服务器偶尔会连不上HPE StoreEasy 1660 Storage
2021-11-02提问
  • 1收藏,1477浏览
我们的应用程序服务器访问这台存储设备时偶尔会连不上,如下图:
此时查看存储设备HPE StoreEasy 1660 Storage的应用程序日志会发现系统服务错误。如下图:
下面是 StorageManagementProvider LOG
[10/25/2021 07:43:47.465][E][002564][3204] Error - SetSubSystem - 'Firmware Version' property not found.
[10/25/2021 07:43:53.478][E][002564][0001] There is no matching string found in resource file for the given string Error: This operation is not supported with the current configuration. Use the "show" command on devices to show additional details about the configuration. Reason: Space for creation not available so returning null error
[10/25/2021 07:43:53.494][E][002564][0001] Failed to retrieve error description for status code: SC_UNINITIALIZED, the retrieved value is: NULL
[10/25/2021 07:43:53.494][E][002564][0001] Failed to retrieve error description for status code: 1, the retrieved value is: NULL
[10/25/2021 07:43:53.509][E][002564][0001] Failed to retrieve error description for error code: 1, the retrieved value is: NULL
[10/25/2021 07:43:53.509][E][EC:0x1][002564][3204] Failed to retrieve message from Error Code Library.Unspecified error
[10/25/2021 07:43:54.921][E][002564][3204] The strRAID is:
[10/25/2021 07:43:54.921][E][002564][3204] RAID 6
[10/25/2021 07:43:54.921][E][002564][3204] The RAIDLabel is:
[10/25/2021 07:43:54.921][E][002564][3204] 6
[10/25/2021 07:43:54.937][E][002564][3204] The command is:
[10/25/2021 07:43:54.937][E][002564][3204] ctrl slot=0 array A create type=logicaldrive raid=6 size=?
[10/25/2021 07:43:56.317][E][002564][3204] free Size:
[10/25/2021 07:43:56.317][E][002564][3204] 0
[10/25/2021 07:43:59.146][E][002564][3204] Error - SetEnclosure - 'Device Number' property not found.
[10/25/2021 07:43:59.146][E][002564][3204] Error - SetEnclosure - 'Firmware Version' property not found.
[10/25/2021 07:43:59.146][E][002564][3204] Error - SetEnclosure - 'Vendor ID' property not found.
[10/25/2021 07:43:59.146][E][002564][3204] Error - SetEnclosure - 'Serial Number' property not found.
[10/25/2021 07:43:59.146][E][002564][3204] Error - SetEnclosure - 'Power Supply Status' property not found.
[10/25/2021 07:44:07.681][E][002564][0001] There is no matching string found in resource file for the given string Error: This operation is not supported with the current configuration. Use the "show" command on devices to show additional details about the configuration. Reason: Space for creation not available so returning null error
[10/25/2021 07:44:07.681][E][002564][0001] Failed to retrieve error description for status code: SC_UNINITIALIZED, the retrieved value is: NULL
[10/25/2021 07:44:07.681][E][002564][0001] Failed to retrieve error description for status code: 1, the retrieved value is: NULL
[10/25/2021 07:44:07.681][E][002564][0001] Failed to retrieve error description for error code: 1, the retrieved value is: NULL
[10/25/2021 07:44:07.681][E][EC:0x1][002564][3204] Failed to retrieve message from Error Code Library.Unspecified error
[10/25/2021 07:44:08.181][E][002564][3204] The strRAID is:
[10/25/2021 07:44:08.181][E][002564][3204] RAID 1
[10/25/2021 07:44:08.181][E][002564][3204] The RAIDLabel is:
[10/25/2021 07:44:08.181][E][002564][3204] 1
[10/25/2021 07:44:08.181][E][002564][3204] The command is:
[10/25/2021 07:44:08.181][E][002564][3204] ctrl slot=0b array A create type=logicaldrive raid=1 size=?
[10/25/2021 07:44:08.681][E][002564][3204] free Size:
[10/25/2021 07:44:08.681][E][002564][3204] 0
[10/25/2021 07:44:09.698][E][002564][3204] Error - SetEnclosure - 'Device Number' property not found.
[10/25/2021 07:44:09.698][E][002564][3204] Error - SetEnclosure - 'Firmware Version' property not found.
[10/25/2021 07:44:09.698][E][002564][3204] Error - SetEnclosure - 'Vendor ID' property not found.
[10/25/2021 07:44:09.698][E][002564][3204] Error - SetEnclosure - 'Serial Number' property not found.
[10/25/2021 07:44:09.698][E][002564][3204] Error - SetEnclosure - 'Power Supply Status' property not found.
这样的问题出现了好几次,导致依赖存储服务器的应用服务器宕机。
设备使用NFS共享,8*4T硬盘,RAID6,NTFS。
请告诉我产生这个错误的原因和解决方法,谢谢!
存储和应用程序服务器都是使用1Gb网卡网线连接交换机。
HPE StoreEasy 1660 Storage存储设备使用NFS共享,8*4T硬盘,RAID6,NTFS。
粉丝:75人 关注:7人
建议拨打400电话进行报修诊断
