s5500不断重启
  • 1收藏,909浏览
S5500-24p-winnet交换机
开机后不断重启,偶尔能成功开机,超级终端能进入sys视图,web登陆成功,正常时间约2分钟,之后出现下面的信息,然后自动重启,
================= exception info (no:  0  idx:  0) =================
Exception Number:          0x0A
Exception Name:            Reserved instruction exception
Exception Instruction:     0x80E5FDA0
Exception Slot:            1
Exception VCpu:            0
Exception Task:            HDQ4 (TID: 128)
Exception Stack Base:      0x83abcfa8
Exception Time:            2000-04-26  12:01:46
Exception Tick:            0x3(CPU Tick High) 0x57df708f(CPU Tick Low)
Register contents:
Reg:     zero, Val = 0x00000000 ; Reg:       at, Val = 0x1000cc00 ;
[WU1] Reg:       v0, Val = 0x00000001 ; Reg:       v1, Val = 0x00000001 ;
Reg:       a0, Val = 0x85ea7320 ; Reg:       a1, Val = 0xa4b2d938 ;
Reg:       a2, Val = 0x00000002 ; Reg:       a3, Val = 0x85ea6ee8 ;
Reg:       t0, Val = 0xa4b2d500 ; Reg:       t1, Val = 0x00000000 ;
Reg:       t2, Val = 0xa4b2d500 ; Reg:       t3, Val = 0x00000000 ;
Reg:       t4, Val = 0x00000000 ; Reg:       t5, Val = 0x00000000 ;
Reg:       t6, Val = 0xffffffff ; Reg:       t7, Val = 0x00000001 ;
Reg:       s0, Val = 0x83abbec4 ; Reg:       s1, Val = 0x83abc078 ;
Reg:       s2, Val = 0x83350000 ; Reg:       s3, Val = 0xa4b2d500 ;
Reg:       s4, Val = 0x83abbeca ; Reg:       s5, Val = 0x0000043a ;
Reg:       s6, Val = 0x00000003 ; Reg:       s7, Val = 0x00000001 ;
Reg:       t8, Val = 0xffffffff ; Reg:       t9, Val = 0x8010e918 ;
Reg:       k0, Val = 0x00000001 ; Reg:       k1, Val = 0x00000001 ;
Reg:       gp, Val = 0x801f6000 ; Reg:       sp, Val = 0x83abbe88 ;
Reg:       s8, Val = 0xffffffff ; Reg:       ra, Val = 0x819e8b24 ;
Reg:       pc, Val = 0x80e5fda0 ; Reg:       sr, Val = 0x1000cc03 ;
Reg:    cause, Val = 0x00800028 ; Reg:    cntxt, Val = 0x00000017 ;
Reg:    fpcsr, Val = 0x00000000 ; Reg:    badva, Val = 0x0000043a ;
Reg: reserve0, Val = 0x00000001 ; Reg: reserve1, Val = 0x0000043a ;
Reg: reserve2, Val = 0x81c10850 ; Reg: reserve3, Val = 0x00000017 ;
Dump stack(total 512Bytes,16Bytes/line):
0x83abbe88: 98 c1 ab 83 f4 0f 03 81 00 00 00 00 00 00 00 00
0x83abbe98: b8 be ab 83 01 00 00 00 17 00 00 00 98 96 bc 87
0x83abbea8: 17 00 90 00 3c bf ab 83 01 00 00 00 00 00 00 00
0x83abbeb8: 17 00 00 00 30 4c cf 81 00 00 00 00 a0 36 9f 83
0x83abbec8: b7 dc 01 00 00 00 00 00 00 00 00 00 00 00 00 00
0x83abbed8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x83abbee8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x83abbef8: 00 00 00 00 00 00 00 00 00 00 00 00 d4 56 cf 81
0x83abbf08: 80 bf ab 83 17 00 90 00 b4 32 c1 81 84 32 c1 81
0x83abbf18: a0 43 ac 81 00 00 00 00 00 00 00 00 00 00 00 00
0x83abbf28: 03 00 00 00 78 6a f5 83 62 00 00 00 ff ff ff ff
0x83abbf38: 17 00 00 00 01 00 00 00 00 00 00 00 17 00 00 00
0x83abbf48: ff ff ff ff e0 bf ab 83 68 c0 ab 83 68 c0 ab 83
0x83abbf58: 17 00 90 00 00 f6 e8 85 78 c0 ab 83 03 00 00 00
0x83abbf68: 98 c1 ab 83 03 00 00 00 3c 01 bb 81 18 7b ba 81
0x83abbf78: a0 bf ab 83 78 6a f5 83 01 00 00 00 00 00 00 00
0x83abbf88: 05 00 00 00 00 1d 9a 82 17 00 90 00 00 00 00 00
0x83abbf98: 00 00 00 00 00 00 00 00 f0 72 9e 81 44 71 9e 81
0x83abbfa8: 62 00 00 00 ff ff ff ff ff ff ff ff 00 00 00 00
0x83abbfb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x83abbfc8: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff
0x83abbfd8: 68 c0 ab 83 17 00 90 00 17 00 90 00 00 f6 e8 85
0x83abbfe8: 78 c0 ab 83 18 7b ba 81 17 00 00 00 ff ff ff ff
0x83abbff8: 01 00 00 00 00 00 62 83 17 00 90 00 00 f6 e8 85
0x83abc008: 78 c0 ab 83 03 00 00 00 98 c1 ab 83 03 00 00 00
0x83abc018: 84 9a 9e 81 70 9a 9e 81 00 00 23 80 08 00 00 00
0x83abc028: 34 41 1d 80 54 fc eb 80 78 c0 ab 83 00 00 00 00
0x83abc038: 00 cc 00 10 00 00 00 00 e8 6e ea 85 3a 04 00 00
0x83abc048: 01 00 00 00 00 00 00 00 17 00 00 00 00 00 00 00
0x83abc058: c0 64 64 fe c0 64 64 fe 00 00 00 00 00 00 00 00
0x83abc068: 17 00 90 00 ff ff ff ff ff ff ff ff 00 00 00 00
0x83abc078: 01 00 00 00 17 00 00 00 00 00 00 00 00 00 00 00
Print layers of stack when exception:
Stack Top = 0x83abbe88, Return Address = 0x80e5fda0
Stack Top = 0x83abbe88, Return Address = 0x819e8b24
Stack Top = 0x83abc020, Return Address = 0x819e9a84
Stack Top = 0x83abc150, Return Address = 0x819eb7c4
Stack Top = 0x83abc2f8, Return Address = 0x819dcf44
Stack Top = 0x83abc328, Return Address = 0x80cbf8e0
Stack Top = 0x83abc358, Return Address = 0x80cbffec
Stack Top = 0x83abc3a0, Return Address = 0x80c34c5c
Stack Top = 0x83abc4e8, Return Address = 0x80c36010
Stack Top = 0x83abc5f0, Return Address = 0x8160ddb8
Stack Top = 0x83abc768, Return Address = 0x8160b460
Stack Top = 0x83abc800, Return Address = 0x8164cfb0
Stack Top = 0x83abc830, Return Address = 0x80b35b88
Stack Top = 0x83abc870, Return Address = 0x80b2df88
Stack Top = 0x83abc8a0, Return Address = 0x80b2e0e8
Stack Top = 0x83abc8c0, Return Address = 0x815f2818
Stack Top = 0x83abc8e0, Return Address = 0x815f2a10
Stack Top = 0x83abc908, Return Address = 0x80c86520
Stack Top = 0x83abc950, Return Address = 0x80c866ac
Stack Top = 0x83abc978, Return Address = 0x80c86d08t
自动重启后,经常进入下面页面:
Starting......
            *        H3C S5500-24P-WiNet BOOTROM, Version 621         *
            Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd.
            Creation date   : Nov 12 2013, 02:03:22
            CPU Clock Speed : 264MHz
            BUS Clock Speed : 33MHz
            Memory Size     : 128MB
            Mac Address     : 84d93183b24f
Press Ctrl-B to enter Boot Menu... 0
Auto-booting...
Decompress Image............................................................................................................................................................................................................................................................................................................................................................................................................................................................................. .......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
...............................................something wrong when decompressing!!!
No correct default file to boot!
BootRom password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
  BOOT  MENU
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter bootrom upgrade menu
7. Skip current configuration file
8. Reserved
9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System
Ctrl+D: Enter Debugging Mode
Ctrl+T: Enter Board Test Environment
Enter your choice(0-9):
 请教是软件问题还是硬件问题?有解决方案吗?
版本丢失了,重新导入下版本吧
xmodem导入过程直接没有反应,断开连接了。
