h3c wx3024e +wa4320-acn iperf3测速慢 ,协商速度很快
2021-08-18提问
  • 1收藏,1334浏览
二台mac本,都通过wifi接入,协商速度都是800Mbps,都支持802.11AC
但是内网传输文件确很慢,只有90Mbps
为了验证这个情况
server: iperf3 -s (插有线)
client : iperf3 -c serverip -t 100 (无线,协商速度800Mbps)
最终只有180Mbps
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
 version 5.20, Release 3509P48
 sysname ac
 domain default enable system
 telnet server enable
 lldp enable
 port-security enable
 oap management-ip 192.168.0.101 slot 0
 wlan client learn-ipaddr enable
 wlan auto-ap enable
 wlan auto-persistent enable
 password-recovery enable
vlan 1
vlan 2 to 4
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$/oeH1gTdu9OsEjl6LGZG6mimiQgoZbkz
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
 band-navigation enable
 dot11a spectrum-analysis enable
 dot11a calibrate-channel sensitivity high
 dot11a calibrate-channel track spectrum-analysis
wlan service-template 1 crypto
 ssid zenki
 bind WLAN-ESS 0
 cipher-suite ccmp
 security-ie rsn
 service-template enable
wlan service-template 2 crypto
 ssid zenki-2.4G
 bind WLAN-ESS 1
 cipher-suite ccmp
 security-ie rsn
wlan service-template 3 crypto
 ssid zenki-google
 bind WLAN-ESS 2
 cipher-suite ccmp
 security-ie rsn
wlan ap-group default_group
 ap ap1
 ap ap2
 ap ap3
 ap ap4
 ap ap5
interface Bridge-Aggregation1
 port link-type trunk
 port trunk permit vlan all
interface NULL0
interface Vlan-interface1
 ip address 11.11.1.3 255.255.255.0
interface Vlan-interface3
 port link-aggregation group 1
interface WLAN-ESS0
 port link-type hybrid
 port hybrid vlan 1 untagged
 mac-vlan enable
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$qQOZ8n3Sn9p/oDCblC4pptU8OvTDXwjiEiHPhA==
interface WLAN-ESS1
 mac-vlan enable
 port-security preshared-key pass-phrase cipher $c$3$SwqQYUAcvTbb/dXJu+JLcnP8RDN1WHQUhEz27w==
interface WLAN-ESS2
 undo port hybrid vlan 1
 port hybrid vlan 4 untagged
 port hybrid pvid vlan 4
 mac-vlan enable
 port-security preshared-key pass-phrase cipher $c$3$gm+gytW4+Ld7Bsr26VfdtZb+3ozVJUnVIdByIg==
interface WLAN-ESS3
 port hybrid vlan 1 to 2 untagged
 port hybrid pvid vlan 2
 mac-vlan enable
 port-security preshared-key pass-phrase cipher $c$3$H/aAq/YkQJxqtnXGpeFfzndveQ0bXVjcIBPCig==
interface WLAN-ESS4
wlan ap ap1 model WA4320i-ACN id 1
 serial-id 210235A1GPC176001264
 radio 1
  max-power 5
  service-template 1
  service-template 3
  mimo 2x2
  radio enable
 radio 2
  max-power 4
  service-template 2
  service-template 3
  mimo 2x2
  radio enable
wlan ap ap2 model WA4320i-ACN id 2
 serial-id 210235A1GPC178000498
 radio 1
  max-power 5
  service-template 1
  service-template 3
  mimo 2x2
  radio enable
 radio 2
  max-power 4
  service-template 2
  service-template 3
  mimo 2x2
  radio enable
wlan ap ap3 model WA4320-ACN id 3
 serial-id 210235A1GTC185001074
 radio 1
  max-power 4
  service-template 1
  service-template 3
  mimo 2x2
  radio enable
 radio 2
  max-power 4
  service-template 2
  service-template 3
  green-energy-management enable
  mimo 2x2
  radio enable
wlan ap ap4 model WA4320-ACN id 4
 serial-id 210235A1GTC183000735
 country-code CN
 radio 1
  max-power 4
  service-template 1
  service-template 3
  mimo 2x2
  radio enable
 radio 2
  max-power 3
  service-template 2
  service-template 3
  radio enable
wlan ap ap5 model WA4320-ACN id 5
 serial-id 210235A1GTC185000135
 radio 1
  max-power 5
  service-template 1
  service-template 3
  mimo 2x2
  radio enable
 radio 2
  max-power 4
  service-template 2
  service-template 3
  mimo 2x2
  radio enable
wlan ips
 malformed-detect-policy default
 signature deauth_flood signature-id 1
 signature broadcast_deauth_flood signature-id 2
 signature disassoc_flood signature-id 3
 signature broadcast_disassoc_flood signature-id 4
 signature eapol_logoff_flood signature-id 5
 signature eap_success_flood signature-id 6
 signature eap_failure_flood signature-id 7
 signature pspoll_flood signature-id 8
 signature cts_flood signature-id 9
 signature rts_flood signature-id 10
 signature addba_req_flood signature-id 11
 signature-policy default
 countermeasure-policy default
 attack-detect-policy default
 virtual-security-domain default
 ip route-static 0.0.0.0 0.0.0.0 11.11.1.1
 ssh server enable
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 protocol inbound ssh
return
建议wlan rrm里的配置清除,2.4G信道建议选1,6,11指定,减少信道干扰,如果ap较。无线速度受环境干扰影响很大,建议手动进行调优,不要使用自动调优功能。
和这个无关。周围 没有干扰
周小龙 发表时间:2021-08-18
周小龙 知了小白
1. 求大家不要在说2.4的问题,首先,我们只用5G,不用2.4G,配置中有2.4G是给一些无法连5G的用,2.4G慢。无所谓
2. 不要说干扰问题,这个回答,就像网吧网官说,关机重启是答案
问题不管你什么Ap,现在强烈怀疑是WA4320-acn的问题,我在baidu上,基本上没有搜索到有上过200Mbps的。
有线和无关之间传输才180Mbps,问题在这里。
