两台路由器SR8805做vrrp,路由器之间通过两台交换机相连
2017-07-27提问
  • 1收藏,3246浏览
如图R4 R5路由器之间可以ping通,但是不能形成备份,状态都是master
[RT4] DIS VRRP
 IPv4 Standby Information:
     Run Mode       : Standard
     Run Method     : Virtual MAC
 Interface          VRID   State       Run     Adver   Auth     Virtual
                                       Pri     Timer   Type        IP
 GE0/0/0            1      Master      120     1       Simple   10.189.185.1
[RT4]DIS VRRP S
[RT4]DIS VRRP statistics
 Interface               : GigabitEthernet0/0/0
 VRID                    : 1
 CheckSum Errors         : 0          Version Errors                : 0
 Invalid Type Pkts Rcvd  : 0          Advertisement Interval Errors : 0
 IP TTL Errors           : 0          Auth Failures                 : 0
 Invalid Auth Type       : 0          Auth Type Mismatch            : 0
 Packet Length Errors    : 0          Address List Errors           : 0
 Become Master           : 1          Priority Zero Pkts Rcvd       : 0
 Adver Rcvd              : 0          Priority Zero Pkts Sent       : 0
 Adver Sent              : 2599
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
<RT5> DIS VRRP
     Run Mode       : Standard
                                       Pri     Timer   Type        IP
 GE0/0/0            1      Master      100     1       Simple   10.189.185.1
<RT5>DIS VRRP S
<RT5>DIS VRRP statistics
 VRID                    : 1
 Adver Sent              : 2630
 Global statistics
 CheckSum Errors         : 0
 Version Errors          : 0
 VRID Errors             : 0
[RT4]ping -a 10.189.185.2 10.189.185.3
  PING 10.189.185.3: 56  data bytes, press CTRL_C to break
    Request time out
    Reply from 10.189.185.3: bytes=56 Sequence=2 ttl=253 time=10 ms
    Reply from 10.189.185.3: bytes=56 Sequence=3 ttl=253 time=1 ms
    Request time out
    Reply from 10.189.185.3: bytes=56 Sequence=5 ttl=253 time=1 ms
  --- 10.189.185.3 ping statistics ---
    5 packet(s) transmitted
    3 packet(s) received
    40.00% packet loss
    round-trip min/avg/max = 1/4/10 ms
RT4]DIS CU
 sysname RT4
interface GigabitEthernet0/0/0
 port link-mode route
 ip address 10.189.185.2 255.255.255.240
 vrrp vrid 1 virtual-ip 10.189.185.1
 vrrp vrid 1 priority 120
 vrrp vrid 1 preempt-mode timer delay 20
 vrrp vrid 1 track interface GigabitEthernet0/0/2 reduced 50
 vrrp vrid 1 authentication-mode simple 123
 ip route-static 10.189.185.3 255.255.255.255 10.189.185.9
 sysname RT5
 ip address 10.189.185.3 255.255.255.240
 ip route-static 10.189.185.2 255.255.255.255 10.189.185.10
<SW1>
#Jul 27 11:03:06:139 2017 SW1 SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Jul 27 11:03:06:139 2017 SW1 SHELL/5/SHELL_LOGIN: Console logged in from con0.DIS CU
 sysname SW1
 ip ttl-expires enable
 ip unreachables enable
 ip address 10.189.185.9 255.255.255.240
interface GigabitEthernet0/0/1
 ip address 10.0.0.1 255.255.255.0
 ip route-static 0.0.0.0 0.0.0.0 10.189.185.1
 ip route-static 10.189.185.0 255.255.255.252 10.189.185.2
 ip route-static 10.189.185.0 255.255.255.252 10.0.0.2
 sysname SW2
 ip address 10.189.185.10 255.255.255.240
 ip address 10.0.0.2 255.255.255.0
 ip route-static 10.189.185.0 255.255.255.252 10.189.185.3
 ip route-static 10.189.185.0 255.255.255.252 10.0.0.1
VRRP报文是二层的,两台88之间要二层互通,你中间交换机都是三层口,VRRP肯定起不来呀
SR8805(vrrp master)------vlan1(bridge)  SW1 vlan1(bridge) -------vlan1(bridge)  SW2 vlan1(bridge) -------SR8805(vrrp backup)
能不能说下,怎么修改啊,我是把两台交换机相连链路改成二层链路?
小白求帮忙 发表时间:2017-07-27
两台88之间二层互通就行了,VRRP通报报文是组播报文,组播报文是跨三层的,我在回答中补充一下
风干工程师肉干要不要 发表时间:2017-07-27
粉丝:12人 关注:7人
如果是主接口启VRRP,那么下面交换机需要二层access口透传。
最简单的方法:把两台路由器直接用网线连起来看看状态是否正常。
