wa5530-fit
2021-08-17提问
  • 1收藏,976浏览
我的这台ap要换成单台ap使用的模式,我该怎么去调试和管理?
粉丝:95人 关注:1人
https://www.h3c.com/cn/d_202107/1422878_30005_40.htm 固件下载地址
方法一、AP瘦切胖配置方法(BootROM菜单下)
提示:升级过程中请勿断电,操作不当断电会引起设备故障,请谨慎操作。
1、先从官方下载WA4320-ACN-E的升级包
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/H3C_WA4300S/
账号:yx800
密码:01230123
2、使用3CDaemon软件搭建FTP服务(3CDaemon文件压缩包已经上传)
3、用Console线连接设备并启动,显示Ctrl+B时按住Ctrl+B并按回车并进入BootROM菜单
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Ctrl+F: Format File System
Enter your choice(0-9):
4、按住Ctrl+F并将设备进行格式化,释放空间
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................
............. Format success.
5、输入“3”,进入以太网子菜单
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 3
5、输入“3”,进行修改以太网参数
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-3): 3
6、选择TFTP、上传的文件名称、server地址(本机地址)、Local地址(随便输入只要是一个网段的即可)
==========================<ETHERNET PARAMETER SET>==========================
|Note: "." = Clear field. |
|          "-" = Go to previous field. |
|           Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
 Load File Name :wa4300s_art.bin
                            :wa4300s_fat.bin
Target File Name :target
                            :wa4300s_fat.bin
Server IP Address :192.168.1.254
 Local IP Address :192.168.1.2
 Gateway IP Address :0.0.0.0
7、输入“2”进行更新主应用程序
Enter your choice(0-3): 2
Loading.........................................................
...................................................................... ..Done!
11293696 bytes downloaded!
Updating File flash:/wa4300s_fat.bin...................................
.........................................................Done!
8、输入“0”,退出以太网子菜单
Enter your choice(0-3): 0
9、输入“0”重启设备即可引导上传的fat程序
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 0
System is starting...
方法二、AP瘦切胖配置方法(命令行模式下)
1、使用3CDaemon软件搭建FTP服务(3CDaemon文件压缩包已经上传)
2、先删除原有的fit版本,释放设备内存空间
<WA4320-ACN-E>delete /unreserved wa4300s_fit.bin
The contents cannot be restored!!! Delete flash:/wa4300s_fit.bin?[Y/N]:y
Deleting a file permanently will take a long time. Please wait... ........
configuration state.................Delete file flash:/wa4300s_fit.bin...Done.
3、给AP配置IP地址,保证能和本机(Server)通信
<WA4320-ACN-E>sys
[WA4320-ACN-E] int vlan1
 [WA4320-ACN-E-Vlan-interface1] ip add 192.168.1.2 24
 [WA4320-ACN-E-Vlan-interface1] quit
 [WA4320-ACN-E] quit
 <WA4320-ACN-E>
4、上传fat版本到AP中,并查询保证已经上传到本机
<WA4320-ACN-E>tftp 192.168.1.254 get wa4300s_fat.bin
   File will be transferred in binary mode
   Downloading file from remote TFTP server, please wait.............|
   configuration state...................................
   TFTP: 11293696 bytes received in 94 second(s)
   File downloaded successfully.
<WA4320-ACN-E>dir           #查询当前目录下的所有文件
Directory of flash:/
    0          -rw-      11293696      Apr     26     2000     12:36:11     wa4300s_fat.bin
 15057     KB     total     (4026 KB     free)
 <WA4320-ACN-E>
5、指定系统启动文件为“wa4300s_fat.bin”,设备会自动重启并引导“wa4300s_fat.bin”文件
 <WA4320-ACN-E>boot-loader file flash:/wa4300s_fat.bin
 Verifying boot file ...... This command will set the boot file. Continue? [Y/N]:y
 The specified file will be used as the boot file at the next reboot on slot 1!
6、进入系统后查询是否引导的是”wa4300s_fat.bin“文件,如果是则已转成胖AP
<WA4320-ACN-E>display boot-loader
 The current boot app is: flash:/wa4300s_fat.bin
 The app that will boot upon reboot is: flash:/wa4300s_fat.bin
(推荐用户使用3CDaemon搭建TFTP服务器)
将软件版本下载到设备FLASH内,然后通过命令行加载Bootrom版本,再加载主机软件版本,加载时输入的文件名一定要一致,建议复制黏贴,然后升级过程中避免断电重启操作。
具体操作如下:
1) 从新华三的官网下载对应AP型号的胖版本,下载到电脑后,需修改文件名,以WAP621为例子,修改对应的启动文件名wa2600a_fat.bin,需要注意文件名称修改正确。
AP型号和使用版本关系:
AP-mode
版本名称
H3C WAP621
wa2600a_fat.bin
H3C WAP722
wa4300_fat.bin
H3C WAP722E
H3C WAP722S
wa4300s_fat.bin
H3C WAP712C
H3C WAP712H
2)  电脑网卡设置为:192.168.0.1/255.255.255.0 ,如下例子打开TFTP服务器,把软件版本WA2600a_fat.bin放到电脑桌面上,TFTP服务器目录指向电脑桌面,然后点击确定。
3) 创建APip地址,AP设置地址为192.168.0.2 255.255.255.0,和电脑同一个网段,保证电脑和AP网络可达。以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
<H3C> system
   [H3C] interface vlan1
   [H3C-Vlan-interface1] ip address 192.168.0.2 255.255.255.0
   [H3C-Vlan-interface1] quit
4) 通过TFTP上传胖APwa2620a_fat.bin192.168.0.1是电脑的ip
 <H3C> tftp 192.168.0.1 get wa2600a_fat.bin
  File will be transferred in binary mode.
  Downloading file from remote tftp server, please wait........................................................................................................................
  TFTP:  4602950 bytes received in 115 second(s).
备注:如果提示FLASH空间不足已放下新版本请将老版本删除,删除后请勿重启,否则设备已无系统,只能通过bootrom升级。
<H3C>delete /unreserved wa2600a_fit.bin
 //如果空间不够,可以删除原有的软件版本释放存储空间
5) 加载BOOTROM
<H3C> bootrom update file wa2600a_fat.btm(此步忽略)
please wait ...
Bootrom is updated!
6) 加载主机软件
<H3C> boot-loader file wa2600a_fat.bin main
<H3C> reboot
7) 重启设备完成后就可以使用默认的管理地址192.168.0.50登录AP进行管理了。登录AP的默认用户名是admin,密码是h3capadmin
1.1.2  AP瘦切胖配置案例(Bootrom
1) 使用Console口登入到命令行,从官网下载WAP621的软件版本,将压缩包解压,将里面的文件名称修改为wa2600a_fat.bin。
2) 电脑网卡设置为:192.168.0.1 255.255.255.0,如下例子打开TFTP服务器,把软件版本WA2600a_fat.bin放到电脑桌面上,TFTP服务器目录指向电脑桌面,然后点击确定。
3) AP重启的时候按住Ctrl+B进入设备的bootroom菜单,以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
|<1> Boot System
|<4> File Control
|<0> Reboot
Enter your choice(0-9): Ctrl+F
y
Enter your choice(0-9): 3(此处输入)
|<3> Update Backup Application File
|<4> Update Secure Application File
|<5> Modify Ethernet Parameter
4) 进入修改以太网参数菜单,使用TFTP网络协议传输wa2600a_fat.binAP
Enter your choice(0-5): 5
|          Ctrl+D = Quit.
Protocol (FTP or TFTP) : TFTP
//忽略输出内容,直接输入TFTP,然后回车
Load File Name         :wa2600a_fat.bin
//忽略输出内容,直接输入wa2600a_fat.bin,然后回车
Target File Name       :wa2600a_fat.bin
Server IP Address      :192.168.0.1
//忽略输出内容,直接输入电脑主机的 IP,比如192.168.0.1,然后回车
Local IP Address       :192.168.0.50
//忽略输出内容,直接输入和电脑主机的ip同一网段,比如192.168.0.50,然后回车
//忽略输出内容,直接回车
备注:注意给电脑手动配置一个与AP同网段的IP地址,保证电脑与AP路由可达
Enter your choice(0-5): 2   //此时可以看到TFTP服务器上数据上传的滚动
Loading.....................................................................
5) 返回主菜单,查看设备上是否真的已经上传了该软件版本
Enter your choice(0-5): 0
<1> Boot System
<4> File Control
<0>Reboot        ==========================================================
Enter your choice(0-9): 4
=====================<File CONTROL>===============================
<1> Display All File(s)
<2> Set Application File type
<3> Delete File
Enter your choice(0-3): 1
Display all file(s) in flash:
"M" = MAIN      "B" = BACKUP      "S" = SECURE      "N/A" = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name
||1   9124864   Aug/08/2008 20:00:00 M      wa2600a_fat.bin
6) 返回主菜单,将设备进行重启
<3> Delete File
<1> Boot System
<4> File Control
<0>Reboot        ==================================================================
下载的文件里面没有BIN格式,求指导一下,谢谢合法性
zhiliao_Og9IO8 发表时间:2021-08-17
(39.85 MB)这个下载出来解压不就是bin文件了,看下版本说明书,谢谢
李云龙的意大利炮 发表时间:2021-08-17
解压后只有一个BTW和IPE
zhiliao_Og9IO8 知了小白
我找不到相关软件和资料,能给我发一下吗?6714139@qq.com谢谢您
直接点击刚才的链接下载就行, 用户名:yx800 密码:01230123
今天吃啥 发表时间:2021-08-17
好的,谢谢您
粉丝:39人 关注:7人
以下是瘦切胖的案例:
https://zhiliao.h3c.com/Theme/details/74007
以下是FAT AP配置要点:
 1、创建VLAN,用于业务使用。举例:
vlan 10
2、再创建VLAN,用于管理使用。举例:
vlan 100  //创建vlan 100
management-vlan 100  //将VLAN 100设置为管理vlan
int vlan 100
ip address 10.1.1.1 24  //给vlan 100设置ip地址,后续可使用10.1.1.1远程登陆管理
3、配置有线接口,用于接入网络,举例:
int gi 1/0/1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 10 100
4、配置默认路由:
ip route-static 0.0.0.0 0.0.0.0 10.1.1.254
5、配置WLAN虚拟接入端口,用于无线移动终端的接入:
int wlan-bss 1
port link-type access
port access vlan 10
6、配置无线模板
wlan service-template 1 clear  //创建服务模板1
authentication-method open-system //无认证
ssid h3c //配置SSID
service-template enable //启用无线服务模板
7、配置射频接口,类似于配置天线
int wlan-radio 1/0/1  //进入射频接口1/0/1
service-template 1 interface wlan-bss 1  //调用服务模板1及wlan虚拟接入端口
radio-type dotllg  //配置AP在802.11g模式
channel 11  //配置射频接口使用信道11
max-power 15  //配置射频接口的最大功率是15dBm
WA5530如何 配制管理WEB地址,谢谢
