掉电重启后7606之间链路不通,插拔光模块后ospf状态为full链路恢复。 为什么必须要插拔模块后链路才会起来?
2021-10-26提问
  • 1收藏,825浏览
益胖 一段
7606掉电后链路不通,插拔光模块后ospf邻居状态为full,链路恢复。
两台7606之间的互联vlan为265 两台都将265宣告到ospf1中
出问题的是LKZC这台
配置如下
[LKZC_S7606]dis cu con ospf
ospf 1 router-id 1.1.1.35
 import-route direct
 area 0.0.0.0
  network 172.23.254.60 0.0.0.3
  network 172.23.247.24 0.0.0.3
interface Vlan-interface265
 ip address 172.23.254.62 255.255.255.252
interface GigabitEthernet3/1/1
 port link-mode bridge
 description to_LK S7606
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 3 11 21 to 22 31 to 32 62 to 64 110 132 to 134 231 241 265
 port trunk permit vlan 290 315 396 1901 to 1932 2009 4021
 speed 1000
 duplex full
 dhcp-snooping trust
[LKZ_S7606]dis cu con ospf
ospf 1 router-id 1.1.1.12
 import-route direct
 area 0.0.0.0
  network 172.23.247.20 0.0.0.3
  network 172.23.254.4 0.0.0.3
  network 172.23.254.80 0.0.0.3
interface GigabitEthernet3/0/22
 description to_zhangcunS7606
 port link-type hybrid
 undo port hybrid vlan 1
 port hybrid vlan 11 21 to 22 31 to 32 62 to 64 110 132 to 133 231 241 265 290 tagged
 port hybrid vlan 315 396 1906 2009 4021 tagged
 qinq transparent-vlan 21 to 22 31 to 32
 description TO-LKZC
 ip address 172.23.254.61 255.255.255.252
粉丝:39人 关注:6人
可能光模块有问题,更换光模块看下是否还出现这个情况。
如果还出现,看下交换机的版本是否最新,可考虑升级到最新。
粉丝:226人 关注:0人
您好,这是链路动荡导致的
是指物理光纤链路还是别的链路 这两个设备之间光纤直连的
益胖 发表时间:2021-10-26
益胖 一段
 GigabitEthernet3/1/1: The transceiver is absent.
%Oct 26 10:53:07:070 2021 LKZC_S7606 OPTMOD/4/MODULE_IN: -Slot=3;
 GigabitEthernet3/1/1: The transceiver is 1000_BASE_LX_SFP.
%Oct 26 10:53:12:568 2021 LKZC_S7606 IFNET/3/LINK_UPDOWN: GigabitEthernet3/1/1 link status is UP.
%Oct 26 10:53:23:852 2021 LKZC_S7606 OSPF/5/OSPF_NBR_CHG: OSPF 11 Neighbor 172.23.251.61(Vlan-interface315) from Loading to Full.
%Oct 26 10:53:23:927 2021 LKZC_S7606 OSPF/5/OSPF_NBR_CHG: OSPF 10 Neighbor 172.23.252.61(Vlan-interface290) from Loading to Full.
%Oct 26 10:53:24:755 2021 LKZC_S7606 OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 172.23.254.61(Vlan-interface265) from Loading to Full.
