v7控制器+本地转发+portal认证如何配置
2018-07-05提问
  • 1收藏,1556浏览
网络结构如图,总部核心与分布核心三层互联,AP想采用本地转发,无线用户采用portal认证,V7版本的谁有开局或者模板,在网站上找了个V5版本的但是好多地方感觉看不懂。
下面是网站V5的开局
      LSW
vlan 10
vlan 20
vlan 30
vlan 138
interface Bridge-Aggregation4
 port link-type trunk
 port trunk permit vlan all
interface Vlan-interface10
 ip address 138.10.1.1 255.255.0.0
interface Vlan-interface20
 ip address 138.20.1.1 255.255.0.0
interface Vlan-interface30
 ip address 138.30.1.1 255.255.0.0
interface Vlan-interface138
 ip address 8.138.1.2 255.255.0.0
interface Ten-GigabitEthernet4/0/1
 port link-mode bridge
 port link-aggregation group 4
interface Ten-GigabitEthernet4/0/2
 ip route-static 8.0.0.0 255.0.0.0 8.138.1.1
·              AC
 portal server pt ip 8.1.1.50 key simple 123456 url http://8.1.1.50:8080/portal
 portal free-rule 1 source interface Bridge-Aggregation1 destination any
 portal host-check wlan
 wlan client learn-ipaddr enable
vlan 10
vlan 30
dhcp server ip-pool 30
 network 138.30.0.0 mask 255.255.0.0
 gateway-list 138.20.1.3   这个地方network和网关能不一个段吗,这个网关是路由器的网关,在控制器上指定吗
 dns-list 138.20.1.3
 dns-list 8.1.1.5
radius scheme portal
 primary authentication 8.1.1.50
 primary accounting 8.1.1.50
 key authentication simple 123456
 key accounting simple 123456
 user-name-format without-domain
 nas-ip 138.10.1.80
domain portal
 authentication portal radius-scheme portal
 authorization portal radius-scheme portal
 accounting portal radius-scheme portal
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
wlan service-template 30 clear
 ssid portal-local
 bind WLAN-ESS 30
 client forwarding-mode local
 client dhcp-server centralized
 service-template enable
 ip address 138.10.1.80 255.255.0.0
 ip address 138.30.1.80 255.255.0.0
 portal server pt method direct
 portal domain portal
 portal nas-ip 138.10.1.80
 portal forwarding-mode local
 port link-aggregation group 1
interface WLAN-ESS30
 port access vlan 30
wlan ap ap1 model WA2620E-AGN id 1
 serial-id 210235A42MB108000002
 map-configuration apcfg.txt
 radio 1
  channel 161
  service-template 30
  radio enable
 radio 2
 ip route-static 0.0.0.0 0.0.0.0 138.10.1.1
 arp-snooping enable
 dhcp enable
·              Router
dhcp server ip-pool 20
 network 138.20.0.0 mask 255.255.0.0
 option 43 hex 80070000 018A0A01 50
interface GigabitEthernet0/0
 port link-mode route
 ip address 138.10.1.3 255.255.0.0
interface GigabitEthernet0/1
 ip address 138.20.1.3 255.255.0.0
 ip route-static 0.0.0.0 255.0.0.0 138.10.1.1
 dhcp enable
·              SW
vlan 20
vlan 30
 ip address 138.20.1.2 255.255.0.0
 ip address 138.30.1.2 255.255.255.0 这个VLAN30跨三层怎么到核心和AC上的
 description routeg0/1
 description ap-portal-local
 port trunk pvid vlan 20
 poe enable
 ip route-static 0.0.0.0 0.0.0.0 138.20.1.3
粉丝:2人 关注:1人
官网也有本地转发时的portal认证配置:http://www.h3c.com/cn/d_201803/1072737_30005_0.htm
粉丝:148人 关注:3人
参考这个目录下的文件
http://www.h3c.com/cn/Service/Document_Software/TechnicalInfo/PorductMaintanInfo/WLAN/
无线V7一本通,里面的V7典型配置 章节里面 有远程portal+本地转发的典型配置案例;
V5的那个dhcp server 配置看上去确实存在不对的地方。
