SecPath U200-M和ER5200 G2组IPSEC VPN,ER会自动掉线
2018-06-22提问
  • 1收藏,1396浏览
惠州是总部,用的是U200-M,分支为深圳和杭州,都是用的ER5200 G2,深圳那边会自动掉线,请帮忙看下是哪里出问题了。谢谢!
总部-U200-M配置(这里有另一端杭州的配置,因为设备都是ER5200G2,深圳用的是主模式,杭州用的是野蛮模式):
 ike local-name huizhou
 acl number 3080
 description ipsec vpn to shenzhen
 rule 10 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.80.0 0.0.0.255
 rule 20 permit ip source 192.168.20.0 0.0.0.255 destination 192.168.80.0 0.0.0.255
acl number 3090
 description ipsec vpn to hangzhou
 rule 10 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.90.0 0.0.0.255
 rule 20 permit ip source 192.168.20.0 0.0.0.255 destination 192.168.90.0 0.0.0.255
 rule 40 permit ip source 192.168.40.0 0.0.0.255 destination 192.168.90.0 0.0.0.255
ike dpd 1
ike peer hangzhou
 exchange-mode aggressive
 pre-shared-key cipher +MGS6bX9XT8=
 id-type name
 remote-name hangzhou
 local-address x.x.x.x
 dpd 1
ike peer shenzhen
 remote-name shenzhen
 remote-address  x.x.x.x
 dpd 1
ipsec proposal 1
ipsec policy center 80 isakmp
 security acl 3080
 ike-peer shenzhen
 proposal 1
ipsec policy center 90 isakmp
 security acl 3090
 ike-peer hangzhou
 proposal 1
interface GigabitEthernet0/1
 port link-mode route
 description this port is link to China Telecom's Fiber Converter
 nat outbound 3003
 ip address  x.x.x.x
 ipsec policy center
[U200-M]dis ike dpd 1
 IKE dpd: 1
   references: 2
   interval-time: 10
   time_out: 5
[U200-M]dis ipsec prop
[U200-M]dis ipsec proposal 1
  IPsec proposal name: 1
    encapsulation mode: tunnel
    transform: esp-new
    ESP protocol: authentication md5-hmac-96, encryption des
[U200-M]dis ike sa
    total phase-1 SAs:  2
    connection-id  peer            flag        phase   doi
     1197          x.x.x.x   RD            1     IPSEC
     1209           x.x.x.x   RD            2     IPSEC
     1206           x.x.x.x     RD            1     IPSEC
     1211          x.x.x.x   RD            2     IPSEC
     1210          x.x.x.x   RD            2     IPSEC
     1213           x.x.x.x    RD            2     IPSEC
     1212           x.x.x.x     RD            2     IPSEC
  flag meaning
  RD--READY ST--STAYALIVE RL--REPLACED FD--FADING TO--TIMEOUT
[U200-M]dis ipsec sa
Interface: GigabitEthernet0/1
    path MTU: 1500
  IPsec policy name: "center"
  sequence number: 80
  mode: isakmp
    connection id: 196
    perfect forward secrecy: None
    tunnel:
        local  address:  x.x.x.x
        remote address:  x.x.x.x
    Flow :
        sour addr: 192.168.10.0/255.255.255.0  port: 0  protocol: IP
        dest addr: 192.168.80.0/255.255.255.0  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 3507750634 (0xd11406ea)
      proposal: ESP-ENCRYPT-DES ESP-AUTH-MD5
      sa duration (kilobytes/sec): 1843200/3600
      sa remaining duration (kilobytes/sec): 1834492/1172
      max received sequence-number: 69472
      anti-replay check enable: Y
      anti-replay window size: 32
      udp encapsulation used for nat traversal: N
    [outbound ESP SAs]
      spi: 225714323 (0xd742093)
      sa remaining duration (kilobytes/sec): 1827372/1172
      max sent sequence-number: 67963
  sequence number: 80
  mode: isakmp
    connection id: 197
    tunnel:
    Flow :
        sour addr: 192.168.20.0/255.255.255.0  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 2216410771 (0x841bbe93)
      sa remaining duration (kilobytes/sec): 1841773/1171
      max received sequence-number: 19092
    [outbound ESP SAs]
      spi: 225714322 (0xd742092)
      sa remaining duration (kilobytes/sec): 1842075/1171
      max sent sequence-number: 16857
  sequence number: 90
  mode: isakmp
    connection id: 200
    tunnel:
    Flow :
        dest addr: 192.168.90.0/255.255.255.0  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 1592023955 (0x5ee45b93)
      sa remaining duration (kilobytes/sec): 1838075/768
      max received sequence-number: 11495
    [outbound ESP SAs]
      spi: 2753749697 (0xa422e2c1)
      sa remaining duration (kilobytes/sec): 1839310/768
      max sent sequence-number: 10837
  sequence number: 90
  mode: isakmp
    connection id: 198
    tunnel:
    Flow :
    [inbound ESP SAs]
      spi: 1051300980 (0x3ea99474)
      sa remaining duration (kilobytes/sec): 1841206/768
      max received sequence-number: 21289
    [outbound ESP SAs]
      spi: 2753749698 (0xa422e2c2)
      sa remaining duration (kilobytes/sec): 1842476/768
      max sent sequence-number: 14214
  sequence number: 90
  mode: isakmp
    connection id: 199
    tunnel:
    Flow :
        sour addr: 192.168.40.0/255.255.255.0  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 2005175563 (0x77848d0b)
      sa remaining duration (kilobytes/sec): 1842861/768
      max received sequence-number: 5376
    [outbound ESP SAs]
      spi: 2753749696 (0xa422e2c0)
      sa remaining duration (kilobytes/sec): 1842865/768
      max sent sequence-number: 5348
[U200-M]
分支深圳的配置(会自动断):
断的时候,log有日志吗?有没有类似dpd检测失败断开的日志?从配置上看不出来什么问题,这个大概多上时间会复现一次?自己就会好吗?
有日志的,一个是DPD超时,隧道断开,一个是发送PAYLOAD_MALFORMED通告信息,一个是收到IPSEC_RESPONDER_LIFETIME消息载荷;不固定的,大概7、8个小时左右,断的时候丢包8个,丢完包会自动重连成功
zhiliao_64770 发表时间:2018-06-22
