服务器~核心交换机~普通接入路由器~外网,可以把服务器端口映射出去外网吗?
2021-08-11提问
  • 1收藏,999浏览
粉丝:0人 关注:2人
接入路由器上开了dhcp服务,核心上怎么配置?让核心可以上网
另外路由器上需要怎么设置映射?
粉丝:39人 关注:7人
可以。
在路由器上映射即可,以下是参考命令:
[R1]acl basic 2000
[R1-acl-ipv4-basic-2000]rule 0 permit source any
[R1-acl-ipv4-basic-2000]quit
[R1]int gi 0/1
[R1-GigabitEthernet0/1]description <connect to WAN>
[R1-GigabitEthernet0/1]ip address 192.168.200.254 24
[R1-GigabitEthernet0/1]nat outbound 2000
[R1-GigabitEthernet0/1]nat server protocol tcp global 192.168.200.102 80 inside 10.0.0.1 80
[R1-GigabitEthernet0/1]nat server protocol tcp global 192.168.200.102 443 inside 10.0.0.1 443
[R1-GigabitEthernet0/1]quit
[R1]ip route-static 0.0.0.0 0.0.0.0 192.168.200.1
以下是核心配置DHCP的参考命令:
[H3C]sysname SW1
在交换机分别创建VLAN 10、VLAN 20:
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
VLAN 10的IP设置为:192.168.10.1 255.255.255.0:
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
VLAN 20的IP设置为:192.168.20.1 255.255.255.0:
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 192.168.20.1 24
[SW1-Vlan-interface20]quit
将GI1/0/1端口划分到VLAN 10:
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 10
[SW1-GigabitEthernet1/0/1]quit
将GI1/0/2端口划分到VLAN 20:
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 20
[SW1-GigabitEthernet1/0/2]quit
开启DHCP功能:
[SW1]dhcp enable
创建DHCP地址池,命名为VLAN10,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan10]quit
[SW1]
创建DHCP地址池,命名为VLAN20,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan20
[SW1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[SW1-dhcp-pool-vlan20]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan20]quit
最后做好核心与路由器的三层互联及路由发布或指向。
