wap712c 瘦转胖一直报错不成功,请求帮忙,非常感谢!
2021-08-25提问
  • 1收藏,723浏览
****************************************************************************** * Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.* * Without the owner's prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ****************************************************************************** Line con0 is available. Press ENTER to get started. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing................................. Done! **************************************************************************** * * * H3C WAP712C BootWare, Version 7.14 * * * **************************************************************************** Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. Compiled Date : Oct 15 2018 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main boot and system image files... Loading file flash:/wa4300s-system.bin...................................... ............................................................................ ............................................................................ ....................................................................Done. Loading file flash:/wa4300s-boot.bin........................................ ..........................Done. Image file flash:/wa4300s-boot.bin is self-decompressing.................... ............................................................................ ............................................................................ ................................Done. System image is starting... Startup configuration file does not exist. Line con0 is available. Press ENTER to get started. <H3C>%Aug 24 11:04:25:469 2021 H3C SHELL/5/SHELL_LOGIN: Console logged in from c on0. <H3C>system System View: return to User View with Ctrl+Z. [H3C] <H3C>system System View: return to User View with Ctrl+Z. [H3C] <H3C>info ^ % Unrecognized command found at '^' position. <H3C> <H3C> <H3C>system System View: return to User View with Ctrl+Z. [H3C] <H3C>system System View: return to User View with Ctrl+Z. [H3C]system ^ % Unrecognized command found at '^' position. [H3C] System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing................................. Done! **************************************************************************** * * * H3C WAP712C BootWare, Version 7.14 * * * **************************************************************************** Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. Compiled Date : Oct 15 2018 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 4 ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Image File type | |<3> Set Bin File type | |<4> Set Configuration File type | |<5> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-5): 1 Display all file(s) in flash: 'M' = MAIN 'B' = BACKUP 'N/A' = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | |1 10923008 Aug/08/2008 20:00:00 M flash:/wa4300s-system.bin | |2 2657280 Aug/08/2008 20:00:00 M flash:/wa4300s-boot.bin | ============================================================================ ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Image File type | |<3> Set Bin File type | |<4> Set Configuration File type | |<5> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-5): 0 ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y..... ............................................................................ .................. Format success. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): Please select the new mode Current mode is Fit ============================================================================ |NO. Mode | |1 Oasis Mode | |2 Fit Mode | |0 Exit | ============================================================================ Enter your choice(0-2):1 flash:/wa4300h-oasis.bin image does not exist. Changed to Oasis mode failed! ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 0 ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :wa4300s_fat.bin : Target File Name :wa4300s_fat.bin : Server IP Address :192.168.1.1 192.168.0.2 Local IP Address :192.168.1.253 192.168.0.50 Subnet Mask :0.0.0.0 Gateway IP Address :0.0.0.0 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading..................................................................... ............................................................................ ............................................................................ ..Done. 11293696 bytes downloaded! Saving file flash:/wa4300s_fat.bin ......................................... ............................................................................ ...........................................................Done. Set the file attribute failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 0 ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Enter your choice(0-9): 0 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing................................. Done! **************************************************************************** * * * H3C WAP712C BootWare, Version 7.14 * * * **************************************************************************** Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. Compiled Date : Oct 15 2018 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Booting image fails! Trying to get the IP address from the DHCP server...... Getting IP Address Failed, the system will reboot. [State : Idle] Reset re System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing................................. Done!
镜像好像刷不进去  启动无镜像文件,请求帮助,谢谢!
winter 九段
粉丝:50人 关注:18人
可以对比这个案例看下操作步骤是否有错误。https://zhiliao.h3c.com/Theme/details/45609
粉丝:39人 关注:7人
The image does not exist! 没有镜像文件,以下是排查要点,请参考:
1、检查确认导入的固件是否适配。
2、确认设备的存储空间足够存放固件。
3、以下是瘦切胖的案例,请参考:
https://zhiliao.h3c.com/Theme/details/74007
zhiliao_3eiE4 知了小白
真的是按步骤一步一步来的,固件地址下载的,也格式化了,但就是不成功
谁能帮忙我  看能不能帮忙远程,谢谢!
一样的问题
