设置列表
%Sep 10 10:10:46:417 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 10 19:06:23:500 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=139-OperateState=success-OperateEndTime=127027196; Operation completed.
%Sep 10 19:06:27:667 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=100-OperateState=success-OperateEndTime=127027612; Operation completed.
%Sep 10 21:48:16:104 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:37:46:572 09/10/2021 to 21:48:16:093 09/10/2021, the NTP server's IP address is 192.168.68.210.
%Sep 10 22:00:20:732 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:10:50:135 09/10/2021 to 22:00:20:721 09/10/2021, the NTP server's IP address is 192.168.68.210.
%Sep 11 02:01:22:939 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=79-OperateState=success-OperateEndTime=129517129; Operation completed.
%Sep 11 02:01:24:801 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=33-OperateState=success-OperateEndTime=129517315; Operation completed.
%Sep 11 19:06:20:436 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=89-OperateState=success-OperateEndTime=135666879; Operation completed.
%Sep 11 19:06:22:689 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=82-OperateState=success-OperateEndTime=135667104; Operation completed.
%Sep 11 21:54:10:582 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:43:39:767 09/11/2021 to 21:54:10:571 09/11/2021, the NTP server's IP address is 192.168.68.210.
%Sep 11 22:15:02:892 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:25:33:621 09/11/2021 to 22:15:02:881 09/11/2021, the NTP server's IP address is 192.168.68.210.
%Sep 12 02:01:28:251 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=79-OperateState=success-OperateEndTime=138157654; Operation completed.
%Sep 12 02:01:30:080 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=34-OperateState=success-OperateEndTime=138157837; Operation completed.
%Sep 12 21:47:27:710 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:36:55:931 09/12/2021 to 21:47:27:699 09/12/2021, the NTP server's IP address is 192.168.68.210.
%Sep 12 22:00:30:041 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:11:01:747 09/12/2021 to 22:00:30:030 09/12/2021, the NTP server's IP address is 192.168.68.210.
%Sep 13 01:05:15:235 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/0 changed to down.
%Sep 13 01:05:15:236 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/0 changed to down.
%Sep 13 01:08:13:234 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/0 changed to up.
%Sep 13 01:08:13:235 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/0 changed to up.
%Sep 13 03:32:14:356 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:14:357 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:17:386 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 03:32:17:388 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 03:32:19:353 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:19:357 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:23:379 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 03:32:23:385 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 03:32:41:356 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:41:357 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 13 03:32:53:355 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 03:32:53:355 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 13 09:18:02:427 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 2843.
%Sep 13 09:18:03:460 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 13 09:18:03:840 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
%Sep 13 09:18:07:431 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis device manuinfo
%Sep 13 09:25:54:052 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis device manuinfo
%Sep 13 09:25:59:744 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis device manuinfo
%Sep 13 09:27:25:410 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis device manuinfo
%Sep 13 09:27:36:558 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis device manuinfo
%Sep 13 09:37:48:840 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGOUT: admin logged out from 172.16.0.2.
%Sep 13 09:37:48:889 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: User admin logged out from 172.16.0.2 port 2843.
%Sep 13 09:37:48:889 2021 ZLSYR01-B1 SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.16.0.2) disconnected from the server.
%Sep 13 09:37:53:895 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=-IPAddr=**-User=**; Command is undo debugging all
%Sep 13 14:10:08:925 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.0.2 port 2833 because of invalid username or wrong password .
%Sep 13 14:10:13:076 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.0.2 port 2833 because of invalid username or wrong password .
%Sep 13 14:10:19:450 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 2833.
%Sep 13 14:10:20:488 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 13 14:10:20:878 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
%Sep 13 14:10:24:927 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis logbuffer
%Sep 13 14:11:14:642 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis logbuffer
%Sep 13 14:25:37:878 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGOUT: admin logged out from 172.16.0.2.
%Sep 13 14:25:37:914 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: User admin logged out from 172.16.0.2 port 2833.
%Sep 13 14:25:37:914 2021 ZLSYR01-B1 SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.16.0.2) disconnected from the server.
%Sep 13 14:25:49:204 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=-IPAddr=**-User=**; Command is undo debugging all
%Sep 13 21:44:41:620 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:34:08:074 09/13/2021 to 21:44:41:609 09/13/2021, the NTP server's IP address is 192.168.68.210.
%Sep 13 22:19:06:247 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:29:39:639 09/13/2021 to 22:19:06:236 09/13/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 03:03:10:528 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:52:35:250 09/15/2021 to 03:03:10:517 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 03:13:50:282 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 03:24:25:535 09/15/2021 to 03:13:50:271 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 05:25:09:678 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 05:14:34:286 09/15/2021 to 05:25:09:667 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 05:41:27:408 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 05:52:02:681 09/15/2021 to 05:41:27:397 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 15:25:03:390 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 2081.
%Sep 15 15:25:04:537 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 15 15:25:05:251 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
%Sep 15 15:25:19:015 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 15:25:47:302 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGOUT: admin logged out from 172.16.0.2.
%Sep 15 15:25:47:314 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: User admin logged out from 172.16.0.2 port 2081.
%Sep 15 15:25:47:314 2021 ZLSYR01-B1 SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.16.0.2) disconnected from the server.
%Sep 15 15:25:52:360 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=-IPAddr=**-User=**; Command is undo debugging all
%Sep 15 19:06:31:441 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=103-OperateState=success-OperateEndTime=170227945; Operation completed.
%Sep 15 19:06:33:412 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=60-OperateState=success-OperateEndTime=170228142; Operation completed.
%Sep 15 20:54:08:831 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.0.2 port 1994 because of invalid username or wrong password .
%Sep 15 20:54:13:833 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 1994.
%Sep 15 20:54:14:903 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 15 20:54:15:367 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
%Sep 15 20:54:21:028 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:54:27:532 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:54:34:951 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:54:47:215 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:54:57:493 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:55:00:584 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:55:03:421 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:55:07:991 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:55:12:684 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis ip routing-table protocol static
%Sep 15 20:55:19:121 2021 ZLSYR01-B1 SHELL/4/SHELL_CMD_MATCHFAIL: -User=admin-IPAddr=172.16.0.2; Command dis local-guest in view shell failed to be matched.
%Sep 15 20:55:23:319 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=172.16.0.2-User=admin; Command is dis logbuffer
%Sep 15 21:06:57:379 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGOUT: admin logged out from 172.16.0.2.
%Sep 15 21:06:57:427 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: User admin logged out from 172.16.0.2 port 1994.
%Sep 15 21:06:57:427 2021 ZLSYR01-B1 SSHS/6/SSHS_DISCONNECT: SSH user admin (IP: 172.16.0.2) disconnected from the server.
%Sep 15 21:07:02:130 2021 ZLSYR01-B1 SHELL/6/SHELL_CMD: -Line=-IPAddr=**-User=**; Command is undo debugging all
%Sep 15 21:43:37:705 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:33:01:410 09/15/2021 to 21:43:37:694 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 15 21:52:05:456 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:02:41:708 09/15/2021 to 21:52:05:445 09/15/2021, the NTP server's IP address is 192.168.68.210.
%Sep 16 02:01:28:887 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=149-OperateState=success-OperateEndTime=172717687; Operation completed.
%Sep 16 02:01:33:214 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=122-OperateState=success-OperateEndTime=172718120; Operation completed.
%Sep 16 19:06:17:640 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=187-OperateState=success-OperateEndTime=178866563; Operation completed.
%Sep 16 19:06:21:700 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=137-OperateState=success-OperateEndTime=178866969; Operation completed.
%Sep 16 21:45:46:281 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:35:08:466 09/16/2021 to 21:45:46:270 09/16/2021, the NTP server's IP address is 192.168.68.210.
%Sep 16 22:08:56:686 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:19:34:305 09/16/2021 to 22:08:56:675 09/16/2021, the NTP server's IP address is 192.168.68.210.
%Sep 17 02:01:19:680 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=96-OperateState=success-OperateEndTime=181356749; Operation completed.
%Sep 17 02:01:21:507 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=46-OperateState=success-OperateEndTime=181356932; Operation completed.
%Sep 17 19:06:18:282 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=190-OperateState=success-OperateEndTime=187506609; Operation completed.
%Sep 17 19:06:22:453 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=145-OperateState=success-OperateEndTime=187507027; Operation completed.
%Sep 17 21:49:39:851 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:39:00:706 09/17/2021 to 21:49:39:838 09/17/2021, the NTP server's IP address is 192.168.68.210.
%Sep 17 21:59:11:810 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:09:50:891 09/17/2021 to 21:59:11:795 09/17/2021, the NTP server's IP address is 192.168.68.210.
%Sep 18 02:01:18:377 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=84-OperateState=success-OperateEndTime=189996615; Operation completed.
%Sep 18 02:01:20:370 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=50-OperateState=success-OperateEndTime=189996813; Operation completed.
%Sep 18 04:10:23:339 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
total used free shared buffers cached
Mem: 2026068 1796812 229256 0 108 89912
-/+ buffers/cache: 1706792 319276
Swap: 0 0 0
%Sep 18 04:10:24:287 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 18 04:10:24:287 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 18 04:10:25:025 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 18 04:10:28:187 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 18 04:10:28:188 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 18 04:10:38:930 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 18 04:10:58:971 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796832 229236 0 0 89912
-/+ buffers/cache: 1706920 319148
Swap: 0 0 0
%Sep 18 04:11:00:497 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 18 04:11:12:677 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 18 04:11:32:584 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796856 229212 0 0 89912
-/+ buffers/cache: 1706944 319124
Swap: 0 0 0
%Sep 18 04:11:34:260 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 18 04:11:46:805 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 18 04:12:06:667 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796840 229228 0 0 89912
-/+ buffers/cache: 1706928 319140
Swap: 0 0 0
%Sep 18 04:12:08:212 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 18 04:12:21:291 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 18 19:06:19:168 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=219-OperateState=success-OperateEndTime=196146694; Operation completed.
%Sep 18 19:06:23:389 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=171-OperateState=success-OperateEndTime=196147117; Operation completed.
%Sep 18 21:52:23:433 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:41:42:843 09/18/2021 to 21:52:23:422 09/18/2021, the NTP server's IP address is 192.168.68.210.
%Sep 18 22:15:28:945 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:26:09:435 09/18/2021 to 22:15:28:934 09/18/2021, the NTP server's IP address is 192.168.68.210.
%Sep 19 02:01:21:688 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=79-OperateState=success-OperateEndTime=198636939; Operation completed.
%Sep 19 02:01:23:502 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=32-OperateState=success-OperateEndTime=198637120; Operation completed.
%Sep 19 07:25:26:011 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796740 229328 0 108 89912
-/+ buffers/cache: 1706720 319348
Swap: 0 0 0
%Sep 19 07:25:27:680 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 19 07:25:29:613 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 19 07:25:39:393 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796828 229240 0 0 89912
-/+ buffers/cache: 1706916 319152
Swap: 0 0 0
%Sep 19 07:25:40:934 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 19 07:25:44:840 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 19 07:25:58:519 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796756 229312 0 0 89912
-/+ buffers/cache: 1706844 319224
Swap: 0 0 0
%Sep 19 07:26:00:043 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 19 07:26:03:326 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 19 07:26:33:644 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 19 07:26:35:186 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 19 07:26:39:983 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 19 19:06:19:037 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=302-OperateState=success-OperateEndTime=204786674; Operation completed.
%Sep 19 19:06:22:895 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=197-OperateState=success-OperateEndTime=204787059; Operation completed.
%Sep 19 21:50:02:941 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:39:21:009 09/19/2021 to 21:50:02:930 09/19/2021, the NTP server's IP address is 192.168.68.210.
%Sep 19 22:21:31:942 2021 ZLSYR01-B1 NTP/5/NTP_SOURCE_LOST: Lost synchronization with NTP server with IP address 192.168.68.210.
%Sep 19 22:13:05:041 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:23:47:006 09/19/2021 to 22:13:05:030 09/19/2021, the NTP server's IP address is 192.168.68.210.
%Sep 19 22:13:05:041 2021 ZLSYR01-B1 NTP/5/NTP_LEAP_CHANGE: System Leap Indicator changed from 3 to 0 after clock update.
%Sep 19 22:13:05:041 2021 ZLSYR01-B1 NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 16 to 4 after clock update.
%Sep 20 02:01:22:114 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=98-OperateState=success-OperateEndTime=207276987; Operation completed.
%Sep 20 02:01:23:745 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=33-OperateState=success-OperateEndTime=207277150; Operation completed.
%Sep 20 15:49:32:830 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796912 229156 0 108 89912
-/+ buffers/cache: 1706892 319176
Swap: 0 0 0
%Sep 20 15:49:34:500 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 15:49:45:125 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 15:50:11:843 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796716 229352 0 0 89912
-/+ buffers/cache: 1706804 319264
Swap: 0 0 0
%Sep 20 15:50:13:368 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 15:50:21:060 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 16:11:15:657 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796744 229324 0 0 89912
-/+ buffers/cache: 1706832 319236
Swap: 0 0 0
%Sep 20 16:11:17:335 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 16:11:32:288 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 16:11:52:747 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796708 229360 0 0 89912
-/+ buffers/cache: 1706796 319272
Swap: 0 0 0
%Sep 20 16:11:54:276 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 16:12:06:036 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 16:12:26:737 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796784 229284 0 0 89912
-/+ buffers/cache: 1706872 319196
Swap: 0 0 0
%Sep 20 16:12:28:262 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 16:12:28:403 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 20 16:12:28:404 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 20 16:12:31:407 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 20 16:12:31:408 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 20 16:12:41:179 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 16:13:02:425 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796764 229304 0 0 89912
-/+ buffers/cache: 1706852 319216
Swap: 0 0 0
%Sep 20 16:13:03:954 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 20 16:13:17:197 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 20 19:06:20:857 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=87-OperateState=success-OperateEndTime=213426861; Operation completed.
%Sep 20 19:06:22:611 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=32-OperateState=success-OperateEndTime=213427036; Operation completed.
%Sep 20 21:48:34:448 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 21:37:51:083 09/20/2021 to 21:48:34:437 09/20/2021, the NTP server's IP address is 192.168.68.210.
%Sep 20 21:55:53:184 2021 ZLSYR01-B1 NTP/5/NTP_CLOCK_CHANGE: System clock changed from 22:06:36:457 09/20/2021 to 21:55:53:173 09/20/2021, the NTP server's IP address is 192.168.68.210.
%Sep 21 02:01:21:285 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=running2net-OperateTime=79-OperateState=success-OperateEndTime=215916897; Operation completed.
%Sep 21 02:01:23:113 2021 ZLSYR01-B1 CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=startup2net-OperateTime=32-OperateState=success-OperateEndTime=215917080; Operation completed.
%Sep 21 03:27:27:386 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796724 229344 0 108 89912
-/+ buffers/cache: 1706704 319364
Swap: 0 0 0
%Sep 21 03:27:28:512 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:28:513 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:29:066 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:27:32:512 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:32:513 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:34:510 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:34:512 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:37:510 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:37:511 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:39:511 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:39:513 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:27:42:507 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:42:507 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:27:43:235 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 03:28:03:777 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796808 229260 0 0 89912
-/+ buffers/cache: 1706896 319172
Swap: 0 0 0
%Sep 21 03:28:05:310 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:28:05:536 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:05:536 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:08:534 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:08:539 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:10:539 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:10:541 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:13:538 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:13:539 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:17:536 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:17:536 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to down.
%Sep 21 03:28:18:061 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 03:28:20:538 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:20:538 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 03:28:39:471 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796732 229336 0 0 89912
-/+ buffers/cache: 1706820 319248
Swap: 0 0 0
%Sep 21 03:28:41:000 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:28:53:103 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 03:29:42:323 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796848 229220 0 0 89912
-/+ buffers/cache: 1706936 319132
Swap: 0 0 0
%Sep 21 03:29:43:994 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:29:59:488 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 03:30:18:831 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 21 03:30:20:354 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:30:33:294 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 03:30:52:509 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 21 03:30:54:034 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 03:31:07:336 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:05:12:285 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 21 10:05:13:960 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:05:15:240 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:05:16:167 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796964 229104 0 0 89912
-/+ buffers/cache: 1707052 319016
Swap: 0 0 0
%Sep 21 10:05:17:391 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:05:18:928 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:05:19:263 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1797020 229048 0 0 89912
-/+ buffers/cache: 1707108 318960
Swap: 0 0 0
%Sep 21 10:05:20:805 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:05:23:568 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:05:45:542 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796796 229272 0 0 89912
-/+ buffers/cache: 1706884 319184
Swap: 0 0 0
%Sep 21 10:05:47:222 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:05:48:441 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:05:57:422 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Mem: 2026068 1796860 229208 0 0 89912
-/+ buffers/cache: 1706948 319120
Swap: 0 0 0
%Sep 21 10:05:58:964 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:06:07:061 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:06:26:750 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 21 10:06:28:296 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:06:29:540 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 10:06:34:512 2021 ZLSYR01-B1 DIAG/4/MEM_ALERT: -Slot=2;
system memory info:
Swap: 0 0 0
%Sep 21 10:06:36:038 2021 ZLSYR01-B1 DIAG/1/MEM_EXCEED_THRESHOLD: -Slot=2; Memory minor threshold has been exceeded.
%Sep 21 10:06:44:094 2021 ZLSYR01-B1 DIAG/1/MEM_BELOW_THRESHOLD: -Slot=2; Memory usage has dropped below minor threshold.
%Sep 21 17:21:13:125 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 2456.
%Sep 21 17:21:14:145 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 21 17:21:14:531 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
<ZLSYR01-B1>
<ZLSYR01-B1>
<ZLSYR01-B1>reboot
Now rebooting, please wait...
Connection closed.
<7506E>ssh 172.16.10.2
Username: admin
Trying 172.16.10.2 ...
Press CTRL+K to abort
Connected to 172.16.10.2 ...
Enter password:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<ZLSYR01-B1>
<ZLSYR01-B1>
<ZLSYR01-B1>
<ZLSYR01-B1>
<ZLSYR01-B1>dis log
<ZLSYR01-B1>dis logbuffer
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 0
Current messages: 14
%Sep 21 17:22:26:894 2021 ZLSYR01-B1 SYSLOG/6/SYSLOG_RESTART: System restarted --
H3C Comware Software.
%Sep 21 17:24:11:744 2021 ZLSYR01-B1 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 2, type is unknown.
%Sep 21 17:25:22:495 2021 ZLSYR01-B1 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on slot 2, type is SPU-100.
%Sep 21 17:25:28:436 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/0 changed to up.
%Sep 21 17:25:28:437 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/0 changed to up.
%Sep 21 17:25:28:567 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 17:25:28:568 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/1 changed to up.
%Sep 21 17:25:28:651 2021 ZLSYR01-B1 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/2 changed to up.
%Sep 21 17:25:28:653 2021 ZLSYR01-B1 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/2 changed to up.
%Sep 21 17:25:32:002 2021 ZLSYR01-B1 OPTMOD/4/MODULE_IN: -Slot=2; GigabitEthernet2/0/0: The transceiver is 1000_BASE_LX_SFP.
%Sep 21 17:25:32:327 2021 ZLSYR01-B1 OPTMOD/4/MODULE_IN: -Slot=2; GigabitEthernet2/0/3: The transceiver is 1000_BASE_LX_SFP.
%Sep 21 17:26:01:931 2021 ZLSYR01-B1 SSHS/6/SSHS_LOG: Accepted password for admin from 172.16.0.2 port 4115.
%Sep 21 17:26:02:954 2021 ZLSYR01-B1 SSHS/6/SSHS_CONNECT: SSH user admin (IP: 172.16.0.2) connected to the server successfully.
%Sep 21 17:26:03:341 2021 ZLSYR01-B1 SHELL/5/SHELL_LOGIN: admin logged in from 172.16.0.2.
<ZLSYR01-B1>
(0)
可以尝试先升级版本,解决老版本一些内存溢出问题;另外确认下是否是流量过大导致的
(0)
<ZLSYR01-B1>dis version H3C Comware Software, Version 7.1.064, Release 0821P15 Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved. H3C MSR56-60 uptime is 0 weeks, 0 days, 4 hours, 12 minutes Last reboot reason : User reboot Boot image: cfa0:/msr56-cmw710-boot-r0821p15.bin Boot image version: 7.1.064P80, Release 0821P15 Compiled Jul 22 2021 15:00:00 System image: cfa0:/msr56-cmw710-system-r0821p15.bin System image version: 7.1.064, Release 0821P15 Compiled Jul 22 2021 15:00:00 Slot 0: MPU-100 uptime is 0 weeks, 0 days, 4 hours, 12 minutes Last reboot reason : User reboot CPU ID: 0x3 2G bytes DDR3 SDRAM Memory 8M bytes Flash Memory PCB Version: 2.0 CPLD Version: 3.0 Basic BootWare Version: 1.71 Extended BootWare Version: 1.71 [SUBSLOT 0]CON (Hardware)2.0, (Driver)1.0, (CPLD)3.0 [SUBSLOT 0]AUX (Hardware)2.0, (Driver)1.0, (CPLD)3.0 [SUBSLOT 0]MGE0 (Hardware)2.0, (Driver)1.0, (CPLD)3.0 Slot 2: SPU-100 uptime is 0 weeks, 0 days, 4 hours, 11 minutes Last reboot reason : Power on CPU ID: 0x5 2G bytes DDR3 SDRAM Memory 8M bytes Flash Memory PCB Version: 2.0 CPLD Version: 2.0 Basic BootWare Version: 1.50 Extended BootWare Version: 1.50 [SUBSLOT 0]GE2/0/0 (Hardware)2.0, (Driver)1.0, (CPLD)2.0 [SUBSLOT 0]GE2/0/1 (Hardware)2.0, (Driver)1.0, (CPLD)2.0 [SUBSLOT 0]GE2/0/2 (Hardware)2.0, (Driver)1.0, (CPLD)2.0 [SUBSLOT 0]GE2/0/3 (Hardware)2.0, (Driver)1.0, (CPLD)2.0 [SUBSLOT 0]CELLULAR2/0/0 (Hardware)2.0, (Driver)1.0, (CPLD)2.0 [SUBSLOT 0]CELLULAR2/0/1 (Hardware)2.0, (Driver)1.0, (CPLD)2.0
CPU ID: 0x3
PCB Version: 2.0
CPLD Version: 3.0
CPU ID: 0x5
PCB Version: 2.0
CPLD Version: 2.0
(0)
display process mem看看是哪个进程高,接口利用率、cpu利用率情况如何都看一下,条件允许的话,诊断信息可收集一份保存到设备导出来看看
dis process memory查看哪些进程对于内存的使用率高。
dis process cpu查看哪些进程对于CPU的使用率高。
dis version看下路由器的软件版本是否最新,可考虑升级到最新。
如果升级版本还出现这个问题,检查设备配置是否有其他特殊的地方,并收集产品型号、序列号、诊断信息文件反馈400
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
