H3C W2620
2021-10-02提问
  • 1收藏,824浏览
BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa2600a_fit.bin!.......... ...................................................................... The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ....................................................................Done! System application is starting... Startup configuration file does not exist. User interface con0 is available. Press ENTER to get started.怎么去掉AC权限?
Xcheng 九段
粉丝:122人 关注:3人
默认情况下。fit没还没注册到ac可直接登录。
如果注册到ac前未登录则需要在ac上配置才能登录/或通过断开ac连接方式规避。
如ac侧开启登录的话 需要在ac配置
v5
sys
_h
wlan ap-e ap名称 ex e
wlan ap-e ap名称 telnet en
然后就能直接telnet登录对应ap了。
V7
sys
pr
wlan ap-e ap名称/all e e
#all 参数选项需要ac版本较高才支持,否需要逐个ap名称方式规避。
然后就能telnet到ap了,缺省密码为h3capadmin
粉丝:13人 关注:2人
是要瘦切胖吗,可以参考这个https://zhiliao.h3c.com/topic/huati/1249
