MSR2630 S3600链接问题
2017-07-27提问
  • 1收藏,3122浏览
中小型企业 MSR 2630做主路由进行NAT转换 下联 S3600  (S3600做DHCP池进行地址下发)s3100 开 TRUNK 现在 S3600 和 S3100可以正常工作但是MSR2630和 s3600不通
Line aux0 is available.
Press ENTER to get started.
Password:
<H3C>%Jul 27 10:03:04:074 2017 H3C SHELL/5/SHELL_LOGIN: TTY logged in from aux0.
<H3C>dis cu
 version 7.1.059, Release 0304
 sysname H3C
 password-recovery enable
vlan 1
controller Cellular0/0
interface Aux0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 ip address 172.16.24.92 255.255.255.0
 nat outbound 2000
interface GigabitEthernet0/1
 ip address 192.168.1.2 255.255.255.0
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
 authentication-mode password
 set authentication password hash $h$6$H9fk/DebmoZoD7Vb$eIkFGpw/Dw3JuVPYa97BHyvg
KhN9DXDt3sKFrtdETipxQjU8UpGUOZ+5bKbdzIPT1rWDeYGrXKcTSIF4ygXLsg==
line vty 0 63
 ip route-static 0.0.0.0 0 172.16.24.3
 ip route-static 192.168.1.0 24 192.168.1.3
acl basic 2000
 rule 10 permit source 0.0.10.0 192.168.20.254
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
return
路由器设置
<H3C>
#Jan  1 01:23:36:174 2010 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Jan  1 01:23:36:315 2010 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
<H3C>dis cu
 version 5.20, Release 2108P01
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
vlan 1
vlan 10
vlan 20
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool 1
 network 192.168.10.0 mask 255.255.255.0
 gateway-list 192.168.10.3
 dns-list 219.149.194.55 219.146.0.130
 domain-name APdhcp
 expired unlimited
dhcp server ip-pool 2
 network 192.168.20.0 mask 255.255.255.0
 gateway-list 192.168.20.3
 domain-name APdhcp2
 expired unlimited
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$fa9XWFtAEDHtDcAkO/mDbXEe5Mui67nfxA==
 authorization-attribute level 3
 service-type telnet
 service-type web
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.50 255.255.255.0
interface Vlan-interface10
 ip address 192.168.10.3 255.255.255.0
 dhcp select server global-pool subaddress
interface Vlan-interface20
 ip address 192.168.20.3 255.255.255.0
interface Ethernet1/0/1
 port link-mode bridge
 port access vlan 10
interface Ethernet1/0/2
 port access vlan 10
interface Ethernet1/0/3
 port access vlan 10
interface Ethernet1/0/4
 port access vlan 10
interface Ethernet1/0/5
 port access vlan 10
interface Ethernet1/0/6
 port access vlan 10
interface Ethernet1/0/7
 port access vlan 10
interface Ethernet1/0/8
 port access vlan 10
interface Ethernet1/0/9
 port access vlan 10
interface Ethernet1/0/10
 port access vlan 10
interface Ethernet1/0/11
 port access vlan 10
interface Ethernet1/0/12
 port access vlan 10
interface Ethernet1/0/13
 port access vlan 20
interface Ethernet1/0/14
 port access vlan 20
interface Ethernet1/0/15
 port access vlan 20
interface Ethernet1/0/16
 port access vlan 20
interface Ethernet1/0/17
 port access vlan 20
interface Ethernet1/0/18
 port access vlan 20
interface Ethernet1/0/19
 port access vlan 20
interface Ethernet1/0/20
 port access vlan 20
interface Ethernet1/0/21
 port access vlan 20
interface Ethernet1/0/22
 port access vlan 20
interface Ethernet1/0/23
interface Ethernet1/0/24
interface GigabitEthernet1/0/25
 ip address 192.168.1.3 255.255.255.0
interface GigabitEthernet1/0/26
 port link-type trunk
 port trunk permit vlan all
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 ip route-static 0.0.0.0 0.0.0.0 192.168.1.2
 ip route-static 192.168.0.0 255.255.0.0 192.168.1.2
 dhcp server forbidden-ip 192.168.10.3
 dhcp server forbidden-ip 192.168.20.3
 dhcp enable
 ip https enable
 load xml-configuration
 load tr069-configuration
user-interface aux 0
 set authentication password cipher $c$3$3oCdrIGDsp6NlIVMDLMV6giHdzd3TS8T0MiYtQ=
user-interface vty 0 15
return
S3600设置
不通的问题,先看有没有arp,如果没有需要配置静态arp看看能不能通,如果能通,说明arp的问题,debug arp看看是哪台设备有问题,如果依旧不能通,那么ping的时候抓包看看是哪台设备有异常。
还有可能是插错线了,stp阻塞了等等。
路由没配置ARP这个是准备作用内网 会议用的可移动设备
网络维护工学徒 发表时间:2017-07-27
-4811 九段
粉丝:28人 关注:1人
路由器上回程路由不对呗 ip route-static 192.168.1.0 24 192.168.1.3
目的地址改为192.168.10.0 24和192.168.20.0 24
加了没反映啊
