原来设置了portal认证
时长是一个星期左右
就是某个账号认证后 一个星期内上网都是免认证的
现在想把这个时长增加到一个月
在命令行是怎么配置
原配置如下
设置列表
对齐方式
# version 7.1.064, Customer 5423P05 # sysname WX3508H # clock protocol none # wlan global-configuration # irf mac-address persistent timer irf auto-update enable irf auto-merge enable irf member 1 priority 1 # dhcp enable # password-recovery enable # vlan 1 # vlan 200 # vlan 210 # vlan 220 # vlan 230 # irf-port 1 # dhcp server ip-pool vlan210 gateway-list 172.16.210.253 network 172.16.210.0 mask 255.255.255.0 # dhcp server ip-pool vlan220 gateway-list 172.16.220.254 network 172.16.220.0 mask 255.255.254.0 dns-list 114.114.114.114 180.76.76.76 expired day 0 hour 8 # dhcp server ip-pool vlan230 gateway-list 172.16.230.254 network 172.16.230.0 mask 255.255.255.0 dns-list 114.114.114.114 180.76.76.76 expired day 0 hour 8 # wlan service-template zhxx ssid zhxx vlan 220 client forwarding-location ap vlan 220 akm mode psk preshared-key pass-phrase cipher $c$3$mYyywfcqNZD7aC2fExm3TH59lezipRi70Gq4S7Lv cipher-suite ccmp security-ie rsn portal enable method direct portal domain portal portal apply web-server portal portal apply mac-trigger-server portal service-template enable # wlan service-template zhxx_guest ssid zhxx_guest vlan 230 client max-count 50 client forwarding-location ap vlan 230 akm mode psk preshared-key pass-phrase cipher $c$3$aD50iREKsbxytcr018vJJMfp2R3bbsfH/esBzIkw cipher-suite ccmp security-ie rsn service-template enable # interface NULL0 # interface Vlan-interface200 description switch_manage ip address 172.16.200.253 255.255.255.0 # interface Vlan-interface210 description ap_manage ip address 172.16.210.253 255.255.255.0 # interface Vlan-interface220 description wifi_yewu ip address 172.16.220.253 255.255.254.0 # interface Vlan-interface230 description wifi_fangke ip address 172.16.230.253 255.255.255.0 # interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 210 # interface GigabitEthernet1/0/2 port link-mode bridge # interface GigabitEthernet1/0/3 port link-mode bridge # interface GigabitEthernet1/0/4 port link-mode bridge # interface GigabitEthernet1/0/5 port link-mode bridge # interface GigabitEthernet1/0/6 port link-mode bridge # interface GigabitEthernet1/0/7 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 200 210 220 230 # interface GigabitEthernet1/0/8 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 200 210 220 230 # scheduler logfile size 16 # line class console user-role network-admin # line class vty user-role network-operator # line con 0 user-role network-admin # line vty 0 31 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 172.16.210.254 # undo info-center enable undo info-center logfile enable # ssh server enable # domain portal authorization-attribute idle-cut 15 1024 accounting start-fail offline authentication portal local authorization portal local accounting portal local # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$ZM073mjEJ+i5aZDS$4o4dfyznVmh1so1xCx3bSn8LcIOD1lJSQDQ6TcsXHCy3+4GbOYynckUtYc8BdO2FMPUcs7pIBOOtenxF4nQ+KQ== service-type ssh terminal https authorization-attribute user-role level-15 authorization-attribute user-role network-admin # local-user caibian class network password cipher $c$3$45kbm+s76qvzP8QjoWHCEoVSaqspDH3J6PovWr4V access-limit 2 service-type portal authorization-attribute user-role network-operator description 蔡 扁 # local-user caojianhui class network password cipher $c$3$Wd9scCMGX33Y0pzkx+nSGI0zDATlRiGcBksrVgC7 access-limit 2 service-type portal authorization-attribute user-role network-operator description 曹建辉 # local-user chengjianyu class network password cipher $c$3$gne01ptURf2vDnk16QJQN0adgsommPdYCYrD8Eqx access-limit 2 service-type portal authorization-attribute user-role network-operator description 成健瑜 # local-user chenguangling class network password cipher $c$3$9ObLzIakdl/Zc7ysNqfqc/dEXdVmO3PYRCbwOv5c access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈广玲 # local-user chenhuaguang class network password cipher $c$3$CETPvbukelnT1NjTfKwxprybrEsuWkeKYNJGas1e access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈华广 # local-user chenjianzhen class network password cipher $c$3$F+vzx2lcRuCIHXtZlZhDmnj55d6U8Gs2N32IS0/n access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈坚贞 # local-user chenjunling class network password cipher $c$3$pTh6eRTipHggdpr9N3WTJNnjyEts0GBU8eBkv8o1 access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈俊玲 # local-user chenlin class network password cipher $c$3$d2fq+7xvb1MvStXpIe5GorACScZmKdz8pINBO6sz access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈 琳 # local-user chenliying class network password cipher $c$3$/ifkCA/yTokRZPUSJaZ3MvrgIBNvCwITY7YIETnf access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈礼英 # local-user chenshuixiang class network password cipher $c$3$5Vcx/YT5aAfJ/SosP5Ol0VZ6JPeZ6nnJeCbFcAqa access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈水湘 # local-user chenxiufeng class network password cipher $c$3$BB2mPpKWad3S9eRqlXlUKYgqO6dMzkbXeEbBapbU service-type portal authorization-attribute user-role network-operator description 陈秀凤 # local-user chenyonghua class network password cipher $c$3$/PHkmZw6xt/j6OUO9YFVkLnFA6A3tOD4OMRFYp73 access-limit 2 service-type portal authorization-attribute user-role network-operator description 陈永华 # local-user dailie class network password cipher $c$3$sZVyTSa3bpsXrj+zw9fI7uUodORU70YKDtecsafN access-limit 2 service-type portal authorization-attribute user-role network-operator description 戴丽娥 # local-user denghongxia class network password cipher $c$3$39Zh6aYRxRt/i90GnapxQ4bASxl5sOtOSi6v3YNF access-limit 2 service-type portal authorization-attribute user-role network-operator description 邓红霞 # local-user dengjiewen class network password cipher $c$3$GDvKoNMZv4DJ5DSQyPBOFksi0lBBcs7R1s3ul/gK access-limit 2 service-type portal authorization-attribute user-role network-operator description 邓洁雯 # local-user dengshunxiu class network password cipher $c$3$L/9Uhm9w8BVLzcuW60x++H/RsGlv5Iwlkg6aWqVd access-limit 2 service-type portal authorization-attribute user-role network-operator description 邓顺秀 # local-user fanyiming class network password cipher $c$3$keZMEDZhibMD2gcQu3mtTyzflsxub/XzkU/S56d1 access-limit 2 service-type portal authorization-attribute user-role network-operator description 范一鸣 # local-user fengchuyu class network password cipher $c$3$0nz6bcIr8GybKK+ifNZ/haa0Eb5wPGdci2bS41en access-limit 2 service-type portal authorization-attribute user-role network-operator description 冯楚瑜 # local-user gaohui class network password cipher $c$3$fmrMhaorZEFxjaCrePgAFlj8kNXL06whnB9MPlic access-limit 2 service-type portal authorization-attribute user-role network-operator description 高 卉 # local-user gongwenqing class network password cipher $c$3$35oLu4jIYDHic9Oyz1FqkyUeNdZVkKrN3nlMUCMS access-limit 2 service-type portal authorization-attribute user-role network-operator description 龚温情 # local-user gongxiaofang class network password cipher $c$3$iNnSJFV/DXN+Vtcm/n5u/Fkv4NYfd0J4/0Aw3QK6 access-limit 2 service-type portal authorization-attribute user-role network-operator description 龚小芳 # local-user gushixin class network password cipher $c$3$PwFqY8S9zHkDphrA38aOQnoFvBU475uxmNdT+4d0 access-limit 2 service-type portal authorization-attribute user-role network-operator description 顾诗欣 # local-user h3c class network password cipher $c$3$SOCeZJovpWDG1iMqHS+quNPGeW4TeA== access-limit 2 service-type portal authorization-attribute user-role network-operator description h3c测试 # local-user hejunye class network password cipher $c$3$FHpxdS98PhfEkfc93U/tyilW/+gas8pmxkgx6InL access-limit 2 service-type portal authorization-attribute user-role network-operator description 何俊烨 # local-user hk class network password cipher $c$3$4JhozUj0vgTNNCljzxrU1Xt77BgE+5vbludhtKI= access-limit 5 service-type portal authorization-attribute user-role network-operator description 管理 # local-user huangaijiao class network password cipher $c$3$Kn6WlrEJcqM/Esme0EvLFVfyWIuSEDJOAdvDEV7y access-limit 2 service-type portal authorization-attribute user-role network-operator description 黄爱娇 # local-user huangfanglan class network password cipher $c$3$70b4AeBp9veohgN0RS3qnzudE1gBPJESbm5b4wvQ access-limit 2 service-type portal authorization-attribute user-role network-operator description 黄芳兰 # local-user huanglimei class network password cipher $c$3$PPz2k5ZhOkf3RzoY9DpQIkKtSFh9YsuhAX5k9VpS access-limit 2 service-type portal authorization-attribute user-role network-operator description 黄利梅 # local-user huangluying class network password cipher $c$3$RfvJSFafuGrz3EzdV+et82y/7RDxJt911kvpar6W access-limit 2 service-type portal authorization-attribute user-role network-operator description 黄璐盈 # local-user huangminchun class network password cipher $c$3$XFmP6yF82UWH0p3M2tvdWImNgT9PgBU0oPUsrYJR access-limit 2 service-type portal authorization-attribute user-role network-operator description 黄敏纯 # local-user huhuihua class network password cipher $c$3$IQjRXLYxTpwj0r3d6KZ2U1NJfHpTgWAJzt6rUFHg access-limit 2 service-type portal authorization-attribute user-role network-operator description 胡慧华 # local-user jiangmandi class network password cipher $c$3$CWcudXGfWtEcbsekZHS+cF0Dj4sMqT3eaQ5jG5Wx access-limit 2 service-type portal authorization-attribute user-role network-operator description 江满娣 # local-user jiangxiuzhen class network password cipher $c$3$46nZM0Rw1RPVmoNp7BYBHTsRnieJG7wiJpMPrafi access-limit 2 service-type portal authorization-attribute user-role network-operator description 江秀珍 # local-user jiangzechong class network password cipher $c$3$TqYPYhol7zSlkO4d5CVl13uilBOxGTclbMSrdW5i access-limit 2 service-type portal authorization-attribute user-role network-operator description 江泽冲 # local-user jishan class network password cipher $c$3$o8W57kxGFvqDrElIgTp296wA6r0LnOGaeiu/Iorr access-limit 2 service-type portal authorization-attribute user-role network-operator description 纪 珊 # local-user kuangxianyu class network password cipher $c$3$LaGgXgpNWHvOtpaUgbCS9xLBBbXYEvOhXtQZ8QeU access-limit 2 service-type portal authorization-attribute user-role network-operator description 邝先郁 # local-user laijuan class network password cipher $c$3$xJnaivjkaOa5ArqcORoct6NHA9NVmNqekzAd9k2t access-limit 2 service-type portal authorization-attribute user-role network-operator description 赖 娟 # local-user laiyuqun class network password cipher $c$3$IhgCwO+hfLLs6HHUJYNXLqjrJwMR6gnE3MdHeuc/ access-limit 2 service-type portal authorization-attribute user-role network-operator description 赖玉群 # local-user lianghuiping class network password cipher $c$3$+/Vyhx/vGjPc3KWIZ5TEIcBMWmyHskldxYtNr5tt access-limit 2 service-type portal authorization-attribute user-role network-operator description 梁惠萍 # local-user liangjun class network password cipher $c$3$WWFMOvJOT6JdzdHFsyJ2bvarFDkwxXty9BOr1prd access-limit 2 service-type portal authorization-attribute user-role network-operator description 梁 俊 # local-user liangshiyao class network password cipher $c$3$E/Uc5Ij7lPUAznuCgMSXK5X7QWOOV6umEtV4rfZz access-limit 2 service-type portal authorization-attribute user-role network-operator description 梁诗瑶 # local-user liaoxiangping class network password cipher $c$3$nm6KxMVicWSAx1fz9wOxu2rpVBHwLLqQsiipIvj7 access-limit 2 service-type portal authorization-attribute user-role network-operator description 廖湘萍 # local-user libiying class network password cipher $c$3$cT8fQFp7FRBsbDE51DLDDAPzriMCB4Tyd0NScA3N access-limit 2 service-type portal authorization-attribute user-role network-operator description 黎碧莹 # local-user lijingting class network password cipher $c$3$UbtbTWtr7lY27GSbMPUknJwZkAClaksWvOTH9Vx3 access-limit 2 service-type portal authorization-attribute user-role network-operator description 李静婷 # local-user liliwen class network password cipher $c$3$VK1Qlhz1u41V6a9gfAJLVhgrcdKbiOQcCGT5nCuB access-limit 2 service-type portal authorization-attribute user-role network-operator description 李莉雯 # local-user lingguoxiong class network password cipher $c$3$wQuoTR3vpT6Sqhrs6Zv/2F26nzfB/UxgG4bnHJtA access-limit 2 service-type portal authorization-attribute user-role network-operator description 凌国雄 # local-user linhong class network password cipher $c$3$/jthSri7Vd5HP7fEXINV5NDNBMCqGh4q6rKq4pSl access-limit 2 service-type portal authorization-attribute user-role network-operator description 林 洪 # local-user linyuan class network password cipher $c$3$cNugaYmCMB3ktKcPnJgXFRbXfA6ZZ3rYEKj31Bee access-limit 2 service-type portal authorization-attribute user-role network-operator description 林 苑 # local-user linyupei class network password cipher $c$3$W52dTGrSUpwGadT4eYvt90R6Aj7FNQqUzK7NtnU5 access-limit 2 service-type portal authorization-attribute user-role network-operator description 林玉佩 # local-user lishaofen class network password cipher $c$3$4JP59kTnAW2RSGPcDm8syRRSpYljeErhyuAa4bVy access-limit 2 service-type portal authorization-attribute user-role network-operator description 黎韶分 # local-user liuchunli class network password cipher $c$3$Kiug9G/ehaBsWyq1ryNogSV9LCfAjUwiBtsbVdUO access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘春利 # local-user liuchunling class network password cipher $c$3$dS5MFE7D4YfFKN1+4q/lQlrpXNsYkmvGP1zyhrFH access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘春凌 # local-user liuchunyan class network password cipher $c$3$nbja6xVqQR5pxrnkKytZjGOrB9kKxjfQPE5iTR/n access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘春燕 # local-user liuhuihong class network password cipher $c$3$TBq1TFINFAaHc6O/VfLaKS6zVKbNJwcb2WjYkBvw access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘会红 # local-user liujiajing class network password cipher $c$3$JK4EXd8DWLRuF/+iMmpBd8dp4YFlyLz1GxKe48I6 access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘嘉靖 # local-user liukaiyi class network password cipher $c$3$5e0KmXVVPSHwBEpFtzca/RNyu81jMYiImQWOwzV/ access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘凯怡 # local-user liukeyuan class network password cipher $c$3$bPNiIFqFkcbKYXi2BhZdf0EQ8QPLc3on+b4WIr+E access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘科苑 # local-user liushuting class network password cipher $c$3$CMPxXsD0B8hHLFxxreOq78AcCp9NTdC0LAZBTTvK access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘淑婷 # local-user liuxuexia class network password cipher $c$3$rioZM5sYCULLNJimbhfcMg9pboplfO3N/iBQ5MRN access-limit 2 service-type portal authorization-attribute user-role network-operator description 刘雪霞 # local-user lixiaofang class network password cipher $c$3$0UoiSHif8T1g+oBfK4re/uEyzKUezNy40ZfWPjpU access-limit 2 service-type portal authorization-attribute user-role network-operator description 李晓芳 # local-user lixiaoyan class network password cipher $c$3$CexnuVrQtKZegyFlu5e6XKM3we62SJjG5+vp5TKz access-limit 2 service-type portal authorization-attribute user-role network-operator description 黎晓燕 # local-user liyangfeng class network password cipher $c$3$tkZcBm2L0MoDbZ3WPxuDqTCeeMa8gVlaeju/LMJu access-limit 2 service-type portal authorization-attribute user-role network-operator description 李洋凤 # local-user luolirong class network password cipher $c$3$uDUIXGPgC0O9eMi2U8wwSsf7XDJelyJuz8Zn9bsB access-limit 2 service-type portal authorization-attribute user-role network-operator description 罗丽容 # local-user luoliyue class network password cipher $c$3$ZmZbfVHrXiVBqDxpqHfuFCvvxbZwvLUAuYQ9WTal access-limit 2 service-type portal authorization-attribute user-role network-operator description 罗立悦 # local-user luoruiwen class network password cipher $c$3$dqmWpEIBYkWy0/FptkVeB6PG4Z0DchrQh8lf+pEH access-limit 2 service-type portal authorization-attribute user-role network-operator description 罗瑞文 # local-user luowenhui class network password cipher $c$3$GsTzWi/EZYSenM43v5glvvMZN0NJJyiV0Q5j7un9 access-limit 2 service-type portal authorization-attribute user-role network-operator description 骆文辉 # local-user lushaoxing class network password cipher $c$3$55dRagiOx4RVrPH2B7awTlSX/AsPzk3fHYaqG8PL access-limit 2 service-type portal authorization-attribute user-role network-operator description 陆韶星 # local-user mawenjuan class network password cipher $c$3$mC4QYnGb9X7Hzu9BEXnTnRD69k2Od9qdo2G+Ud1B access-limit 2 service-type portal authorization-attribute user-role network-operator description 马文娟 # local-user oushunheng class network password cipher $c$3$l4bsk2kIixl1J5PtP809C1jtWHmxsrDjpZWVz3fF access-limit 2 service-type portal authorization-attribute user-role network-operator description 欧顺恒 # local-user ouxinxin class network password cipher $c$3$QFcyBQDUPPIKKwiUgjZ27GmlxdfII0WRHBpEzWyx access-limit 2 service-type portal authorization-attribute user-role network-operator description 欧欣欣 # local-user ouxueyi class network password cipher $c$3$H/pAXqMMiIFkyzCp8AV+mkyED+340/QlJuSPD+o4 access-limit 2 service-type portal authorization-attribute user-role network-operator description 欧雪怡 # local-user panguangxing class network password cipher $c$3$OcenpvccG2NrwZ3n4PwnEiSmaETBCkLAXIHFG8nN access-limit 2 service-type portal authorization-attribute user-role network-operator description 潘光行 # local-user qiubichang class network password cipher $c$3$CESCRek++/8QyE3ejePS6GeX7g369/9Ne5jLMHDC access-limit 2 authorization-attribute user-role network-operator description 邱必昌 # local-user qiushaomei class network password cipher $c$3$Wxy5AecBTeIGi//GX3dafbpSuhT8ZDlftMIZW814 access-limit 2 service-type portal authorization-attribute user-role network-operator description 丘韶妹 # local-user qiuzhiping class network password cipher $c$3$uikYaeP//NkYMDLSw7aV2fX0ULjew9OWDOEPy4Rd access-limit 2 service-type portal authorization-attribute user-role network-operator description 邱志平 # local-user ronghongfen class network password cipher $c$3$2LShyc6jvd+jPTBepNghhYpnLspLGOz/5JvoQf8M access-limit 2 service-type portal authorization-attribute user-role network-operator description 荣红芬 # local-user ruhaiying class network password cipher $c$3$YqlL1iYcL/3r4tpylzgKLKMFmf01O0vfKs3mbB0E access-limit 2 service-type portal authorization-attribute user-role network-operator description 茹海英 # local-user songxinqiang class network password cipher $c$3$QP+MyPE4xJAIp3mFYR3fIkvrVVV+Dr3CqiCEzYIZ access-limit 2 service-type portal authorization-attribute user-role network-operator description 宋新强 # local-user suhang class network password cipher $c$3$jetRRZUQAImjUFv9l2NS2d2++fD+MtrlYcV34iqO access-limit 2 service-type portal authorization-attribute user-role network-operator description 苏 杭 # local-user tanmeifang class network password cipher $c$3$63SucewnZCXckkdgrWpaUscyqRkFsgbV/MYvvTCT access-limit 2 service-type portal authorization-attribute user-role network-operator description 谭美方 # local-user tanyanling class network password cipher $c$3$XAokUDsI6dV16WNTJwfjctlfE63O17ZW/l1T79zV access-limit 2 service-type portal authorization-attribute user-role network-operator description 谭艳玲 # local-user test class network password cipher $c$3$Ek2jzUtWSSiCtl+4Yxryr8IjgTT/rQ== access-limit 1 service-type portal authorization-attribute user-role network-operator # local-user wangxiang class network password cipher $c$3$ITP7/LXS1Wmhlmm1cjQ6Wa55V8kebigkDXpJEyEq access-limit 2 service-type portal authorization-attribute user-role network-operator description 王 翔 # local-user wangyanting class network password cipher $c$3$RJ/eRneQNO1oxEGdjKOBJ8x02ZnvauYKqeB9ZPXJ access-limit 2 service-type portal authorization-attribute user-role network-operator description 王艳婷 # local-user wenfulan class network password cipher $c$3$M1LKORTRvfOpbE/fPt+PQqvhNgahJItXrWsmJqOz access-limit 2 service-type portal authorization-attribute user-role network-operator description 温福兰 # local-user wenhuixin class network password cipher $c$3$xSKIOj8NPqw1DymwrM4FU4lj/SHdIqVL/3v3dM+B access-limit 2 service-type portal authorization-attribute user-role network-operator description 温慧馨 # local-user wenyanbing class network password cipher $c$3$AZTt2HQoX6bPMeXGfd64So9o1G+drPtAOec4L2WE access-limit 2 service-type portal authorization-attribute user-role network-operator description 温燕冰 # local-user wuhaijuan class network password cipher $c$3$29ij8Em2pPriSewHrD+d1pcGG3g9/1EvPKdLxzCC access-limit 2 service-type portal authorization-attribute user-role network-operator description 吴海娟 # local-user wulonghua class network password cipher $c$3$e/a5w/pnX/7EC7LhTQ81wNYV5cMHyqGwG1SqKLPi access-limit 2 service-type portal authorization-attribute user-role network-operator description 吴龙华 # local-user xieguangzhu class network password cipher $c$3$a7NEZSg0VLPYoaq241CuVtcfolxuImgAN8X3JzlO service-type portal authorization-attribute user-role network-operator description 谢光珠 # local-user xiehuiying class network password cipher $c$3$XRZxFqUd1bqOWhLaWNkrX/xdDk9nYPXdyolacICe access-limit 2 service-type portal authorization-attribute user-role network-operator description 谢慧莹 # local-user xieqi class network password cipher $c$3$N4ZU3GBl5FQG/6aaQfAZFioULHNYHbndIbADgrgf access-limit 2 service-type portal authorization-attribute user-role network-operator description 谢 琦 # local-user xiewenjuan class network password cipher $c$3$r3iM0R1P/3LwpwA2cnnnY+5YWWMWOmRyZ3yhtAu2 access-limit 2 service-type portal authorization-attribute user-role network-operator description 谢文娟 # local-user xieyongchang class network password cipher $c$3$0Vr/M7oubLCUzOKBo0oSzsgIJXjofctdDB4HWAJl access-limit 2 service-type portal authorization-attribute user-role network-operator description 谢永昌 # local-user xulin class network password cipher $c$3$ohZF5roIhPwPEutAAgvE6cXJWRfYj+J0Q5rno/j6 access-limit 2 service-type portal authorization-attribute user-role network-operator description 许 琳 # local-user xuliyan class network password cipher $c$3$+zjWTPhJiNUVOqiva+2AiIdgrPOtWm1KPkvUMB5x access-limit 2 service-type portal authorization-attribute user-role network-operator description 徐丽艳 # local-user xuqingqian class network password cipher $c$3$f+hJQlCz6jYsDCOG6K3/+HpxNVKg1c+JfH0q0dK0 access-limit 2 service-type portal authorization-attribute user-role network-operator description 许青倩 # local-user xushenglin class network password cipher $c$3$HO8/XzBr31BOxjwTO70P+vt1CsgeR+iNQhaCakBP access-limit 2 service-type portal authorization-attribute user-role network-operator description 许胜林 # local-user xuyuchan class network password cipher $c$3$/4dRUnelvDmMbkN2o96oSwaO5I0BIF6/jDYmZ0oU access-limit 2 service-type portal authorization-attribute user-role network-operator description 许玉婵 # local-user yangguining class network password cipher $c$3$pOCM9XELuGuQ6IdZG35cfRA4aOBwIj73UAAA65Px access-limit 2 service-type portal authorization-attribute user-role network-operator description 杨桂宁 # local-user yangxiyuan class network password cipher $c$3$3SmqYOETX1mu+PMGBqVO4sQYN2a8c7Kb5mj0ixqU access-limit 2 service-type portal authorization-attribute user-role network-operator description 杨晰媛 # local-user yefei class network password cipher $c$3$YEzq6yjyLhqfjtoPFEZKmQtl+9KIGWoN11A4YEK3 access-limit 2 service-type portal authorization-attribute user-role network-operator description 叶 菲 # local-user yetao class network password cipher $c$3$z7B2wFSW3/92BQ7MXAvgsci4NPUBFLdobzB5Omih access-limit 2 service-type portal authorization-attribute user-role network-operator description 叶 桃 # local-user yinlifang class network password cipher $c$3$vLVuqMUfkaYGrJRjRREiCmjM/deaDWvKAOA54TEq access-limit 2 service-type portal authorization-attribute user-role network-operator description 殷利芳 # local-user yuanjie class network password cipher $c$3$yfuDyRdPU6RFs06EuMmu8+WsNGSMxj7AMNcPx7vf access-limit 2 service-type portal authorization-attribute user-role network-operator description 袁 洁 # local-user zengliling class network password cipher $c$3$pnlv6mMijMBJ68SbKHpc5IQbri4zUhkVEYJAjTZR access-limit 2 service-type portal authorization-attribute user-role network-operator description 曾丽玲 # local-user zengliuqin class network password cipher $c$3$4QOiqZa6FisfxqgdrbUiYzS7Dz9ZGRZbdTQIm4gU access-limit 2 service-type portal authorization-attribute user-role network-operator description 曾柳琴 # local-user zengruotong class network password cipher $c$3$UWgcv/EcCVLva0M3vPd63nvXyZtmyQAnX+5cPdr6 access-limit 2 service-type portal authorization-attribute user-role network-operator description 曾若彤 # local-user zengxiaoying class network password cipher $c$3$V7jUD288/pFibLoA76tUgSx3enVOR0IBI1hJtpjz access-limit 2 service-type portal authorization-attribute user-role network-operator description 曾小英 # local-user zhanglina class network password cipher $c$3$AzE5My3HndD+Jt1DbjXmhKUxU8faMsWVqK1dy3/u access-limit 2 service-type portal authorization-attribute user-role network-operator description 张丽娜 # local-user zhangweibin class network password cipher $c$3$rreo+P4EPDFxe7gS4/PLf9RWB/8uGwNF1xDExVyy access-limit 2 service-type portal authorization-attribute user-role network-operator description 张伟斌 # local-user zhangxian class network password cipher $c$3$OezPsoKXl2xJ+bhth3UsSqWwh7rv2m6oCEuWW47W access-limit 2 service-type portal authorization-attribute user-role network-operator description 张娴 # local-user zhangxinyan class network password cipher $c$3$mEbLERaRq78Tavj0+2Cip5ZZfu9KUatyzYgiM94M access-limit 2 service-type portal authorization-attribute user-role network-operator description 张新艳 # local-user zhiyanfang class network password cipher $c$3$GLNYs6VGfNOrFSFT1cg1CH7HYPr+JLErv1WkrlE4 access-limit 2 service-type portal authorization-attribute user-role network-operator description 植艳芳 # local-user zhongshaofen class network password cipher $c$3$FR8ojjrUCS0iHyogp6lXBGN0NlxeaPxNu+bkkCsn access-limit 2 service-type portal authorization-attribute user-role network-operator description 钟韶芬 # local-user zhusilu class network password cipher $c$3$r9l7n87ZdyyD421OtDFnBw3CTHi2ct4JcsC9uwBp access-limit 2 service-type portal authorization-attribute user-role network-operator description 朱思璐 # local-user zouxinzong class network password cipher $c$3$A9UTVzdJN15FbgcZcObMx3PgnVDjsEYu0AsNJTby access-limit 2 service-type portal authorization-attribute user-role network-operator description 邹新宗 # local-user zouxuedan class network password cipher $c$3$uKuVlcbr5QLNSVkKcoOGy14E5yegLLfH8SKuyy9h access-limit 2 service-type portal authorization-attribute user-role network-operator description 邹雪丹 # portal host-check enable portal free-rule 0 destination ip 114.114.114.114 255.255.255.255 portal free-rule 1 destination ip 172.16.220.253 255.255.255.255 portal free-rule 2 destination ip 172.16.220.254 255.255.255.255 # portal web-server portal url http://172.16.220.253/portal url-parameter wlanuserip source-address # portal local-web-server http default-logon-page defaultfile.zip # ip https enable web idle-timeout 30 # portal mac-trigger-server portal ip 172.16.220.253 local-binding aging-time 2880 local-binding enable # wlan auto-ap enable wlan auto-persistent enable # wlan ap-group default-group vlan 1 # wlan ap-group wa5320 vlan 1 ap 5098-b864-9da0 ap 5098-b868-80c0 ap 5098-b869-1940 ap 5098-b869-19e0 ap 5098-b869-1b40 ap 5098-b869-1cc0 ap 5098-b869-1e60 ap 782c-2972-a5e0 ap 782c-2972-aa40 ap 782c-2972-d900 ap 782c-2972-dfa0 ap 782c-2972-e080 ap 782c-2972-e180 ap 782c-2972-e580 ap 782c-2972-e5e0 ap 782c-2972-e640 ap 782c-2972-e660 ap 782c-2972-e760 ap 782c-2972-e7a0 ap 782c-2972-e7e0 ap 782c-2972-e800 ap 782c-2972-e840 ap 782c-2972-e860 ap 782c-2972-e880 ap 782c-2972-e8c0 ap 782c-2972-e8e0 ap 782c-2972-e920 ap 782c-2972-e940 ap 782c-2972-e960 ap 782c-2973-2760 ap 782c-2973-2ac0 ap 782c-2973-2d80 ap 782c-2973-2dc0 ap 782c-2973-2de0 ap 782c-2973-3000 ap-model WA5320 map-configuration flash:/wa5320_map.txt radio 1 radio enable channel band-width 20 service-template zhxx vlan 220 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 radio 2 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable service-template zhxx vlan 220 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 gigabitethernet 1 gigabitethernet 2 # wlan ap-group wa5320x vlan 1 ap 7057-bf05-ff40 ap-model WA5320X map-configuration flash:/wa5320x_map.txt radio 1 radio enable channel band-width 20 service-template zhxx vlan 230 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 radio 2 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable service-template zhxx vlan 220 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 # wlan ap-group wa5530i vlan 1 ap 5098-b86a-b4e0 ap 5098-b86a-b7e0 ap 5098-b86a-be40 ap 5098-b86a-bf90 ap 5098-b86a-c470 ap 5098-b86a-cd10 ap-model WA5530i map-configuration flash:/wa5530i_map.txt radio 1 radio enable channel band-width 20 service-template zhxx vlan 220 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 radio 2 radio enable channel band-width 20 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 radio 3 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable service-template zhxx vlan 220 service-template zhxx_guest vlan 230 client-rate-limit enable client-rate-limit inbound mode static cir 8192 client-rate-limit outbound mode static cir 8192 gigabitethernet 1 gigabitethernet 2 # user-isolation vlan 220 enable user-isolation vlan 220 permit-mac 3c8c-40bf-5061 5098-b82f-f468 user-isolation vlan 230 enable user-isolation vlan 230 permit-mac 3c8c-40bf-5061 5098-b82f-f468 # wlan ap 5098-b864-9da0 model WA5320 serial-id 219801A0YD8197E004X9 description (办公楼)2楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b868-80c0 model WA5320 serial-id 219801A0YD8197E006LH description (办公楼)3楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b869-1940 model WA5320 serial-id 219801A0YD8197E007VV description (办公楼)2楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b869-19e0 model WA5320 serial-id 219801A0YD8197E007W0 description 舞蹈室门外 vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b869-1b40 model WA5320 serial-id 219801A0YD8197E007WC description (办公楼)2楼走道5号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b869-1cc0 model WA5320 serial-id 219801A0YD8197E007WR vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b869-1e60 model WA5320 serial-id 219801A0YD8197E007X5 description 2楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-b4e0 model WA5530i serial-id 219801A1TF8197E0007L description 体育馆2号 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-b7e0 model WA5530i serial-id 219801A1TF8197E00083 description 体育馆1号 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-be40 model WA5530i serial-id 219801A1TF8197E00096 description 阶梯会议室1号 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-bf90 model WA5530i serial-id 219801A1TF8197E0009F description 阶梯会议室2号 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-c470 model WA5530i serial-id 219801A1TF8197E000B8 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 5098-b86a-cd10 model WA5530i serial-id 219801A1TF8197E000CR description 创客室 vlan 1 radio 1 radio 2 radio 3 gigabitethernet 1 gigabitethernet 2 # wlan ap 7057-bf05-ff40 model WA5320X serial-id 219801A17D8191E000KJ description 1楼大功率 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 # wlan ap 782c-2972-a5e0 model WA5320 serial-id 219801A0YD8194E0000X description (办公楼)2楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-aa40 model WA5320 serial-id 219801A0YD8194E00021 description (办公楼)3楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-d900 model WA5320 serial-id 219801A0YD8194E000G3 description 3楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-dfa0 model WA5320 serial-id 219801A0YD8194E000HT description 3楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e080 model WA5320 serial-id 219801A0YD8194E000J1 description 1楼走道1号 vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e180 model WA5320 serial-id 219801A0YD8194E000J9 description 4楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e580 model WA5320 serial-id 219801A0YD8194E000KB description 2楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e640 model WA5320 serial-id 219801A0YD8194E000KJ description 4楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e660 model WA5320 serial-id 219801A0YD8194E000KK description 4楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e760 model WA5320 serial-id 219801A0YD8194E000KT description (办公楼)3楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e800 model WA5320 serial-id 219801A0YD8194E000KZ description 3楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e840 model WA5320 serial-id 219801A0YD8194E000L1 description 5楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e860 model WA5320 serial-id 219801A0YD8194E000L2 description 5楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e880 model WA5320 serial-id 219801A0YD8194E000L3 description 3楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e920 model WA5320 serial-id 219801A0YD8194E000L8 description (办公楼)4楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e940 model WA5320 serial-id 219801A0YD8194E000L9 description (办公楼)4楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e960 model WA5320 serial-id 219801A0YD8194E000LB description (办公楼)4楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e5e0 model WA5320 serial-id 219801A0YD8194E000KF description 5楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e7a0 model WA5320 serial-id 219801A0YD8194E000KW description 1楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e7e0 model WA5320 serial-id 219801A0YD8194E000KY description 5楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e8c0 model WA5320 serial-id 219801A0YD8194E000L5 description 1楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2972-e8e0 model WA5320 serial-id 219801A0YD8194E000L6 description 4楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-2760 model WA5320 serial-id 219801A0YD8194E0013B description 2楼走道2号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-3000 model WA5320 serial-id 219801A0YD8194E0015K description (办公楼)4楼走道4号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-2ac0 model WA5320 serial-id 219801A0YD8194E00146 description (办公楼)2楼走道3号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-2d80 model WA5320 serial-id 219801A0YD8194E0014X description 2楼走道4号 vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-2dc0 model WA5320 serial-id 219801A0YD8194E0014Z description (办公楼)3楼走道1号 vlan 1 radio 1 service-template zhxx service-template zhxx_guest radio 2 service-template zhxx service-template zhxx_guest gigabitethernet 1 gigabitethernet 2 # wlan ap 782c-2973-2de0 model WA5320 serial-id 219801A0YD8194E00150 vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2 # return
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
使用的是内置portal认证 没有服务器
是账号在线时长超过28小时后需要重认证 能把这个时间延长吗
试试这个 #配置无感知的名字为localportal,无感知服务器为192.168.100.1,开启本地无感知功能,设置无感知绑定表项的老化时间为1分钟 [AC]portal mac-trigger-server localportal [AC-portal-mac-trigger-server-localportal]ip 192.168.100.1 [AC-portal-mac-trigger-server-localportal]local-binding enable [AC-portal-mac-trigger-server-localportal]local-binding aging-time 1
