WA4320-ACN-SI-FIT
2018-06-22提问
  • 1收藏,1234浏览
WA4320-ACN-SI-FIT用Console口登录设备后到这里了Press ENTER to get started.按ENTER 键没反应
余sir 八段
粉丝:25人 关注:0人
注册在线的吗?在线的需要开启AP 登录开关。 如果不在线的,每8分钟就重启。
好像是有在重启的 这是配置 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing......................Done! **************************************************************************** * * * H3C WA4320-ACN-SI BootWare, Version 1.04 * * * **************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Mar 18 2016 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin!.......... ............................................................................ ................................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .....................................................................Done! System application is starting... Startup configuration file does not exist. User interface con0 is available. Press ENTER to get started.
哈午夜 发表时间:2018-06-22
粉丝:4人 关注:0人
AP再重启下,看命令行有没有那些开启设备的信息出现
这是配置,能麻烦您看一下吗 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing......................Done! **************************************************************************** * * * H3C WA4320-ACN-SI BootWare, Version 1.04 * * * **************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Mar 18 2016 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin!.......... ............................................................................ ................................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .....................................................................Done! System application is starting... Startup configuration file does not exist. User interface con0 is available. Press ENTER to get started.
哈午夜 发表时间:2018-06-22
这个就正常啊 回车下,页可以断开跟上层连接的网络单独看下
我有一本苏 发表时间:2018-06-22
就是按回车键没反应,不知道什么情况
哈午夜 发表时间:2018-06-22
回复哈午夜:
所以要断开上层连接看下
我有一本苏 发表时间:2018-06-25
fywr 九段
粉丝:49人 关注:3人
查看下电脑串口配置是否正确,默认波特率9600
这些正确的
哈午夜 发表时间:2018-06-22
