MSR3600 IPSEC VPN
2021-10-11提问
  • 1收藏,645浏览
对齐方式
  • 靠左
  • 居中
  • 靠右
问题
1)该VPN用于分公司联系,原来一直正常,电信过来调试不小心改动。
 2)本地PPOE固定IP,对方固定 IP
3)目前可以PING 对方IP,没有问题,但show ike sa 没有连接,VPN不正常
[H3C]show cur
 version 7.1.064, Release 0605P21
 sysname H3C
 dialer-group 2 rule ip permit
 dhcp server always-broadcast
 dns proxy enable
 password-recovery enable
vlan 1
vlan 100
dhcp server ip-pool lan1
 gateway-list 192.168.0.1
 network 192.168.0.0 mask 255.255.254.0
 address range 192.168.1.2 192.168.1.254
 dns-list 192.168.0.1
controller Cellular0/0
interface Aux0
interface Dialer0
 ppp chap password cipher $c$3$iVdlrqz4fgkYUC9D0bxLAgy0HyzZS2+Zrrya
 ppp chap user XXXX000XXXX0
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user 880000073610 password cipher $c$3$hja9Bd6cn1imIHr5zB/I8HW3FhCVfRU233ms
 dialer bundle enable
 dialer-group 2
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 nat outbound
interface Dialer2
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.1 255.255.254.0
 tcp mss 1280
interface Vlan-interface100
 mtu 1300
 ip address 192.188.2.98 255.255.255.0
 tcp mss 1024
interface GigabitEthernet0/0
 port link-mode route
 mtu 1300
 tcp mss 1024
 pppoe-client dial-bundle-number 0
 pppoe-client dial-bundle-number 2
 ipsec apply policy poli
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/27
interface GigabitEthernet0/3
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Dialer0
acl advanced 3000
 rule 0 permit ip source 192.188.2.0 0.0.0.255 destination 192.188.1.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.188.2.0 0.0.0.255 destination 192.188.1.0 0.0.0.255
 rule 10 permit ip
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
 password-control complexity user-name check
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type telnet http
ipsec transform-set trans
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy poli 1 isakmp
 transform-set trans
 security acl 3000
 remote-address XXX.XX.XXX.4
 ike-profile prof
ike profile prof
 keychain keyq
 match remote identity address XXX.XX.XXX.4 255.255.255.0
 proposal 1
ike proposal 1
 dh group5
ike keychain keyq
 pre-shared-key address XXX.XX.XXX.4 255.255.255.0 key cipher $c$3$DRPz8/Vvo1+MoZgPro7Hqtb9wfm+R0LtWdNCFUB1+g==
 ip http enable
wlan global-configuration
 control-address disable
wlan ap-group default-group
 cloud-management server domain oasis.h3c.com
粉丝:39人 关注:6人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
对方IP能PING通,下一步查哪个
zhiliao_9qyxC2 发表时间:2021-10-11
粉丝:11人 关注:0人
之前配置是否有做备份?通过文件对比工具看下什么配置发生变动。ike sa 和ipsec sa是否有删除流量重新触发下试试?再不行只能收集下debug信息,看什么问题导致
给 nat outbound 后加 已经创建的acl 3001 试试
