<CZB-4F-JK-JR-24P-1>DIS current-configuration # version 7.1.070, Release 6328 # sysname CZB-4F-JK-JR-24P-1 # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # lldp global enable # password-recovery enable # vlan 1 # vlan 100 to 999 # vlan 1001 # stp global enable # interface NULL0 # interface Vlan-interface1 ip address dhcp-alloc dhcp client identifier ascii 5ca7219f8e4c-VLAN0001 # interface Vlan-interface1001 ip address 10.1.0.27 255.255.255.0 # interface GigabitEthernet1/0/1 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/2 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/3 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/4 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/5 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/6 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/7 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/8 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/9 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/10 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/11 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/12 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/13 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/14 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/15 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/16 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/17 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/18 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/19 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/20 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/21 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/22 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/23 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/24 port access vlan 212 stp edged-port # interface GigabitEthernet1/0/25 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 2 to 4094 # interface GigabitEthernet1/0/26 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 2 to 4094 # interface GigabitEthernet1/0/27 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 2 to 4094 # interface GigabitEthernet1/0/28 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 2 to 4094 # scheduler logfile size 16 # line class aux user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-admin # line vty 0 4 authentication-mode scheme user-role network-operator # line vty 5 63 user-role network-operator # ip route-static 0.0.0.0 0 10.1.0.254 # radius scheme system user-name-format without-domain # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$xGRHSeLDZJSTb9br$LCN2o0NawhkXEpU9u8QKci+FVOAW4jWLooYJogt5AQYehNyYkx4b8Gfd4pOPnaXguVeRyD40IyNTgGNpz663WQ== service-type telnet ssh authorization-attribute user-role network-admin authorization-attribute user-role network-operator # return
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
这个咋看
多次通过这条命令看看回显的drop计数有没有增加,要看故障时候的,接口换成实际的接口就行 <Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound Interface: Ten-GigabitEthernet1/0/1 Direction: outbound Forwarded: 0 packets, 0 bytes Dropped: 0 packets, 0 bytes Queue 0 Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps Dropped: 0 packets, 0 bytes Current queue length: 0 packets Queue 1 Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps Dropped: 0 packets, 0 bytes Current queue length: 0 packets Queue 2 Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps Dropped: 0 packets, 0 bytes Current queue length: 0 packets Queue 3 Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps Dropped: 0 packets, 0 bytes Current queue length: 0 packets Queue 4 Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps Dropped: 0 packets, 0 bytes Current queue length: 0 packets Queue 5
