思科配置翻译ip tacacs source-interface Loopback1
2021-10-21提问
  • 1收藏,2143浏览
ip tacacs source-interface Loopback1   翻译为h3c命令是什么
oneday 二段
华三交换机tacacs+认证配置
[H3C]
#开启ssh服务
ssh server enable
#配置tacacs认证模板
hwtacacs scheme acs
primary authentication 192.168.147.135 49 single-connection key simple tacacs@123
primary authorization 192.168.147.135 49 single-connection key simple tacacs@123
primary accounting 192.168.147.135 49 single-connection key csimple tacacs@123
user-name-format without-domain
timer response-timeout 3
nas-ip 192.168.147.134
domain acs
authentication default hwtacacs-scheme acs local
authorization default hwtacacs-scheme acs local
accounting default hwtacacs-scheme acs local
domain system
#全局下默认调用tacacs认证
domain default enable acs
# 配置本地用户
local-user admin class manage
password simple Admin@123
service-type ssh terminal
# vty线路下调用tacacs认证
line vty 0 63
authentication-mode scheme
protocol inbound ssh
command authorization
command accounting
思科交换机tacacs+认证配置
Cisco#
! 开启tacacs认证
feature tacacs+
!配置本地用户
username admin password 0 Admin@123 role network-admin
ip domain-lookup
ip tacacs source-interface loopback0
tacacs-server timeout 3
tacacs-server host 192.168.147.135 key 0 tacacs@123 port 49
aaa group server tacacs+ tacacs-server
server 192.168.147.135
! 全局调用tacacs认证
aaa authentication login default group tacacs-server local
aaa authentication login console local
aaa authorization config-commands default group tacacs-server local
aaa authorization commands default group tacacs-server local
aaa accounting default group tacacs-server
粉丝:39人 关注:6人
以下是H3C交换机配置tacacs的举例:
组网及说明
本案例使用S6800交换机部署hwtacacs,与IMC TAM进行联动,达到安全管理设备的效果。
IMC版本为PLAT 7.3 E0506P03
S6800版本信息如下:
H3C Comware Software, Version 7.1.045, Release 2418P05
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S6800-4C uptime is 233 weeks, 0 days, 6 hours, 17 minutes
Last reboot reason : USER reboot
Boot image: flash:/s6800-cmw710-boot-r2418p05.bin
Boot image version: 7.1.045, Release 2418P05
  Compiled Jun 09 2015 12:06:42
System image: flash:/s6800-cmw710-system-r2418p05.bin
System image version: 7.1.045, Release 2418P05
特别说明:
 1、要部署hwtacacs的设备已经在IMC进行了纳管。
 2、要部署hwtacacs的设备已经和IMC网络互通。
 3、要部署hwtacacs的设备需要提前开启远程管理的功能,并创建用户及赋予权限,待设备和服务器都部署完tacacs后,需要使用服务器上的tacacs账号对设备进行远程登陆管理,当tacacs服务器挂掉了,才可以使用设备的本地用户远程登陆管理。
配置步骤
1、授权场景条件:
设备区域管理、设备类型管理、授权时段策略管理
2、授权命令配置:
Shell profile配置、命令集配置
3、设备管理:
配置共享密钥、绑定设备区域、绑定设备类型
4、添加用户名、密码
5、S6800部署tacacs
配置关键点
IMC侧部署如下:
配置“授权场景条件”
添加“设备区域管理”
设置“区域名称”
设置“设备类型管理”
增加
设置“授权时段策略管理”
增加,设置“授权时段策略名称”、“生效时间”、“失效时间”
设置“授权命令配置”-shell profile配置”
设置“shell profile名称”-“授权级别”
设置“命令集配置”
设置“命令集名称”、“缺省授权方式”
配置“设备管理”
增加设备,设置“共享密钥”、“确认共享密钥”,绑定“设备区域”、“设备类型”
配置“授权管理”
绑定“设备区域”-“设备类型”-“授权时段”-shell profile-“授权命令集”
配置“用户设备分组”,设置“分组名称”-“授权策略”
设置“设备用户管理”-“所有设备用户”
设置“账号名”-“登陆密码”-“登陆密码确认”-“设备用户分组”-“用户的授权策略”
S6800 hwtacacs配置如下:
1、部署hwtacacs:
hwtacacs scheme shebeiguanli
 primary authentication 10.190.8.7
 primary authorization 10.190.8.7
 primary accounting 10.190.8.7
 key authentication cipher $c$3$6rB1jZTbXYAS18iQYdh+izGjX6L4us+8BxaOQwE=
 key authorization cipher $c$3$lX9iIYf/1Ex6vIIN1NykEnxEU0hLmjgwDeJXeSE=
 key accounting cipher $c$3$HZUG2r4NKeXtw9RlZNDWGZvqOpwh4GqfdxIIjIs=
 nas-ip 10.190.0.15
2、配置domain:
domain tamdm
 authentication login hwtacacs-scheme shebeiguanli local
 authorization login hwtacacs-scheme shebeiguanli local
 accounting login hwtacacs-scheme shebeiguanli local
 authorization command hwtacacs-scheme shebeiguanli local
 accounting command hwtacacs-scheme shebeiguanli
3、启用domain默认域:
domain default enable tamdm
4、查看hwtacacs显示信息:
dis hwtacacs scheme
Total 1 TACACS schemes
HWTACACS Scheme Name  : shebeiguanli
  Index : 0
  Primary Auth Server:
    Host name: Not Configured
    IP  : 10.190.8.7      Port: 49     State: Active
    VPN Instance: Not configured
    Single-connection: Disabled
  Primary Author Server:
  Primary Acct Server:
  VPN Instance                          : Not configured
  NAS IP Address                        : 10.190.0.15
  Server Quiet Period(minutes)          : 5
  Realtime Accounting Interval(minutes) : 12
  Response Timeout Interval(seconds)    : 5
  Username Format                       : without-domain
5、查看domain显示信息:
dis domain tamdm
Domain:tamdm
 State: Active
 login   Authentication Scheme:  tacacs: shebeiguanli, local
 login   Authorization  Scheme:  tacacs: shebeiguanli, local
 login   Accounting     Scheme:  tacacs: shebeiguanli, local
 command Authorization  Scheme:  tacacs: shebeiguanli, local
 command Accounting     Scheme:  tacacs: shebeiguanli
 default Authentication Scheme:  local
 default Authorization  Scheme:  local
 default Accounting     Scheme:  local
 Authorization attributes :
  Idle-cut : Disable
至此,S6800 hwtacacs典型组网配置案例已完成!
