览
H3C接入交换机与cisco核心互联是否可以使用PVST
粉丝:39人 关注:7人
使用PVST即可。以下是对接案例,请参考:
本案例使用S12508与思科3560对接PVST的典型组网配置案例,S12508-1为主根,同时也部署了VRRP,其中S12508-1为VRRP的master,S12508-2为VRRP的backup,为了进一步防止物理环路,因此在S12508与思科3560部署PVST。
S12508版本信息如下:
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1828P05
Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S12508 uptime is 57 weeks, 5 days, 7 hours, 43 minutes
Last reboot reason : User reboot
思科3560版本信息如下:
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000,>
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
WAI-F7-XZC-1 uptime is 30 weeks, 6 days, 9 hours, 47 minutes
System returned to ROM by power-on
System restarted at 23:07:18 china Sun Oct 20 2019
System image file is "flash:c3560-ipservices-mz.122-35.SE5/c3560-ipservices-mz.122-35.SE5.bin"
cisco WS-C3560G-48TS (PowerPC405) processor (revision F0) with 122880K/8184K bytes of memory.
Processor board ID FOC1442Z4FZ
Last reset from power-on
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : B4:14:89:E7:D1:80
Motherboard assembly number     : 73-10214-06
Power supply part number        : 341-0107-01
Motherboard serial number       : FOC14425UBW
Power supply serial number      : AZS143501S4
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C3560G-48TS-E
System serial number            : FOC1442Z4FZ
Top Assembly Part Number        : 800-27479-03
Top Assembly Revision Number    : A0
Version ID                      : V05
CLEI Code Number                : COMBG10BRA
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   52     WS-C3560G-48TS     12.2(35)SE5             C3560-IPSERVICES-M
Configuration register is 0xF
配置步骤
S12508-1的MAC如下(使用lldp查看):
  Chassis ID         : 7425-8ade-a600
  System name        : Internet_S12508A
  System description : H3C Comware software. H3C S12508 Product Version S12500-CMW520-R1828P05. Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
S12508-2的MAC如下(使用lldp查看):
  Chassis ID         : 70f9-6df4-8a00
  System name        : Internet_S12508B
S12508-1配置如下:
stp mode pvst
 stp pathcost-standard dot1d-1998
 stp vlan 1 4 13 16 19 28 37 64 to 65 72 110 to 112 root primary
 stp vlan 120 to 121 131 140 to 141 150 to 151 160 to 161 170 to 171 180 to 181 190 to 191 200 to 201 210 to 211 root primary
 stp vlan 220 to 221 311 to 316 330 to 331 400 411 to 422 root primary
 stp enable
S12508-2配置如下:
stp mode pvst
 stp instance 0 root secondary
 stp vlan 120 to 121 140 to 141 150 to 151 160 to 161 170 to 171 180 to 181 190 to 191 200 to 201 210 to 211 220 to 221 root secondary
 stp vlan 311 to 316 330 to 331 411 to 422 root secondary
 stp enable
思科3560配置如下:
查看S12508-1的STP根信息:
dis stp root
 VLAN  Root Bridge ID        ExtPathCost IntPathCost Root Port
    1  0.7425-8ade-a600      0           0
    4  0.7425-8ade-a600      0           0
   28  0.7425-8ade-a600      0           0
   37  0.7425-8ade-a600      0           0
   64  0.7425-8ade-a600      0           0
   65  0.7425-8ade-a600      0           0
   72  0.7425-8ade-a600      0           0
  110  0.7425-8ade-a600      0           0
  111  0.7425-8ade-a600      0           0
  112  0.7425-8ade-a600      0           0
  120  0.7425-8ade-a600      0           0
  121  0.7425-8ade-a600      0           0
  131  0.7425-8ade-a600      0           0
  140  0.7425-8ade-a600      0           0
  141  0.7425-8ade-a600      0           0
  150  0.7425-8ade-a600      0           0
  151  0.7425-8ade-a600      0           0
  160  0.7425-8ade-a600      0           0
  161  0.7425-8ade-a600      0           0
  170  0.7425-8ade-a600      0           0
  171  0.7425-8ade-a600      0           0
  180  0.7425-8ade-a600      0           0
  181  0.7425-8ade-a600      0           0
  190  0.7425-8ade-a600      0           0
  191  0.7425-8ade-a600      0           0
  200  0.7425-8ade-a600      0           0
  201  0.7425-8ade-a600      0           0
  210  0.7425-8ade-a600      0           0
  211  0.7425-8ade-a600      0           0
  220  0.7425-8ade-a600      0           0
  221  0.7425-8ade-a600      0           0
  311  0.7425-8ade-a600      0           0
  312  0.7425-8ade-a600      0           0
  313  0.7425-8ade-a600      0           0
  314  0.7425-8ade-a600      0           0
  315  0.7425-8ade-a600      0           0
  316  0.7425-8ade-a600      0           0
  330  0.7425-8ade-a600      0           0
  331  0.7425-8ade-a600      0           0
  400  0.7425-8ade-a600      0           0
  411  0.7425-8ade-a600      0           0
  412  0.7425-8ade-a600      0           0
  413  0.7425-8ade-a600      0           0
  414  0.7425-8ade-a600      0           0
  415  0.7425-8ade-a600      0           0
  416  0.7425-8ade-a600      0           0
  417  0.7425-8ade-a600      0           0
  418  0.7425-8ade-a600      0           0
  419  0.7425-8ade-a600      0           0
  420  0.7425-8ade-a600      0           0
  421  0.7425-8ade-a600      0           0
  422  0.7425-8ade-a600      0           0
  555  32768.7425-8ade-a600  0           0
  901  32768.7425-8ade-a600  0           0
  902  32768.7425-8ade-a600  0           0
  998  32768.70f9-6df4-8a00  0           2           Bridge-Aggregation1
  999  32768.7425-8ade-a600  0           0
查看S12508-2的STP根信息:
dis stp root
    1  0.7425-8ade-a600      0           2           Bridge-Aggregation1
    4  0.7425-8ade-a600      0           2           Bridge-Aggregation1
   28  0.7425-8ade-a600      0           2           Bridge-Aggregation1
   37  0.7425-8ade-a600      0           2           Bridge-Aggregation1
   64  0.7425-8ade-a600      0           2           Bridge-Aggregation1
   65  0.7425-8ade-a600      0           2           Bridge-Aggregation1
   72  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  110  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  111  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  112  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  120  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  121  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  140  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  141  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  150  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  151  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  160  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  161  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  170  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  171  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  180  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  181  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  190  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  191  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  200  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  201  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  210  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  211  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  220  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  221  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  311  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  312  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  313  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  314  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  315  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  316  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  330  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  331  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  400  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  411  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  412  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  413  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  414  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  415  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  416  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  417  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  418  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  419  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  420  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  421  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  422  0.7425-8ade-a600      0           2           Bridge-Aggregation1
  555  32768.70f9-6df4-8a00  0           0
  900  32768.70f9-6df4-8a00  0           0
  903  32768.70f9-6df4-8a00  0           0
  998  32768.70f9-6df4-8a00  0           0
查看思科3560的STP根信息:
sh spanning-tree root
                                        Root    Hello Max Fwd
Vlan                   Root ID          Cost    Time  Age Dly  Root Port
VLAN0064            64 7425.8ade.a600         4    2   20  15  Gi0/48
VLAN0170           170 7425.8ade.a600         4    2   20  15  Gi0/48
VLAN0400           400 7425.8ade.a600         4    2   20  15  Gi0/48
查看思科3560 STP端口状态信息:
sh spanning-tree detail active
 VLAN0064 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 64, address b414.89e7.d180
  Configured hello time 2, max age 20, forward delay 15
  Current root has priority 64, address 7425.8ade.a600
  Root port is 48 (GigabitEthernet0/48), cost of root path is 4
  Topology change flag not set, detected flag not set
  Number of topology changes 82 last change occurred 2w1d ago
          from GigabitEthernet0/47
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
 Port 46 (GigabitEthernet0/46) of VLAN0064 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.46.
   Designated root has priority 64, address 7425.8ade.a600
   Designated bridge has priority 32832, address b414.89e7.d180
   Designated port id is 128.46, designated path cost 4
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   BPDU: sent 5251132, received 428
 Port 47 (GigabitEthernet0/47) of VLAN0064 is blocking
   Port path cost 4, Port priority 128, Port Identifier 128.47.
   Designated bridge has priority 32832, address 70f9.6df4.8a00
   Designated port id is 128.115, designated path cost 2
   Timers: message age 2, forward delay 0, hold 0
   Number of transitions to forwarding state: 13
   BPDU: sent 1250, received 7696996
 Port 48 (GigabitEthernet0/48) of VLAN0064 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.48.
   Designated bridge has priority 64, address 7425.8ade.a600
   Designated port id is 128.115, designated path cost 0
   Timers: message age 3, forward delay 0, hold 0
   Number of transitions to forwarding state: 7
   BPDU: sent 278, received 1624711
 VLAN0170 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 170, address b414.89e7.d180
  Current root has priority 170, address 7425.8ade.a600
  Number of topology changes 5566 last change occurred 16:28:31 ago
          from GigabitEthernet0/46
 Port 16 (GigabitEthernet0/16) of VLAN0170 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.16.
   Designated root has priority 170, address 7425.8ade.a600
   Designated bridge has priority 32938, address b414.89e7.d180
   Designated port id is 128.16, designated path cost 4
   BPDU: sent 257292, received 0
 Port 32 (GigabitEthernet0/32) of VLAN0170 is forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.32.
   Designated port id is 128.32, designated path cost 4
   BPDU: sent 1492843, received 0
 Port 46 (GigabitEthernet0/46) of VLAN0170 is forwarding
   BPDU: sent 4708774, received 5847
 Port 47 (GigabitEthernet0/47) of VLAN0170 is blocking
   Designated bridge has priority 4266, address 70f9.6df4.8a00
   Number of transitions to forwarding state: 4
   BPDU: sent 7225, received 6590908
 Port 48 (GigabitEthernet0/48) of VLAN0170 is forwarding
   Designated bridge has priority 170, address 7425.8ade.a600
   Timers: message age 1, forward delay 0, hold 0
   BPDU: sent 2182, received 1590312
 VLAN0400 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 400, address b414.89e7.d180
  Current root has priority 400, address 7425.8ade.a600
  Number of topology changes 79 last change occurred 2w1d ago
 Port 46 (GigabitEthernet0/46) of VLAN0400 is forwarding
   Designated root has priority 400, address 7425.8ade.a600
   Designated bridge has priority 33168, address b414.89e7.d180
   BPDU: sent 4707169, received 423
 Port 47 (GigabitEthernet0/47) of VLAN0400 is blocking
   Designated bridge has priority 33168, address 70f9.6df4.8a00
   Number of transitions to forwarding state: 10
   BPDU: sent 1214, received 6602570
 Port 48 (GigabitEthernet0/48) of VLAN0400 is forwarding
   Designated bridge has priority 400, address 7425.8ade.a600
   Number of transitions to forwarding state: 8
   BPDU: sent 262, received 1601135
至此,S12508与思科3560 PVST对接的典型组网配置案例已完成!
粉丝:154人 关注:1人
直接PVST就可以,标准协议,兼容的
