H3C WA4320H-ACN-FIT版本从V7降到V5后,格式化后报错,请问是否硬件故障?
2021-11-02提问
  • 1收藏,757浏览
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
Register contents: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0x00000000 ; Reg: v0, Val = 0x00000000 ; Reg: v1, Val = 0x87601b78 ; Reg: a0, Val = 0x87600e98 ; Reg: a1, Val = 0x875fba50 ; Reg: a2, Val = 0x875fba4c ; Reg: a3, Val = 0x00000001 ; Reg: t0, Val = 0x875fba48 ; Reg: t1, Val = 0x2aea5400 ; Reg: t2, Val = 0xbf1a0000 ; Reg: t3, Val = 0x000000b4 ; Reg: t4, Val = 0x00000002 ; Reg: t5, Val = 0x00000046 ; Reg: t6, Val = 0xfffffffc ; Reg: t7, Val = 0x87a80000 ; Reg: s0, Val = 0x87600e98 ; Reg: s1, Val = 0x00000000 ; Reg: s2, Val = 0x00000001 ; Reg: s3, Val = 0x87601a98 ; Reg: s4, Val = 0x87601b84 ; Reg: s5, Val = 0x87601b78 ; Reg: s6, Val = 0x00000001 ; Reg: s7, Val = 0x00000005 ; Reg: t8, Val = 0x0000001f ; Reg: t9, Val = 0x87a34da0 ; Reg: k0, Val = 0x87b2c02c ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x87a86050 ; Reg: sp, Val = 0x875fba08 ; Reg: s8, Val = 0x00000001 ; Reg: ra, Val = 0x87a4ac44 ; Reg: status, Val = 0x10004003 ; Reg: lo, Val = 0x00000000 ; Reg: hi, Val = 0x00000000 ; Reg: badva, Val = 0x00000004 ; Reg: cause, Val = 0x4000800c ; Reg: epc, Val = 0x87a4aa84 ; Print call stack: 87a4aa84 87a4ac44 87a3d1cc 87a3de54 87a2b9dc 87a37858 87a0bfb8 87a0c1b4 System is starting...
粉丝:6人 关注:0人
重新恢复一下出厂,或者重新导入一下V5的版本就好了,boot异常出现的
不格式化,导不了固件,是否是硬件问题?
zhiliao_Ey4hKn 发表时间:2021-11-02
先格式化一下,因为空间可能不够不格式化的话。在下载版本哪一步不要直接操作2,先操作1再操作2
努力的小C 发表时间:2021-11-02
第一次用1,然后再次导入版本在同样的位置选择2
Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing..............................Done! **************************************************************************** * * * H3C WA4320H-ACN BootWare, Version 1.10 * * * **************************************************************************** Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Nov 18 2015 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 128MB PCB Version : Ver.B Read net params from bootrom failed, use the default value BootWare Validating... Press Ctrl+B to enter extended boot menu... BootWare password: Not required. Please press Enter to continue. Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+Y: Change AP Mode Ctrl+F: Format File System Enter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y Exception Number: 3 Exception Name: TLB exception: store Exception Instruction: 0x87a4aa84 Exception Stack Base: 0x875fba08 BootWare Run Address: 0x87a00000 Register contents: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0x00000000 ; Reg: v0, Val = 0x00000000 ; Reg: v1, Val = 0x87601b78 ; Reg: a0, Val = 0x87600e98 ; Reg: a1, Val = 0x875fba50 ; Reg: a2, Val = 0x875fba4c ; Reg: a3, Val = 0x00000001 ; Reg: t0, Val = 0x875fba48 ; Reg: t1, Val = 0x2aea5400 ; Reg: t2, Val = 0xbf1a0000 ; Reg: t3, Val = 0x000000b4 ; Reg: t4, Val = 0x00000002 ; Reg: t5, Val = 0x00000046 ; Reg: t6, Val = 0xfffffffc ; Reg: t7, Val = 0x87a80000 ; Reg: s0, Val = 0x87600e98 ; Reg: s1, Val = 0x00000000 ; Reg: s2, Val = 0x00000001 ; Reg: s3, Val = 0x87601a98 ; Reg: s4, Val = 0x87601b84 ; Reg: s5, Val = 0x87601b78 ; Reg: s6, Val = 0x00000001 ; Reg: s7, Val = 0x00000005 ; Reg: t8, Val = 0x0000001f ; Reg: t9, Val = 0x87a34da0 ; Reg: k0, Val = 0x87b2c02c ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x87a86050 ; Reg: sp, Val = 0x875fba08 ; Reg: s8, Val = 0x00000001 ; Reg: ra, Val = 0x87a4ac44 ; Reg: status, Val = 0x10004003 ; Reg: lo, Val = 0x00000000 ; Reg: hi, Val = 0x00000000 ; Reg: badva, Val = 0x00000004 ; Reg: cause, Val = 0x4000800c ; Reg: epc, Val = 0x87a4aa84 ; Print call stack: 87a4aa84 87a4ac44 87a3d1cc 87a3de54 87a2b9dc 87a37858 87a0bfb8 87a0c1b4 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing..............................Done!
zhiliao_Ey4hKn 发表时间:2021-11-03
回复努力的小C:
就是不能格式化,应该是硬件故障吧?
zhiliao_Ey4hKn 知了小白
V5环境下如果不格式化,不能上传固件。上传后提示报错!
CPU L1 Cache : 32KB
Memory Type : SDRAM
Memory Size : 256MB
Flash Size : 128MB
PCB Version : Ver.B
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 4
===============================<File CONTROL>===============================
|Note:the operating device is flash |
|<1> Display All File(s) |
|<2> Set Application File type |
|<3> Delete File |
|<0> Exit To Main Menu |
Enter your choice(0-3): 1
Display all file(s) in flash:
"M" = MAIN "B" = BACKUP "S" = SECURE "N/A" = NOT ASSIGNED
|NO. Size(B) Time Type Name |
|<3> Delete File |
Enter your choice(0-3): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Modify Ethernet Parameter |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-3): 3
==========================<ETHERNET PARAMETER SET>==========================
|Note: "." = Clear field. |
| "-" = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :host
:wa4300_fat.bin
Target File Name :target
:wa4300_fat.bin
Server IP Address :192.168.1.1 192.168.0.1
Local IP Address :192.168.1.253 192.168.0.50
Gateway IP Address :0.0.0.0
Enter your choice(0-3): 2
Loading.....................................................................
.......................................................................Done!
10923008 bytes downloaded!
Updating File flash:/wa4300_fat.bin
Failed!
不格式化,上传是失败的
