WA4320-ACN-SI-FIT
2018-06-22提问
  • 1收藏,1309浏览
我的AP是开机信息是这样的System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing......................Done! **************************************************************************** * * * H3C WA4320-ACN-SI BootWare, Version 1.04 * * * **************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Mar 18 2016 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin!.......... ............................................................................ ................................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .....................................................................Done! System application is starting... User interface con0 is available. Press ENTER to get started.  请问家用怎么配置 我是小白一枚 麻烦说详细一点消息
粉丝:15人 关注:0人
WA4320-ACN-SI这种定位是企业AP,家用NAT或拨号可能会有问题,建议桥接到路由,关闭AP的dhcp功能,胖模式登录地址192.168.0.50    账号 admin/h3capadmin
请问是将vlan1的ip设置为192.168.0.50 255.255.255.0然后添加账号和密码了之后通过家用的无线路由器转网线进来就可以了吗
哈午夜 发表时间:2018-06-22
对了 为什么设备会老是自动重启呢
哈午夜 发表时间:2018-06-22
skylar 九段
粉丝:42人 关注:0人
这是启动完成了,已经提示你了Press ENTER to get started。按回车就可以了
嗯 这个我明白 我就是不知道需要怎么设置 信息您啊
哈午夜 发表时间:2018-06-22
