WA5530S 胖模式 802.1X 用户无法认证
2021-09-22提问
  • 1收藏,1601浏览
AP报错
-Username=<username>-UserMAC=<usermac>-BSSID=<bssid>-SSID=<SSID>-APName=fatap-RadioID=1-VLANID=50; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 26.
后端 freeradius 服务器报错
(9) eap: Peer sent EAP Response (code 2) ID 5 length 17
(9) eap: Continuing tunnel setup
(9) [eap] = ok
(9) } # authorize = ok
(9) Found Auth-Type = eap
(9) # Executing group from file /etc/raddb/sites-enabled/default
(9) authenticate {
(9) eap: Expiring EAP session with state 0x9b2314ae98260dea
(9) eap: Finished EAP session with state 0x9b2314ae98260dea
(9) eap: Previous EAP request found for state 0x9b2314ae98260dea, released from the list
(9) eap: Peer sent packet with method EAP PEAP (25)
(9) eap: Calling submodule eap_peap to process data
(9) eap_peap: Continuing EAP-TLS
(9) eap_peap: Peer indicated complete TLS record size will be 7 bytes
(9) eap_peap: Got complete TLS record (7 bytes)
(9) eap_peap: [eaptls verify] = length included
(9) eap_peap: <<< recv TLS 1.2 [length 0002]
(9) eap_peap: ERROR: TLS Alert read:fatal:unknown CA
(9) eap_peap: TLS_accept: Need to read more data: error
(9) eap_peap: ERROR: Failed in __FUNCTION__ (SSL_read): error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca
(9) eap_peap: TLS - In Handshake Phase
(9) eap_peap: TLS - Application data.
(9) eap_peap: ERROR: TLS failed during operation
(9) eap_peap: ERROR: [eaptls process] = fail
(9) eap: ERROR: Failed continuing EAP PEAP (25) session. EAP sub-module failed
(9) eap: Sending EAP Failure (code 4) ID 5 length 4
(9) eap: Failed in EAP select
(9) [eap] = invalid
(9) } # authenticate = invalid
(9) Failed to authenticate the user
(9) Using Post-Auth-Type Reject
这款应该是支持802.1X的,然而和不支持的 WA6320C 报了同样的错
https://zhiliao.h3c.com/questions/dispcont/141135
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
配置如下(部分字段隐去)
version 7.1.064, Release 2444P01
sysname H3C
wlan global-configuration
telnet server enable
dot1x
dot1x authentication-method eap
dot1x retry 3
dot1x timer supp-timeout 2
dot1x timer tx-period 4
lldp global enable
lldp hold-multiplier 8
password-recovery enable
vlan 1
vlan 50
vlan 120
wlan service-template 1
ssid H3C
service-template enable
ssid
vlan 120
user-isolation enable
akm mode psk
preshared-key pass-phrase cipher
cipher-suite ccmp
cipher-suite tkip
security-ie rsn
security-ie wpa
ssid
vlan 50
akm mode dot1x
cipher-suite ccmp
security-ie rsn
client-security authentication-mode dot1x
dot1x domain<***.***>
interface NULL0
interface Vlan-interface1
ip address 192.168.0.50 255.255.255.0
interface Vlan-interface50
ip address 192.168.50.234 255.255.255.0
port link-type trunk
port trunk permit vlan 1 50 60 120
port-isolate enable
port-isolate enable
interface WLAN-Radio1/0/1
service-template
service-template
channel band-width dual-80
interface WLAN-Radio1/0/2
service-template
service-template
interface WLAN-Radio1/0/3
service-template
service-template
interface WLAN-Mesh1
interface WLAN-Mesh2
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
line vty 0 31
authentication-mode scheme
line vty 32 63
rib
ip route-static 0.0.0.0 0 192.168.50.254
radius session-control enable
radius scheme<***.***>
primary authentication 192.168.10.152 key cipher
primary accounting 192.168.10.152 key cipher
user-name-format keep-original
nas-ip 192.168.50.234
domain<***.***>
authorization-attribute idle-cut 15 1024
authentication lan-access radius-scheme<***.***>
authorization lan-access radius-scheme<***.***>
accounting lan-access radius-scheme<***.***>
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash
service-type telnet http https
ip http enable
ip https enable
undo attack-defense tcp fragment enable
return
锤哥 七段
粉丝:16人 关注:5人
报错误26一般是因为:用户名或密码错误/认证类型错误/服务器上没有添加设备IP地址/服务模板下认证域配置错误
radius服务器上标红的错误提示是证书的问题。 eap_peap: ERROR: TLS Alert read:fatal:unknown CA eap_peap: ERROR: Failed in __FUNCTION__ (SSL_read): error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca
zhiliao_CEiLkc 发表时间:2021-09-22
粉丝:39人 关注:6人
802.1X认证不通过,以下是排查要点,请参考:
1、检查设备到AAA服务器的路由是否正常可达。
2、检查设备802.1X配置中是否已正确指向到AAA服务器,且秘钥是否正确。
3、检查domain的配置中是否正确调用的radius的scheme配置方案。
4、检查domain是否配置为默认域。
都检查了,还是不行
