堆叠
2021-09-19提问
  • 1收藏,1455浏览
%Sep 19 08:11:32:179 2021 1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/49 changed to up. %Sep 19 08:11:32:181 2021 1 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/49 (IfIndex 50), neighbor's chassis ID is 6cc5-2218-0200, port ID is Ten-GigabitEthernet2/0/49. %Sep 19 08:11:32:220 2021 1 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/50 changed to up. %Sep 19 08:11:32:221 2021 1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/50 changed to up. %Sep 19 08:11:32:222 2021 1 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/50 (IfIndex 51), neighbor's chassis ID is 6cc5-2218-0200, port ID is Ten-GigabitEthernet2/0/50. %Sep 19 08:11:32:335 2021 1 STM/4/STM_MERGE: IRF merge occurred. [1-if-range] [1-if-range] [1-if-range]%Sep 19 08:11:37:146 2021 1 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/49 changed to down. %Sep 19 08:11:37:146 2021 1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/49 changed to down. %Sep 19 08:11:37:187 2021 1 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/50 changed to down. %Sep 19 08:11:37:187 2021 1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/50 changed to down. %Sep 19 08:11:37:198 2021 1 STM/3/STM_LINK_DOWN: IRF port 2 went down
堆叠失败,的可能原因有哪些?
粉丝:3人 关注:0人
1、硬件型号 版本要完全一直
2、堆叠接口速率
3、配置,需要按照官网的配合先后顺序来 前后不能颠倒
4、链路速率不匹配
V7交换机IRF2堆叠配置方法(命令行版)
V7交换机IRF2堆叠配置方法(命令行版) 1
1 配置需求或说明 1
1.1 适用产品系列 1
1.2 配置需求及实现的效果 1
2 组网图 2
3 配置步骤 2
3.1 配置IRF2 2
3.1.1 配置设备编号 2
3.1.2 配置堆叠口 2
3.2 BFD分裂检测(选配) 3
3.3 配置要点 4
1 配置需求或说明
1.1 适用产品系列
本案例适用于支持IRF2款型的V7交换机,具体型号是否支持,对堆叠的物理连线、模块是否有要求可以参考对应型号交换机操作手册中的IRF配置指导。在此以S5820V2交换机举例。
1.2 配置需求及实现效果
由于网络规模迅速扩大,当前中心交换机(Device A)转发能力已经不能满足需求,需要另外增加一台设备Device B。现需要将两台设备配置IRF2堆叠,将网络转发能力提高一倍,并实现网络易管理、易维护。Device ADevice B分别使用自带的两个万兆口做堆叠口。也可以只用一个接口堆叠,根据实际情况而定。
2 组网图
3 配置步骤
3.1 配置IRF2
3.1.1 配置设备编号
# Device A保留缺省编号为1,不需要进行配置。同时,Device B上将设备的成员编号修改为2
<DeviceB> system-view
[DeviceB] irf member 1 renumber 2
Warning: Renumbering the switch number may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB]
3.1.2 配置堆叠口
#将两台设备断电后,按组网图所示连接IRF链路,然后将两台设备上电Device A上创建设备的IRF端口2,与物理端口Ten-GigabitEthernet1/0/25 Ten-GigabitEthernet1/0/26绑定,并保存配置。
<DeviceA> system-view
[DeviceA] interface ten-gigabitethernet 1/0/25
[DeviceA-Ten-GigabitEthernet1/0/25] shutdown
[DeviceA-Ten-GigabitEthernet1/0/25] quit
[DeviceA] interface ten-gigabitethernet 1/0/26
[DeviceA-Ten-GigabitEthernet1/0/26] shutdown
[DeviceA-Ten-GigabitEthernet1/0/26] quit
[DeviceA] irf-port 1/2
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/25
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/26
[DeviceA-irf-port1/2] quit
[DeviceA-Ten-GigabitEthernet1/0/25] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/25quit
[DeviceA-Ten-GigabitEthernet1/0/26] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/26quit
[DeviceA] save force
Device B上创建设备的IRF端口1,与物理端口Ten-GigabitEthernet2/0/25Ten-GigabitEthernet2/0/26绑定,并保存配置。
[DeviceB] interface ten-gigabitethernet 2/0/25
[DeviceB-Ten-GigabitEthernet2/0/25] shutdown
[DeviceB-Ten-GigabitEthernet2/0/25] quit
[DeviceB] interface ten-gigabitethernet 2/0/26
[DeviceB-Ten-GigabitEthernet2/0/26] shutdown
[DeviceB-Ten-GigabitEthernet2/0/26] quit
[DeviceB] irf-port 2/1
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/25
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/26
[DeviceB-irf-port2/1] quit
[DeviceB-Ten-GigabitEthernet2/0/25] undo shutdown
[DeviceB-Ten-GigabitEthernet2/0/25quit
[DeviceB-Ten-GigabitEthernet2/0/26] undo shutdown
[DeviceB-Ten-GigabitEthernet2/0/26quit
[DeviceB] save force
激活DeviceAIRF端口配置。
[DeviceA] irf-port-configuration active
激活DeviceBIRF端口配置。
[DeviceB] irf-port-configuration active
#两台设备间将会进行Master竞选,竞选失败的一方将自动重启,重启完成后,IRF形成,系统名称统一为DeviceA
3.2 BFD分裂检测(选配)
IRF设备一旦分裂,会变成两台配置完全相同的设备,导致业务转发有问题。为了避免此类问题出现,可以配置分裂检测。设备一旦检测到IRF2分裂,则自动关闭备设备的所有非保留端口。在此介绍BFD MAD分裂检测配置方法。使用网线Device A上的端口GigabitEthernet1/0/1Device B上的端口GigabitEthernet2/0/1连接起来。
创建VLAN 3,并将Device A上的端口GigabitEthernet1/0/1Device B上的端口GigabitEthernet2/0/1加入VLAN中。
[DeviceA] vlan 3
[DeviceA-vlan3] port gigabitethernet 1/0/1 gigabitethernet 2/0/1
[DeviceA-vlan3] quit
创建VLAN接口3,并配置MAD IP地址。
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] mad bfd enable
[DeviceA-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[DeviceA-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[DeviceA-Vlan-interface3] quit
按组网图所示连接BFD MAD链路。
因为BFD MAD和生成树功能互斥,所以在GigabitEthernet1/0/1GigabitEthernet2/0/1上关闭生成树协议。
[DeviceA] interface gigabitethernet 1/0/1
[DeviceA-Gigabitethernet1/0/1] undo stp enable
[DeviceA-Gigabitethernet1/0/1] quit
[DeviceA] interface gigabitethernet 2/0/1
[DeviceA-Gigabitethernet2/0/1] undo stp enable
3.3 配置要点
1IRF-port端口编号说明,irf-port 1/2中,第一个数字代表的是设备成员编号,第二个数字是接口编号。堆叠要求使用逻辑端口1对接逻辑端口2。即,如若第一台配置irf-port1/2,则第二台需要是用irf-port2/1对接。如若第一台使用irf-port1/1,则第二台需要配置irf-port2/2
2)设备配置好IRF2配置后,要先保存再激活配置。
我再试试,感谢
在路上 发表时间:2021-09-19
