用户SSID coco-staff 做的802.1X 认证。 部分用户手机这个选证书的位置,必须选择,但是选择选项“无”,就认证不通过。这个怎么解?
wlan service-template coco-staff
ssid COCO-STAFF
vlan 28
client association-location ap
client forwarding-location ap vlan 23
quick-association enable
akm mode dot1x
cipher-suite ccmp
cipher-suite tkip
security-ie rsn
security-ie wpa
undo gtk-rekey enable
client-security authentication-mode dot1x
dot1x domain coco
ft enable
service-template enable
radius session-control enable
radius scheme coco
primary authentication 192.168.20.12 key cipher $c$3$kEeL0IjwiHqVUMgfCaIvG6FQzZ/goveA
primary accounting 192.168.20.12 key cipher $c$3$tXXcqIS5VnFJ5wm35vMxmyLfnt7U3v1E
nas-ip 192.168.28.4
domain coco authentication lan-access
radius-scheme coco
authorization lan-access none
accounting lan-access radius-scheme coco
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
大部分手机是可以的,只有这个位置是 “无、系统证书”的,选哪个都不行。。。。
Received client failure message with reason code=4019.
错误代码是这个
从这个错误代码无法获知原因,debug或者抓包看看
