无线网络漫游问题
2021-09-03提问
  • 1收藏,2478浏览
场景:一个办公室里面装了两个AP,型号:一个5320,一个4320。两个AP的信道已经做过优化。
问题:现在5320AP连接的终端数有30个,4320连接的终端数只有5个。
做了终端与AP的距离测试,即使终端与4320距离更近,但终端还是会连接到5320.
下面是测试终端的部份连接日志:
Session for a MAC authentication user was terminated.Reason:Received client offline message with reason code=3121
Client 30b4-XXXX-4d69 went offline from BSS 1cab-XXXX-1bb0 with SSID XXXX on AP 1cab-XXXX-1ba0 Radio ID 2. State changed to Unauth. Reason:AP triggered (kick station by fast keep alive).
Session for a MAC authentication user was terminated.Reason:Received client offline message with reason code=1040.
 Client 30b4-XXXX-4d69 went offline from BSS 1cab-XXXX-1bb0 with SSID XXXX on AP 1cab-XXXX-1ba0 Radio ID 2. State changed to Unauth. Reason: Successfully roamed to another BSS.
 STAMGR_MACA_LOGOFF: -Username=XXXX-UserMAC=XXXX-BSSID=882a-XXXX-0690-SSID=XXXX-APName=882a-XXXX-0680-RadioID=2-VLANID=1908-UsernameFormat=MAC address; Session for a MAC authentication user was terminated.Reason:Received client offline message with reason code=1022
请问会是什么原因?
lqlqlq 九段
粉丝:21人 关注:19人
可以降低5320功率,提高4320功率
粉丝:11人 关注:0人
AP一个射频正常带20多个,你这30个带机数也正常。在信号强度差不多,是由终端来选取连接哪个无线的。如果要两个ap带机量差不多,可以调整ap的功率,设置弱信号拒绝接入,限制单射频带机量等来设置。
和AP型号没关吗?因为在同一办公室,两个AP信号强度应该差不多啊?
zhiliao_YjRor 发表时间:2021-09-03
回复zhiliao_YjRor:
性能上应该也是有差别的,一个53的,一个43的。
红烧牛肉面 发表时间:2021-09-03
