secpath f1000-s-ai web页面无法登录。
2021-10-26提问
  • 1收藏,725浏览
粉丝:0人 关注:6人
[h3c]display interface GigabitEthernet0/0 current state: UP Line protocol current state: UP Description: GigabitEthernet0/0 Interface The Maximum Transmit Unit is 1500 Internet Address is 192.168.0.1/24 Primary IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 586a-b105-8cca IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 586a-b105-8cca Media type is twisted pair, loopback not set, promiscuous mode not set 1000Mb/s, Full-duplex, link type is autonegotiation Output flow-control is disabled, input flow-control is disabled Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0 Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0 Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0 Last clearing of counters: Never Peak value of input: 1318 bytes/sec, at 2021-10-26 8:14:14 Peak value of output: 18 bytes/sec, at 2021-10-26 7:31:59 Last 300 seconds input rate 51 bytes/sec, 408 bits/sec, 0 packets/sec Last 300 seconds output rate 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 675 packets, 0 jumboes, 54764 bytes, - buffers 32 broadcasts, 297 multicasts, 0 pauses 0 errors, 0 runts, 0 giants 0 crc, 0 align errors, 0 overruns 0 dribbles, 0 drops, 0 no buffers Output:25 packets, 1150 bytes, - buffers 2 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 underruns, 0 collisions 0 deferred, 0 drops, 0 lost carriers
能否帮助看一下原因出在哪。
aUtiSm 九段
粉丝:48人 关注:1人
命令行登进去看下https或http服务是否正常开启,端口号是否更改
粉丝:119人 关注:1人
你这个只是接口信息,web登录不了,检查下服务有没有起来
粉丝:0人 关注:6人
<h3c>display ip http
HTTP port: 80
Basic ACL: 0
Current connection: 0
Operation status: Running
<h3c>display ip https
HTTPS port: 443
SSL server policy:
Certificate access-control-policy:
Basic ACL: 0
Operation status: Stopped
帮我看下,什么原因?
谢谢
粉丝:39人 关注:6人
WEB登录失败,以下是排查要点,请参考:
1、检查用户名、密码是否已输入正确。
2、console登录防火墙确认是否已赋予了WEB权限,如果没有,以下是赋予权限的参考命令:
local-user admin
service-type http https
3、更换其他浏览器、清理浏览器缓存、更新浏览器flash
4、看下防火墙的软件版本是否最新,可考虑升级到最新。
<H3C>sys System View: return to User View with Ctrl+Z. [H3C]local-user admin [H3C-luser-admin]service-type http https ^ % Unrecognized command found at '^' position. [H3C-luser-admin] 命令不好使呀老师,怎么回事?
山东的老干肉 发表时间:2021-10-26
