MSG360-10 -连接wifi后一直会断
  • 1收藏,949浏览
旁挂模式,很奇怪,现场没看过,只是帮客户重置下AC管理,客户密码忘记了
重置后,就会出现wifi已经连接,实际断开。检查配置都是对的
是wifi太远了,还是干扰太大。怎么去排除啊
客户电脑一直 断开网络,是ap部署的密度不够吗?
报告
Client 3220-9d39-7de9 went offline from BSS 7057-bf8e-5d52 with SSID vip on AP 7057-bf8e-5d40. State changed to Unauth. Reason:Successfully roamed to another BSS.
2021-08-26 20:02:57
报告
Detected client IP change: Client MAC: 3220-9d39-7de9, IP: 192.168.20.3, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-68e0, Radio ID: 1, Channel number: 149, SSID: vip, BSSID: 7057-bf8e-68e2.
2021-08-26 20:02:57
报告
Client 3220-9d39-7de9 roamed from BSSID 7057-bf8e-5d52 on AP 7057-bf8e-5d40 of AC IP 127.0.0.1 to BSSID 7057-bf8e-68e2 on AP 7057-bf8e-68e0 of AC IP 127.0.0.1 successfully.
2021-08-26 20:02:57
报告
Client 3220-9d39-7de9 went online from BSS 7057-bf8e-68e2 with SSID vip on AP 7057-bf8e-68e0. State changed to Run.
2021-08-26 20:02:57
报告
Detected client IP change: Client MAC: 16fa-a6ae-0c39, IP: 192.168.20.122, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-5d40, Radio ID: 2, Channel number: 7, SSID: vip, BSSID: 7057-bf8e-5d52.
2021-08-26 20:02:55
报告
Client 16fa-a6ae-0c39 roamed from BSSID 7057-bf8e-60b2 on AP 7057-bf8e-60a0 of AC IP 127.0.0.1 to BSSID 7057-bf8e-5d52 on AP 7057-bf8e-5d40 of AC IP 127.0.0.1 successfully.
2021-08-26 20:02:55
报告
Client 16fa-a6ae-0c39 went offline from BSS 7057-bf8e-60b2 with SSID vip on AP 7057-bf8e-60a0. State changed to Unauth. Reason:Successfully roamed to another BSS.
2021-08-26 20:02:55
报告
Client 16fa-a6ae-0c39 went online from BSS 7057-bf8e-5d52 with SSID vip on AP 7057-bf8e-5d40. State changed to Run.
2021-08-26 20:02:55
报告
Detected client IP change: Client MAC: 2064-cb0c-77a3, IP: 192.168.20.134, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-68e0, Radio ID: 2, Channel number: 11, SSID: vip, BSSID: 7057-bf8e-68f2.
2021-08-26 20:02:38
报告
Client 2064-cb0c-77a3 roamed from BSSID 7057-bf8e-6072 on AP 7057-bf8e-6060 of AC IP 127.0.0.1 to BSSID 7057-bf8e-68f2 on AP 7057-bf8e-68e0 of AC IP 127.0.0.1 successfully.
2021-08-26 20:02:38
报告
Client 2064-cb0c-77a3 went offline from BSS 7057-bf8e-6072 with SSID vip on AP 7057-bf8e-6060. State changed to Unauth. Reason:Successfully roamed to another BSS.
2021-08-26 20:02:38
报告
Client 2064-cb0c-77a3 went online from BSS 7057-bf8e-68f2 with SSID vip on AP 7057-bf8e-68e0. State changed to Run.
2021-08-26 20:02:38
报告
Detected client IP change: Client MAC: 30b4-9e7d-70d3, IP: 192.168.20.9, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-5d40, Radio ID: 2, Channel number: 7, SSID: vip, BSSID: 7057-bf8e-5d52.
2021-08-26 20:02:21
报告
Client 30b4-9e7d-70d3 went online from BSS 7057-bf8e-5d52 with SSID vip on AP 7057-bf8e-5d40. State changed to Run.
2021-08-26 20:02:21
报告
Client 30b4-9e7d-70d3 went offline from BSS 7057-bf8e-5d52 with SSID vip on AP 7057-bf8e-5d40. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=6
2021-08-26 20:02:21
报告
Detected client IP change: Client MAC: 2064-cb0c-77a3, IP: 192.168.20.134, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-6060, Radio ID: 2, Channel number: 8, SSID: vip, BSSID: 7057-bf8e-6072.
2021-08-26 20:02:12
报告
Client 2064-cb0c-77a3 roamed from BSSID 7057-bf8e-5d52 on AP 7057-bf8e-5d40 of AC IP 127.0.0.1 to BSSID 7057-bf8e-6072 on AP 7057-bf8e-6060 of AC IP 127.0.0.1 successfully.
2021-08-26 20:02:12
报告
Client 2064-cb0c-77a3 went offline from BSS 7057-bf8e-5d52 with SSID vip on AP 7057-bf8e-5d40. State changed to Unauth. Reason:Successfully roamed to another BSS.
2021-08-26 20:02:12
报告
Client 2064-cb0c-77a3 went online from BSS 7057-bf8e-6072 with SSID vip on AP 7057-bf8e-6060. State changed to Run.
2021-08-26 20:02:12
报告
Detected client IP change: Client MAC: d6d0-83c2-335b, IP: 192.168.20.24, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-61a0, Radio ID: 2, Channel number: 4, SSID: vip, BSSID: 7057-bf8e-61b2.
2021-08-26 20:02:02
报告
Client d6d0-83c2-335b went online from BSS 7057-bf8e-61b2 with SSID vip on AP 7057-bf8e-61a0. State changed to Run.
2021-08-26 20:02:02
报告
Client 30b4-9e7d-70d6 went offline from BSS 7057-bf8e-5811 with SSID Office on AP 7057-bf8e-5800. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=8
2021-08-26 20:01:11
报告
Detected client IP change: Client MAC: 58c6-f025-93df, IP: 192.168.20.23, -NA-, -NA-, -NA-, Username: -NA-, AP name: 7057-bf8e-6300, Radio ID: 2, Channel number: 9, SSID: vip, BSSID: 7057-bf8e-6312.
2021-08-26 19:58:57
报告
Client 58c6-f025-93df roamed from BSSID 7057-bf8e-5812 on AP 7057-bf8e-5800 of AC IP 127.0.0.1 to BSSID 7057-bf8e-6312 on AP 7057-bf8e-6300 of AC IP 127.0.0.1 successfully.
2021-08-26 19:58:57
设备型号 MSG360-10 序列号 219801A0WBC193000686 Boot版本 1.16 硬件版本 Ver.B 软件版本 7.1.064, Release 5231 基线版本 Release 5231 MAC信息 74-EA-CB-AF-D8-00
粉丝:19人 关注:3人
下线原因不都是漫游了么,这样应该是会有一个下线上线的过程,丢几个包是正常的,如果一直连不上尝试优化一下吧
粉丝:39人 关注:7人
无线网络不稳定,以下是优化要点,请参考:
1、调整功率和信道。
2、有线网络和无线网络使用不同的VLAN来实现广播域上的隔离。
3、关闭低速率的协议。
4、检查上行物理链路、基础网络是否正常。
5、升级无线设备的软件版本到最新。
6、做好无线网络接入的安全设置,避免非法终端接入。
