想省一个交换机,设置了vlan,但是加入vlan的两个端口无法相互访问。
有人说“最重要的一点,需要开启域内策略,否则即使做了上面的所有配置,同一VLAN,同一安全域,同一网段照样不通。命令如下:security-zone intra-zone default permit”
可这个“security-zone”我这个机器不支持。
设置列表
对齐方式
(0)
3、4口没有加安全域,二层接口加安全域时要加vlan参数
import interface g0/3 vlan 30
另外这是V5防火墙,同域应该是默认放通的
(0)
配置了nqa+track的静态路由,但切换时间超过60秒。把主路由的端口shutdown以后,等了六十几秒,才能ping通,不知道是哪里的问题。 [LT-3016]display current-configuration # version 5.20, Release 2207P02, Basic # sysname LT-3016 # nat address-group 1 9.132.44.97 9.132.44.97 nat address-group 2 9.132.44.104 9.132.44.104 # domain default enable system # dar p2p signature-file cfa0:/p2p_default.mtd # port-security enable # undo ip http enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher .]@USE=B,53Q=^Q`MAF4<1!! authorization-attribute level 3 service-type telnet # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp # interface Ethernet0/0 port link-mode route ip address 10.71.1.1 255.255.255.248 # interface Serial1/0 fe1 unframed link-protocol ppp ip address 9.132.60.98 255.255.255.252 # interface NULL0 # nqa entry admin test type icmp-echo destination ip 9.132.60.97 frequency 100 next-hop 9.132.60.97 reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only # ip route-static 0.0.0.0 0.0.0.0 9.132.60.97 track 1 ip route-static 0.0.0.0 0.0.0.0 10.71.1.3 preference 80 ip route-static 10.129.1.0 255.255.255.0 10.71.1.2 # track 1 nqa entry admin test reaction 1 # nqa schedule admin test start-time now lifetime forever # ssh server enable ssh user h3c3 service-type stelnet authentication-type password # nat static 10.129.1.4 9.132.44.98 # load xml-configuration # user-interface con 0 user-interface tty 13 user-interface aux 0 user-interface vty 0 4 authentication-mode scheme # return
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
