HCL设备无法启动
2021-11-09提问
  • 1收藏,1339浏览
HCL模拟器设备无法启动,最近几天没有系统更新,就无法启动了,box启动日志如下:
如下为box日志
00:00:00.230362 VirtualBox VM 6.0.14 r133895 win.amd64 (Oct 10 2019 19:44:31) release log
00:00:00.230365 Log opened 2021-11-09T02:55:54.994725100Z
00:00:00.230366 Build Type: release
00:00:00.230368 OS Product: Windows 10
00:00:00.230369 OS Release: 10.0.19042
00:00:00.230369 OS Service Pack:
00:00:00.272087 DMI Product Name: TUF Gaming FX505GE_FX86FE
00:00:00.275205 DMI Product Version: 1.0
00:00:00.275211 Host RAM: 8043MB (7.8GB) total, 3527MB (3.4GB) available
00:00:00.275213 Executable: C:\Program Files\Oracle\VirtualBox\VBoxHeadless.exe
00:00:00.275213 Process ID: 5064
00:00:00.275214 Package type: WINDOWS_64BITS_GENERIC
00:00:00.276647 Installed Extension Packs:
00:00:00.276667 None installed!
00:00:00.277719 Console: Machine state changed to 'Starting'
00:00:00.337563 SUP: Loaded VMMR0.r0 (C:\Program Files\Oracle\VirtualBox\VMMR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:00.337574 SUP: VMMR0EntryEx located at XXXXXXXXXXXXXXXX and VMMR0EntryFast at XXXXXXXXXXXXXXXX
00:00:00.337577 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox\VMMR0.r0=0xXXXXXXXXXXXXXXXX
00:00:00.339653 Guest OS type: 'Linux26'
00:00:00.343877 File system of 'C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots' (snapshots) is ntfs
00:00:00.343883 File system of 'c:\users\a'su's\appdata\local\temp\hcl_lsn5hg\ConfigDisk\device1.vdi' is ntfs
00:00:00.344922 File system of 'C:\Users\a'su's\HCL VMs\topo1\device1\t1d1-storage1.vdi' is ntfs
00:00:00.345904 File system of 'C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots\{c1b8c777-e730-49df-acb0-4bfc491e6b61}.vdi' is ntfs
00:00:00.347215 File system of 'C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots\{b4249f26-2b45-4e4c-b19c-556a984d8d16}.vmdk' is ntfs
00:00:00.361440 Shared clipboard service loaded
00:00:00.361448 Shared clipboard mode: Off
00:00:00.366768 Drag and drop service loaded
00:00:00.366776 Drag and drop mode: Off
00:00:00.575032 ************************* CFGM dump *************************
00:00:00.575033 [/] (level 0)
00:00:00.575035 CSAMEnabled <integer> = 0x0000000000000001 (1)
00:00:00.575037 CpuExecutionCap <integer> = 0x0000000000000050 (80)
00:00:00.575037 EnablePAE <integer> = 0x0000000000000001 (1)
00:00:00.575038 HMEnabled <integer> = 0x0000000000000001 (1)
00:00:00.575039 MemBalloonSize <integer> = 0x0000000000000000 (0)
00:00:00.575039 Name <string> = "topo1-device1" (cb=14)
00:00:00.575040 NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.575041 PATMEnabled <integer> = 0x0000000000000001 (1)
00:00:00.575041 PageFusionAllowed <integer> = 0x0000000000000000 (0)
00:00:00.575041 RamHoleSize <integer> = 0x0000000020000000 (536 870 912, 512 MB)
00:00:00.575043 RamSize <integer> = 0x0000000018000000 (402 653 184, 384 MB)
00:00:00.575044 RawR0Enabled <integer> = 0x0000000000000001 (1)
00:00:00.575044 RawR3Enabled <integer> = 0x0000000000000001 (1)
00:00:00.575045 TimerMillies <integer> = 0x000000000000000a (10)
00:00:00.575045 UUID <bytes> = "86 d5 d9 a9 a4 03 ef 4a 94 06 71 e8 42 84 ea f0" (cb=16)
00:00:00.575049
00:00:00.575049 [/CPUM/] (level 1)
00:00:00.575050 GuestCpuName <string> = "host" (cb=5)
00:00:00.575050 NestedHWVirt <integer> = 0x0000000000000000 (0)
00:00:00.575051 PortableCpuIdLevel <integer> = 0x0000000000000000 (0)
00:00:00.575051 SpecCtrl <integer> = 0x0000000000000000 (0)
00:00:00.575052
00:00:00.575052 [/CPUM/IsaExts/] (level 2)
00:00:00.575053
00:00:00.575053 [/DBGC/] (level 1)
00:00:00.575053 GlobalInitScript <string> = "C:\Users\a'su's\.VirtualBox/dbgc-init" (cb=38)
00:00:00.575054 HistoryFile <string> = "C:\Users\a'su's\.VirtualBox/dbgc-history" (cb=41)
00:00:00.575055 LocalInitScript <string> = "C:\Users\a'su's\HCL VMs\topo1\device1/dbgc-init" (cb=48)
00:00:00.575055
00:00:00.575055 [/DBGF/] (level 1)
00:00:00.575056 Path <string> = "C:\Users\a'su's\HCL VMs\topo1\device1/debug/;C:\Users\a'su's\HCL VMs\topo1\device1/;C:\Users\a'su's\" (cb=101)
00:00:00.575056
00:00:00.575057 [/Devices/] (level 1)
00:00:00.575057
00:00:00.575057 [/Devices/8237A/] (level 2)
00:00:00.575058
00:00:00.575058 [/Devices/8237A/0/] (level 3)
00:00:00.575059 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575059
00:00:00.575059 [/Devices/GIMDev/] (level 2)
00:00:00.575060
00:00:00.575060 [/Devices/GIMDev/0/] (level 3)
00:00:00.575061 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575061
00:00:00.575061 [/Devices/VMMDev/] (level 2)
00:00:00.575062
00:00:00.575062 [/Devices/VMMDev/0/] (level 3)
00:00:00.575063 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575063 PCIDeviceNo <integer> = 0x0000000000000004 (4)
00:00:00.575064 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575064 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575065
00:00:00.575065 [/Devices/VMMDev/0/Config/] (level 4)
00:00:00.575065 GuestCoreDumpDir <string> = "C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots" (cb=48)
00:00:00.575066
00:00:00.575066 [/Devices/VMMDev/0/LUN#0/] (level 4)
00:00:00.575067 Driver <string> = "HGCM" (cb=5)
00:00:00.575067
00:00:00.575068 [/Devices/VMMDev/0/LUN#0/Config/] (level 5)
00:00:00.575068 Object <integer> = 0x0000000001f07d50 (32 537 936)
00:00:00.575069
00:00:00.575069 [/Devices/VMMDev/0/LUN#999/] (level 4)
00:00:00.575070 Driver <string> = "MainStatus" (cb=11)
00:00:00.575070
00:00:00.575071 [/Devices/VMMDev/0/LUN#999/Config/] (level 5)
00:00:00.575071 First <integer> = 0x0000000000000000 (0)
00:00:00.575072 Last <integer> = 0x0000000000000000 (0)
00:00:00.575072 papLeds <integer> = 0x0000000001f07878 (32 536 696)
00:00:00.575073
00:00:00.575073 [/Devices/apic/] (level 2)
00:00:00.575074
00:00:00.575074 [/Devices/apic/0/] (level 3)
00:00:00.575075 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575075
00:00:00.575075 [/Devices/apic/0/Config/] (level 4)
00:00:00.575076 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:00.575077 Mode <integer> = 0x0000000000000003 (3)
00:00:00.575077 NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.575077
00:00:00.575078 [/Devices/e1000/] (level 2)
00:00:00.575078
00:00:00.575078 [/Devices/e1000/1/] (level 3)
00:00:00.575079 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575080 PCIDeviceNo <integer> = 0x0000000000000008 (8)
00:00:00.575080 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575080 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575081
00:00:00.575081 [/Devices/e1000/1/Config/] (level 4)
00:00:00.575082 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575082 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575083 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575083 MAC <bytes> = "00 e0 01 02 12 34" (cb=6)
00:00:00.575084
00:00:00.575084 [/Devices/e1000/1/LUN#0/] (level 4)
00:00:00.575085
00:00:00.575085 [/Devices/e1000/1/LUN#999/] (level 4)
00:00:00.575086 Driver <string> = "MainStatus" (cb=11)
00:00:00.575086
00:00:00.575087 [/Devices/e1000/1/LUN#999/Config/] (level 5)
00:00:00.575087 First <integer> = 0x0000000000000000 (0)
00:00:00.575088 Last <integer> = 0x0000000000000000 (0)
00:00:00.575088 papLeds <integer> = 0x0000000001f07760 (32 536 416)
00:00:00.575089
00:00:00.575089 [/Devices/e1000/2/] (level 3)
00:00:00.575090 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575090 PCIDeviceNo <integer> = 0x0000000000000009 (9)
00:00:00.575091 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575091 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575092
00:00:00.575092 [/Devices/e1000/2/Config/] (level 4)
00:00:00.575092 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575093 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575093 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575094 MAC <bytes> = "00 e0 01 03 12 34" (cb=6)
00:00:00.575095
00:00:00.575095 [/Devices/e1000/2/LUN#0/] (level 4)
00:00:00.575096
00:00:00.575096 [/Devices/e1000/2/LUN#999/] (level 4)
00:00:00.575096 Driver <string> = "MainStatus" (cb=11)
00:00:00.575097
00:00:00.575097 [/Devices/e1000/2/LUN#999/Config/] (level 5)
00:00:00.575098 First <integer> = 0x0000000000000000 (0)
00:00:00.575098 Last <integer> = 0x0000000000000000 (0)
00:00:00.575099 papLeds <integer> = 0x0000000001f07768 (32 536 424)
00:00:00.575099
00:00:00.575099 [/Devices/e1000/3/] (level 3)
00:00:00.575100 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575101 PCIDeviceNo <integer> = 0x000000000000000a (10)
00:00:00.575101 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575101 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575102
00:00:00.575102 [/Devices/e1000/3/Config/] (level 4)
00:00:00.575103 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575103 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575104 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575104 MAC <bytes> = "00 e0 01 04 12 34" (cb=6)
00:00:00.575105
00:00:00.575105 [/Devices/e1000/3/LUN#0/] (level 4)
00:00:00.575106
00:00:00.575106 [/Devices/e1000/3/LUN#999/] (level 4)
00:00:00.575106 Driver <string> = "MainStatus" (cb=11)
00:00:00.575107
00:00:00.575107 [/Devices/e1000/3/LUN#999/Config/] (level 5)
00:00:00.575108 First <integer> = 0x0000000000000000 (0)
00:00:00.575108 Last <integer> = 0x0000000000000000 (0)
00:00:00.575108 papLeds <integer> = 0x0000000001f07770 (32 536 432)
00:00:00.575109
00:00:00.575109 [/Devices/e1000/4/] (level 3)
00:00:00.575110 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575110 PCIDeviceNo <integer> = 0x0000000000000010 (16)
00:00:00.575111 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575111 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575112
00:00:00.575112 [/Devices/e1000/4/Config/] (level 4)
00:00:00.575112 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575113 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575113 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575114 MAC <bytes> = "00 e0 01 05 12 34" (cb=6)
00:00:00.575114
00:00:00.575115 [/Devices/e1000/4/LUN#0/] (level 4)
00:00:00.575115
00:00:00.575115 [/Devices/e1000/4/LUN#999/] (level 4)
00:00:00.575116 Driver <string> = "MainStatus" (cb=11)
00:00:00.575116
00:00:00.575117 [/Devices/e1000/4/LUN#999/Config/] (level 5)
00:00:00.575117 First <integer> = 0x0000000000000000 (0)
00:00:00.575118 Last <integer> = 0x0000000000000000 (0)
00:00:00.575118 papLeds <integer> = 0x0000000001f07778 (32 536 440)
00:00:00.575119
00:00:00.575119 [/Devices/e1000/5/] (level 3)
00:00:00.575119 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575120 PCIDeviceNo <integer> = 0x0000000000000011 (17)
00:00:00.575120 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575121 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575121
00:00:00.575121 [/Devices/e1000/5/Config/] (level 4)
00:00:00.575122 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575122 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575123 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575123 MAC <bytes> = "00 e0 01 06 12 34" (cb=6)
00:00:00.575124
00:00:00.575124 [/Devices/e1000/5/LUN#0/] (level 4)
00:00:00.575125
00:00:00.575125 [/Devices/e1000/5/LUN#999/] (level 4)
00:00:00.575126 Driver <string> = "MainStatus" (cb=11)
00:00:00.575126
00:00:00.575126 [/Devices/e1000/5/LUN#999/Config/] (level 5)
00:00:00.575127 First <integer> = 0x0000000000000000 (0)
00:00:00.575127 Last <integer> = 0x0000000000000000 (0)
00:00:00.575128 papLeds <integer> = 0x0000000001f07780 (32 536 448)
00:00:00.575128
00:00:00.575128 [/Devices/e1000/6/] (level 3)
00:00:00.575129 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575129 PCIDeviceNo <integer> = 0x0000000000000012 (18)
00:00:00.575130 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575130 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575131
00:00:00.575131 [/Devices/e1000/6/Config/] (level 4)
00:00:00.575132 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575132 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575132 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575133 MAC <bytes> = "00 e0 01 07 12 34" (cb=6)
00:00:00.575133
00:00:00.575134 [/Devices/e1000/6/LUN#0/] (level 4)
00:00:00.575134
00:00:00.575134 [/Devices/e1000/6/LUN#999/] (level 4)
00:00:00.575135 Driver <string> = "MainStatus" (cb=11)
00:00:00.575135
00:00:00.575136 [/Devices/e1000/6/LUN#999/Config/] (level 5)
00:00:00.575136 First <integer> = 0x0000000000000000 (0)
00:00:00.575137 Last <integer> = 0x0000000000000000 (0)
00:00:00.575137 papLeds <integer> = 0x0000000001f07788 (32 536 456)
00:00:00.575138
00:00:00.575138 [/Devices/e1000/7/] (level 3)
00:00:00.575138 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575139 PCIDeviceNo <integer> = 0x0000000000000013 (19)
00:00:00.575139 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575140 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575140
00:00:00.575140 [/Devices/e1000/7/Config/] (level 4)
00:00:00.575141 AdapterType <integer> = 0x0000000000000000 (0)
00:00:00.575141 CableConnected <integer> = 0x0000000000000000 (0)
00:00:00.575141 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575142 MAC <bytes> = "00 e0 01 08 12 34" (cb=6)
00:00:00.575143
00:00:00.575143 [/Devices/e1000/7/LUN#0/] (level 4)
00:00:00.575144
00:00:00.575144 [/Devices/e1000/7/LUN#999/] (level 4)
00:00:00.575144 Driver <string> = "MainStatus" (cb=11)
00:00:00.575145
00:00:00.575145 [/Devices/e1000/7/LUN#999/Config/] (level 5)
00:00:00.575145 First <integer> = 0x0000000000000000 (0)
00:00:00.575146 Last <integer> = 0x0000000000000000 (0)
00:00:00.575146 papLeds <integer> = 0x0000000001f07790 (32 536 464)
00:00:00.575147
00:00:00.575147 [/Devices/i8254/] (level 2)
00:00:00.575148
00:00:00.575148 [/Devices/i8254/0/] (level 3)
00:00:00.575148
00:00:00.575148 [/Devices/i8254/0/Config/] (level 4)
00:00:00.575149
00:00:00.575149 [/Devices/i8259/] (level 2)
00:00:00.575150
00:00:00.575150 [/Devices/i8259/0/] (level 3)
00:00:00.575150 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575151
00:00:00.575151 [/Devices/i8259/0/Config/] (level 4)
00:00:00.575152
00:00:00.575152 [/Devices/ichac97/] (level 2)
00:00:00.575152
00:00:00.575152 [/Devices/ichac97/0/] (level 3)
00:00:00.575153 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575153 PCIDeviceNo <integer> = 0x0000000000000005 (5)
00:00:00.575154 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575154 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575155
00:00:00.575155 [/Devices/ichac97/0/AudioConfig/] (level 4)
00:00:00.575156
00:00:00.575156 [/Devices/ichac97/0/Config/] (level 4)
00:00:00.575156 Codec <string> = "STAC9700" (cb=9)
00:00:00.575157 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:00.575157 DebugPathOut <string> = "" (cb=1)
00:00:00.575158
00:00:00.575158 [/Devices/ichac97/0/LUN#0/] (level 4)
00:00:00.575159 Driver <string> = "AUDIO" (cb=6)
00:00:00.575159
00:00:00.575159 [/Devices/ichac97/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.575160 Driver <string> = "DSoundAudio" (cb=12)
00:00:00.575160
00:00:00.575161 [/Devices/ichac97/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:00.575161 StreamName <string> = "topo1-device1" (cb=14)
00:00:00.575162
00:00:00.575162 [/Devices/ichac97/0/LUN#0/Config/] (level 5)
00:00:00.575163 BufferSizeMs <integer> = 0x0000000000000000 (0)
00:00:00.575163 DriverName <string> = "DSoundAudio" (cb=12)
00:00:00.575164 InputEnabled <integer> = 0x0000000000000000 (0)
00:00:00.575164 OutputEnabled <integer> = 0x0000000000000000 (0)
00:00:00.575165 PeriodSizeMs <integer> = 0x0000000000000000 (0)
00:00:00.575165 PreBufferSizeMs <integer> = 0x00000000ffffffff (4 294 967 295)
00:00:00.575166
00:00:00.575166 [/Devices/ichac97/0/LUN#1/] (level 4)
00:00:00.575167 Driver <string> = "AUDIO" (cb=6)
00:00:00.575167
00:00:00.575167 [/Devices/ichac97/0/LUN#2/] (level 4)
00:00:00.575168 Driver <string> = "AUDIO" (cb=6)
00:00:00.575168
00:00:00.575168 [/Devices/ioapic/] (level 2)
00:00:00.575169
00:00:00.575169 [/Devices/ioapic/0/] (level 3)
00:00:00.575170 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575170
00:00:00.575170 [/Devices/ioapic/0/Config/] (level 4)
00:00:00.575171 NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.575172
00:00:00.575172 [/Devices/mc146818/] (level 2)
00:00:00.575172
00:00:00.575172 [/Devices/mc146818/0/] (level 3)
00:00:00.575173
00:00:00.575173 [/Devices/mc146818/0/Config/] (level 4)
00:00:00.575174 UseUTC <integer> = 0x0000000000000000 (0)
00:00:00.575174
00:00:00.575174 [/Devices/parallel/] (level 2)
00:00:00.575175
00:00:00.575175 [/Devices/pcarch/] (level 2)
00:00:00.575175
00:00:00.575176 [/Devices/pcarch/0/] (level 3)
00:00:00.575176 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575177
00:00:00.575177 [/Devices/pcarch/0/Config/] (level 4)
00:00:00.575177
00:00:00.575178 [/Devices/pcbios/] (level 2)
00:00:00.575178
00:00:00.575178 [/Devices/pcbios/0/] (level 3)
00:00:00.575179 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575179
00:00:00.575179 [/Devices/pcbios/0/Config/] (level 4)
00:00:00.575180 APIC <integer> = 0x0000000000000001 (1)
00:00:00.575181 BootDevice0 <string> = "IDE" (cb=4)
00:00:00.575181 BootDevice1 <string> = "NONE" (cb=5)
00:00:00.575181 BootDevice2 <string> = "NONE" (cb=5)
00:00:00.575182 BootDevice3 <string> = "NONE" (cb=5)
00:00:00.575182 DmiBoardProduct <string> = "id=1 type=2100 slot=0 dev=58 macAddr=34-30-ae-ce-01-00" (cb=55)
00:00:00.575183 DmiBoardSerial <string> = "" (cb=56)
00:00:00.575183 DmiBoardVersion <string> = "mem=384" (cb=8)
00:00:00.575184 FloppyDevice <string> = "i82078" (cb=7)
00:00:00.575184 HardDiskDevice <string> = "piix3ide" (cb=9)
00:00:00.575185 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:00.575185 McfgBase <integer> = 0x0000000000000000 (0)
00:00:00.575186 McfgLength <integer> = 0x0000000000000000 (0)
00:00:00.575186 NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.575186 PXEDebug <integer> = 0x0000000000000000 (0)
00:00:00.575187 UUID <bytes> = "86 d5 d9 a9 a4 03 ef 4a 94 06 71 e8 42 84 ea f0" (cb=16)
00:00:00.575188
00:00:00.575188 [/Devices/pcbios/0/Config/NetBoot/] (level 5)
00:00:00.575189
00:00:00.575189 [/Devices/pcbios/0/Config/NetBoot/0/] (level 6)
00:00:00.575190 NIC <integer> = 0x0000000000000000 (0)
00:00:00.575191 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575191 PCIDeviceNo <integer> = 0x0000000000000003 (3)
00:00:00.575191 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575192
00:00:00.575192 [/Devices/pci/] (level 2)
00:00:00.575192
00:00:00.575193 [/Devices/pci/0/] (level 3)
00:00:00.575193 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575194
00:00:00.575194 [/Devices/pci/0/Config/] (level 4)
00:00:00.575194 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:00.575195
00:00:00.575195 [/Devices/pcibridge/] (level 2)
00:00:00.575196
00:00:00.575196 [/Devices/pckbd/] (level 2)
00:00:00.575196
00:00:00.575196 [/Devices/pckbd/0/] (level 3)
00:00:00.575197 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575197
00:00:00.575197 [/Devices/pckbd/0/Config/] (level 4)
00:00:00.575198
00:00:00.575198 [/Devices/pckbd/0/LUN#0/] (level 4)
00:00:00.575199 Driver <string> = "KeyboardQueue" (cb=14)
00:00:00.575199
00:00:00.575199 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.575200 Driver <string> = "MainKeyboard" (cb=13)
00:00:00.575201
00:00:00.575201 [/Devices/pckbd/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:00.575202 Object <integer> = 0x0000000001d99eb0 (31 039 152)
00:00:00.575202
00:00:00.575202 [/Devices/pckbd/0/LUN#0/Config/] (level 5)
00:00:00.575203 QueueSize <integer> = 0x0000000000000040 (64)
00:00:00.575204
00:00:00.575204 [/Devices/pckbd/0/LUN#1/] (level 4)
00:00:00.575205 Driver <string> = "MouseQueue" (cb=11)
00:00:00.575205
00:00:00.575205 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
00:00:00.575206 Driver <string> = "MainMouse" (cb=10)
00:00:00.575206
00:00:00.575206 [/Devices/pckbd/0/LUN#1/AttachedDriver/Config/] (level 6)
00:00:00.575207 Object <integer> = 0x0000000001f0b2f0 (32 551 664)
00:00:00.575208
00:00:00.575208 [/Devices/pckbd/0/LUN#1/Config/] (level 5)
00:00:00.575209 QueueSize <integer> = 0x0000000000000080 (128)
00:00:00.575209
00:00:00.575209 [/Devices/pcnet/] (level 2)
00:00:00.575210
00:00:00.575210 [/Devices/pcnet/0/] (level 3)
00:00:00.575211 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575211 PCIDeviceNo <integer> = 0x0000000000000003 (3)
00:00:00.575211 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575212 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575212
00:00:00.575213 [/Devices/pcnet/0/Config/] (level 4)
00:00:00.575213 CableConnected <integer> = 0x0000000000000001 (1)
00:00:00.575214 ChipType <string> = "Am79C973" (cb=9)
00:00:00.575214 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:00.575215 MAC <bytes> = "08 00 27 e0 60 7c" (cb=6)
00:00:00.575215
00:00:00.575215 [/Devices/pcnet/0/LUN#0/] (level 4)
00:00:00.575216 Driver <string> = "UDPTunnel" (cb=10)
00:00:00.575216
00:00:00.575217 [/Devices/pcnet/0/LUN#0/Config/] (level 5)
00:00:00.575217 dest <string> = "127.0.0.1" (cb=10)
00:00:00.575218 dport <string> = "16000" (cb=6)
00:00:00.575218 sport <string> = "16001" (cb=6)
00:00:00.575218
00:00:00.575219 [/Devices/pcnet/0/LUN#999/] (level 4)
00:00:00.575219 Driver <string> = "MainStatus" (cb=11)
00:00:00.575220
00:00:00.575220 [/Devices/pcnet/0/LUN#999/Config/] (level 5)
00:00:00.575221 First <integer> = 0x0000000000000000 (0)
00:00:00.575222 Last <integer> = 0x0000000000000000 (0)
00:00:00.575223 papLeds <integer> = 0x0000000001f07758 (32 536 408)
00:00:00.575223
00:00:00.575224 [/Devices/piix3ide/] (level 2)
00:00:00.575224
00:00:00.575224 [/Devices/piix3ide/0/] (level 3)
00:00:00.575225 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575225 PCIDeviceNo <integer> = 0x0000000000000001 (1)
00:00:00.575226 PCIFunctionNo <integer> = 0x0000000000000001 (1)
00:00:00.575226 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575227
00:00:00.575227 [/Devices/piix3ide/0/Config/] (level 4)
00:00:00.575227 Type <string> = "PIIX4" (cb=6)
00:00:00.575228
00:00:00.575228 [/Devices/piix3ide/0/LUN#0/] (level 4)
00:00:00.575229 Driver <string> = "VD" (cb=3)
00:00:00.575229
00:00:00.575229 [/Devices/piix3ide/0/LUN#0/Config/] (level 5)
00:00:00.575230 Format <string> = "VDI" (cb=4)
00:00:00.575230 Mountable <integer> = 0x0000000000000000 (0)
00:00:00.575231 Path <string> = "C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots\{c1b8c777-e730-49df-acb0-4bfc491e6b61}.vdi" (cb=91)
00:00:00.575231 Type <string> = "HardDisk" (cb=9)
00:00:00.575232
00:00:00.575232 [/Devices/piix3ide/0/LUN#0/Config/Parent/] (level 6)
00:00:00.575233 Format <string> = "VDI" (cb=4)
00:00:00.575233 Path <string> = "C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots\{b0be3de6-2f29-4f95-bf17-00974091ff4b}.vdi" (cb=91)
00:00:00.575234
00:00:00.575234 [/Devices/piix3ide/0/LUN#1/] (level 4)
00:00:00.575235 Driver <string> = "VD" (cb=3)
00:00:00.575235
00:00:00.575235 [/Devices/piix3ide/0/LUN#1/Config/] (level 5)
00:00:00.575236 Format <string> = "VMDK" (cb=5)
00:00:00.575236 Mountable <integer> = 0x0000000000000000 (0)
00:00:00.575237 Path <string> = "C:\Users\a'su's\HCL VMs\topo1\device1\Snapshots\{b4249f26-2b45-4e4c-b19c-556a984d8d16}.vmdk" (cb=92)
00:00:00.575237 Type <string> = "HardDisk" (cb=9)
00:00:00.575238
00:00:00.575238 [/Devices/piix3ide/0/LUN#1/Config/Parent/] (level 6)
00:00:00.575239 Format <string> = "VMDK" (cb=5)
00:00:00.575239 Path <string> = "e:\program files (x86)\hcl\version\s6850_b70.vmdk" (cb=50)
00:00:00.575239
00:00:00.575240 [/Devices/piix3ide/0/LUN#2/] (level 4)
00:00:00.575240 Driver <string> = "VD" (cb=3)
00:00:00.575241
00:00:00.575241 [/Devices/piix3ide/0/LUN#2/Config/] (level 5)
00:00:00.575241 Format <string> = "VDI" (cb=4)
00:00:00.575242 Mountable <integer> = 0x0000000000000000 (0)
00:00:00.575242 Path <string> = "c:\users\a'su's\appdata\local\temp\hcl_lsn5hg\ConfigDisk\device1.vdi" (cb=69)
00:00:00.575243 Type <string> = "HardDisk" (cb=9)
00:00:00.575243
00:00:00.575243 [/Devices/piix3ide/0/LUN#3/] (level 4)
00:00:00.575244 Driver <string> = "VD" (cb=3)
00:00:00.575244
00:00:00.575244 [/Devices/piix3ide/0/LUN#3/Config/] (level 5)
00:00:00.575245 Format <string> = "VDI" (cb=4)
00:00:00.575246 Mountable <integer> = 0x0000000000000000 (0)
00:00:00.575246 Path <string> = "C:\Users\a'su's\HCL VMs\topo1\device1\t1d1-storage1.vdi" (cb=56)
00:00:00.575246 Type <string> = "HardDisk" (cb=9)
00:00:00.575247
00:00:00.575247 [/Devices/piix3ide/0/LUN#999/] (level 4)
00:00:00.575248 Driver <string> = "MainStatus" (cb=11)
00:00:00.575248
00:00:00.575248 [/Devices/piix3ide/0/LUN#999/Config/] (level 5)
00:00:00.575249 DeviceInstance <string> = "piix3ide/0" (cb=11)
00:00:00.575249 First <integer> = 0x0000000000000000 (0)
00:00:00.575250 Last <integer> = 0x0000000000000003 (3)
00:00:00.575250 pConsole <integer> = 0x0000000001f07070 (32 534 640)
00:00:00.575251 papLeds <integer> = 0x0000000001f07458 (32 535 640)
00:00:00.575252 pmapMediumAttachments <integer> = 0x0000000001f07898 (32 536 728)
00:00:00.575253
00:00:00.575253 [/Devices/serial/] (level 2)
00:00:00.575253
00:00:00.575253 [/Devices/serial/0/] (level 3)
00:00:00.575254 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575254
00:00:00.575254 [/Devices/serial/0/Config/] (level 4)
00:00:00.575255 IOBase <integer> = 0x00000000000003f8 (1 016)
00:00:00.575256 IRQ <integer> = 0x0000000000000004 (4)
00:00:00.575256 UartType <string> = "16550A" (cb=7)
00:00:00.575257
00:00:00.575257 [/Devices/serial/0/LUN#0/] (level 4)
00:00:00.575257 Driver <string> = "Char" (cb=5)
00:00:00.575258
00:00:00.575258 [/Devices/serial/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.575259 Driver <string> = "RawFile" (cb=8)
00:00:00.575259
00:00:00.575259 [/Devices/serial/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:00.575260 Location <string> = "c:\users\a'su's\appdata\local\temp\hcl_lsn5hg\SerialFile\S6850_1.txt" (cb=69)
00:00:00.575260
00:00:00.575261 [/Devices/serial/1/] (level 3)
00:00:00.575261 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575262
00:00:00.575262 [/Devices/serial/1/Config/] (level 4)
00:00:00.575262 IOBase <integer> = 0x00000000000002f8 (760)
00:00:00.575263 IRQ <integer> = 0x0000000000000003 (3)
00:00:00.575263 UartType <string> = "16550A" (cb=7)
00:00:00.575264
00:00:00.575264 [/Devices/serial/1/LUN#0/] (level 4)
00:00:00.575265 Driver <string> = "Char" (cb=5)
00:00:00.575265
00:00:00.575265 [/Devices/serial/1/LUN#0/AttachedDriver/] (level 5)
00:00:00.575266 Driver <string> = "NamedPipe" (cb=10)
00:00:00.575266
00:00:00.575266 [/Devices/serial/1/LUN#0/AttachedDriver/Config/] (level 6)
00:00:00.575267 IsServer <integer> = 0x0000000000000001 (1)
00:00:00.575268 Location <string> = "\\.\pipe\topo1-device1" (cb=23)
00:00:00.575268
00:00:00.575268 [/Devices/vga/] (level 2)
00:00:00.575269
00:00:00.575269 [/Devices/vga/0/] (level 3)
00:00:00.575269 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:00.575270 PCIDeviceNo <integer> = 0x0000000000000002 (2)
00:00:00.575270 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.575271 Trusted <integer> = 0x0000000000000001 (1)
00:00:00.575271
00:00:00.575271 [/Devices/vga/0/Config/] (level 4)
00:00:00.575272 3DEnabled <integer> = 0x0000000000000000 (0)
00:00:00.575272 CustomVideoModes <integer> = 0x0000000000000000 (0)
00:00:00.575273 FadeIn <integer> = 0x0000000000000001 (1)
00:00:00.575273 FadeOut <integer> = 0x0000000000000001 (1)
00:00:00.575274 HeightReduction <integer> = 0x0000000000000000 (0)
00:00:00.575274 LogoFile <string> = "" (cb=1)
00:00:00.575275 LogoTime <integer> = 0x0000000000000000 (0)
00:00:00.575275 MonitorCount <integer> = 0x0000000000000001 (1)
00:00:00.575276 ShowBootMenu <integer> = 0x0000000000000002 (2)
00:00:00.575276 VRamSize <integer> = 0x0000000000800000 (8 388 608, 8 MB)
00:00:00.575277
00:00:00.575277 [/Devices/vga/0/LUN#0/] (level 4)
00:00:00.575278 Driver <string> = "MainDisplay" (cb=12)
00:00:00.575278
00:00:00.575279 [/Devices/vga/0/LUN#0/Config/] (level 5)
00:00:00.575279 Object <integer> = 0x0000000001f0c620 (32 556 576)
00:00:00.575280
00:00:00.575280 [/Devices/vga/0/LUN#999/] (level 4)
00:00:00.575281 Driver <string> = "MainStatus" (cb=11)
00:00:00.575281
00:00:00.575281 [/Devices/vga/0/LUN#999/Config/] (level 5)
00:00:00.575282 First <integer> = 0x0000000000000000 (0)
00:00:00.575282 Last <integer> = 0x0000000000000000 (0)
00:00:00.575283 papLeds <integer> = 0x0000000001f07890 (32 536 720)
00:00:00.575283
00:00:00.575284 [/Devices/virtio-net/] (level 2)
00:00:00.575284
00:00:00.575284 [/EM/] (level 1)
00:00:00.575285 TripleFaultReset <integer> = 0x0000000000000000 (0)
00:00:00.575285
00:00:00.575285 [/GIM/] (level 1)
00:00:00.575286 Provider <string> = "KVM" (cb=4)
00:00:00.575286
00:00:00.575286 [/HM/] (level 1)
00:00:00.575287 64bitEnabled <integer> = 0x0000000000000000 (0)
00:00:00.575288 EnableLargePages <integer> = 0x0000000000000001 (1)
00:00:00.575288 EnableNestedPaging <integer> = 0x0000000000000001 (1)
00:00:00.575288 EnableUX <integer> = 0x0000000000000001 (1)
00:00:00.575289 EnableVPID <integer> = 0x0000000000000001 (1)
00:00:00.575290 Exclusive <integer> = 0x0000000000000000 (0)
00:00:00.575290 HMForced <integer> = 0x0000000000000000 (0)
00:00:00.575290 IBPBOnVMEntry <integer> = 0x0000000000000000 (0)
00:00:00.575291 IBPBOnVMExit <integer> = 0x0000000000000000 (0)
00:00:00.575291 L1DFlushOnSched <integer> = 0x0000000000000001 (1)
00:00:00.575292 L1DFlushOnVMEntry <integer> = 0x0000000000000000 (0)
00:00:00.575292 MDSClearOnSched <integer> = 0x0000000000000001 (1)
00:00:00.575293 MDSClearOnVMEntry <integer> = 0x0000000000000000 (0)
00:00:00.575293 SpecCtrlByHost <integer> = 0x0000000000000000 (0)
00:00:00.575294 UseNEMInstead <integer> = 0x0000000000000000 (0)
00:00:00.575294
00:00:00.575294 [/MM/] (level 1)
00:00:00.575295 CanUseLargerHeap <integer> = 0x0000000000000000 (0)
00:00:00.575295
00:00:00.575295 [/NEM/] (level 1)
00:00:00.575296 Allow64BitGuests <integer> = 0x0000000000000000 (0)
00:00:00.575296
00:00:00.575296 [/PDM/] (level 1)
00:00:00.575297
00:00:00.575297 [/PDM/AsyncCompletion/] (level 2)
00:00:00.575297
00:00:00.575298 [/PDM/AsyncCompletion/File/] (level 3)
00:00:00.575298
00:00:00.575298 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
00:00:00.575299
00:00:00.575299 [/PDM/BlkCache/] (level 2)
00:00:00.575300 CacheSize <integer> = 0x0000000000500000 (5 242 880, 5 MB)
00:00:00.575301
00:00:00.575301 [/PDM/Devices/] (level 2)
00:00:00.575301
00:00:00.575302 [/PDM/Drivers/] (level 2)
00:00:00.575302
00:00:00.575302 [/PDM/Drivers/VBoxC/] (level 3)
00:00:00.575303 Path <string> = "VBoxC" (cb=6)
00:00:00.575303
00:00:00.575303 [/PDM/NetworkShaper/] (level 2)
00:00:00.575304
00:00:00.575304 [/PDM/NetworkShaper/BwGroups/] (level 3)
00:00:00.575305
00:00:00.575305 [/TM/] (level 1)
00:00:00.575305 UTCOffset <integer> = 0x0000000000000000 (0)
00:00:00.575306
00:00:00.575306 ********************* End of CFGM dump **********************
00:00:00.575312 VM: fHMEnabled=true (configured) fRecompileUser=false fRecompileSupervisor=false
00:00:00.575313 VM: fRawRing1Enabled=false CSAM=true PATM=true
00:00:00.575434 HM: HMR3Init: VT-x w/ nested paging and unrestricted guest execution hw support
00:00:00.575499 MM: cbHyperHeap=0x100000 (1048576)
00:00:00.577009 CPUM: fXStateHostMask=0x7; initial: 0x7; host XCR0=0x1f
00:00:00.577733 CPUM: Matched host CPU INTEL 0x6/0x9e/0xa Intel_Core7_CoffeeLake with CPU DB entry 'Intel Core i7-6700K' (INTEL 0x6/0x5e/0x3 Intel_Core7_Skylake)
00:00:00.577776 CPUM: MXCSR_MASK=0xffff (host: 0xffff)
00:00:00.577786 CPUM: Microcode revision 0x000000CA
00:00:00.577793 CPUM: Changing leaf 13[0]: EBX=0x440 -> 0x340, ECX=0x440 -> 0x340
00:00:00.577800 CPUM: MSR/CPUID reconciliation insert: 0x0000010b IA32_FLUSH_CMD
00:00:00.577812 CPUM: SetGuestCpuIdFeature: Enabled PAE
00:00:00.579475 PGM: HCPhysInterPD=000000007637a000 HCPhysInterPaePDPT=000000007635f000 HCPhysInterPaePML4=0000000076372000
00:00:00.579483 PGM: apInterPTs={000000007637d000,000000007637e000} apInterPaePTs={000000013d228000,000000013d029000} apInterPaePDs={000000014dc2a000,000000013512b000,000000013432c000,000000013ba2d000} pInterPaePDPT64=0000000076371000
00:00:00.579488 PGM: Host paging mode: AMD64+NX
00:00:00.579495 PGM: PGMPool: cMaxPages=224 (u64MaxPages=224)
00:00:00.579498 PGM: pgmR3PoolInit: cMaxPages=0xe0 cMaxUsers=0x1c0 cMaxPhysExts=0x1c0 fCacheEnable=true
00:00:00.584237 TM: GIP - u32Mode=3 (Invariant) u32UpdateHz=93 u32UpdateIntervalNS=10736000 enmUseTscDelta=2 (Practically Zero) fGetGipCpu=0xb cCpus=8
00:00:00.584245 TM: GIP - u64CpuHz=2 304 000 125 (0x8954407d) SUPGetCpuHzFromGip => 2 304 000 125
00:00:00.584249 TM: GIP - CPU: iCpuSet=0x0 idCpu=0x0 idApic=0x0 iGipCpu=0x5 i64TSCDelta=0 enmState=3 u64CpuHz=2304000026(*) cErrors=0
00:00:00.584253 TM: GIP - CPU: iCpuSet=0x1 idCpu=0x1 idApic=0x1 iGipCpu=0x1 i64TSCDelta=-2 enmState=3 u64CpuHz=2303989892(*) cErrors=0
00:00:00.584256 TM: GIP - CPU: iCpuSet=0x2 idCpu=0x2 idApic=0x2 iGipCpu=0x4 i64TSCDelta=0 enmState=3 u64CpuHz=2303999993(*) cErrors=0
00:00:00.584259 TM: GIP - CPU: iCpuSet=0x3 idCpu=0x3 idApic=0x3 iGipCpu=0x3 i64TSCDelta=0 enmState=3 u64CpuHz=2303999915(*) cErrors=0
00:00:00.584261 TM: GIP - CPU: iCpuSet=0x4 idCpu=0x4 idApic=0x4 iGipCpu=0x7 i64TSCDelta=0 enmState=3 u64CpuHz=2303999867(*) cErrors=0
00:00:00.584264 TM: GIP - CPU: iCpuSet=0x5 idCpu=0x5 idApic=0x5 iGipCpu=0x2 i64TSCDelta=0 enmState=3 u64CpuHz=2303998604(*) cErrors=0
00:00:00.584266 TM: GIP - CPU: iCpuSet=0x6 idCpu=0x6 idApic=0x6 iGipCpu=0x6 i64TSCDelta=0 enmState=3 u64CpuHz=2304000043(*) cErrors=0
00:00:00.584269 TM: GIP - CPU: iCpuSet=0x7 idCpu=0x7 idApic=0x7 iGipCpu=0x0 i64TSCDelta=0 enmState=3 u64CpuHz=2304000125(*) cErrors=0
00:00:00.584293 TM: cTSCTicksPerSecOnd=2 304 000 125 (0x8954407d) enmTSCMode=3 (Dynamic)
00:00:00.584294 TM: TSCTiedToExecution=false TSCNotTiedToHalt=false
00:00:00.585241 VMM: CoreCode: R3=00000000047e0000 R0=XXXXXXXXXXXXXXXX RC=a02d9000 Phys=000000007633c000 cb=0x1000
00:00:00.585461 EMR3Init: fRecompileUser=false fRecompileSupervisor=false fRawRing1Enabled=false fIemExecutesAll=false fGuruOnTripleFault=true
00:00:00.585572 IEM: TargetCpu=CURRENT, Microarch=Intel_Core7_CoffeeLake
00:00:00.585644 GIM: Using provider 'KVM' (Implementation version: 0)
00:00:00.585649 CPUM: SetGuestCpuIdFeature: Enabled Hypervisor Present bit
00:00:00.585700 AIOMgr: Default manager type is 'Async'
00:00:00.585703 AIOMgr: Default file backend is 'NonBuffered'
00:00:00.585957 BlkCache: Cache successfully initialized. Cache size is 5242880 bytes
00:00:00.585965 BlkCache: Cache commit interval is 10000 ms
00:00:00.585967 BlkCache: Cache commit threshold is 2621440 bytes
00:00:00.817089 PcBios: [SMP] BIOS with 1 CPUs
00:00:00.817108 PcBios: Using the 386+ BIOS image.
00:00:00.819393 PcBios: MPS table at 000e1300
00:00:00.819483 PcBios: fCheckShutdownStatusForSoftReset=true fClearShutdownStatusOnHardReset=true
00:00:00.827730 SUP: Loaded VBoxDDR0.r0 (C:\Program Files\Oracle\VirtualBox\VBoxDDR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:00.827738 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox\VBoxDDR0.r0=0xXXXXXXXXXXXXXXXX
00:00:00.827928 CPUM: SetGuestCpuIdFeature: Enabled xAPIC
00:00:00.827932 CPUM: SetGuestCpuIdFeature: Enabled x2APIC
00:00:00.828230 IOAPIC: Using implementation 2.0! Chipset type ICH9
00:00:00.828267 PIT: mode=3 count=0x10000 (65536) - 18.20 Hz (ch=0)
00:00:00.838404 Shared Folders service loaded
00:00:00.843495 Guest Control service loaded
00:00:00.857930 VGA: Using the 386+ BIOS image.
00:00:00.858702 DrvVD: Flushes will be ignored
00:00:00.858708 DrvVD: Async flushes will be passed to the disk
00:00:00.858877 VD: VDInit finished with VINF_SUCCESS
00:00:00.859015 VD: Opening the disk took 299272 ns
00:00:00.859177 PIIX3 ATA: LUN#0: disk, PCHS=2080/16/63, total number of sectors 2097152
00:00:00.859214 DrvVD: Flushes will be ignored
00:00:00.859217 DrvVD: Async flushes will be passed to the disk
00:00:00.865429 VD: Opening the disk took 6203724 ns
00:00:00.865585 PIIX3 ATA: LUN#1: disk, PCHS=2080/16/63, total number of sectors 2097152
00:00:00.865630 DrvVD: Flushes will be ignored
00:00:00.865634 DrvVD: Async flushes will be passed to the disk
00:00:00.865695 VD: Opening the disk took 56637 ns
00:00:00.865843 PIIX3 ATA: LUN#2: disk, PCHS=2496/16/63, total number of sectors 2516582
00:00:00.865855 DrvVD: Flushes will be ignored
00:00:00.865857 DrvVD: Async flushes will be passed to the disk
00:00:00.865912 VD: Opening the disk took 50488 ns
00:00:00.866069 PIIX3 ATA: LUN#3: disk, PCHS=2496/16/63, total number of sectors 2516582
00:00:00.866116 PIIX3 ATA: Ctl#0: finished processing RESET
00:00:00.866135 PIIX3 ATA: Ctl#1: finished processing RESET
00:00:00.866193 E1000#1: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866309 E1000#2: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866399 E1000#3: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866488 E1000#4: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866565 E1000#5: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866652 E1000#6: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866733 E1000#7: Chip=82540EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:00.866855 UDPTunnel#0: sport=16001;dest=127.0.0.1;dport=16000
00:00:00.868012 supR3HardenedErrorV: supR3HardenedScreenImage/LdrLoadDll: rc=VERR_SUP_VP_NOT_OWNED_BY_TRUSTED_INSTALLER fImage=1 fProtect=0x0 fAccess=0x0 \Device\HarddiskVolume6\Windows\SysWOW64\ierd_tgp_lsp64.dll: supHardenedWinVerifyImageByHandle: TrustedInstaller is not the owner of '\Device\HarddiskVolume6\Windows\SysWOW64\ierd_tgp_lsp64.dll'.
00:00:00.868373 supR3HardenedErrorV: supR3HardenedMonitor_LdrLoadDll: rejecting 'C:\WINDOWS\SysWOW64\ierd_tgp_lsp64.dll' (C:\WINDOWS\SysWOW64\ierd_tgp_lsp64.dll): rcNt=0xc0000190
00:00:00.868652 VMSetError: F:\tinderbox\win-6.0\src\VBox\Devices\Network\DrvUDPTunnel.cpp(563) int __cdecl drvUDPTunnelConstruct(struct PDMDRVINS *,struct CFGMNODE *,unsigned int); rc=VERR_PDM_HIF_OPEN_FAILED
00:00:00.868658 VMSetError: UDPTunnel: Failed to start the UDP tunnel server
00:00:00.868679 PDM: Failed to construct 'pcnet'/0! VERR_PDM_HIF_OPEN_FAILED (-2852) - Unable to open the host interface.
00:00:00.885379 E1000#1: Interrupt attempts: 0
00:00:00.885388 E1000#1: Interrupts raised : 0
00:00:00.885391 E1000#1: Interrupts lowered: 0
00:00:00.885393 E1000#1: ICR outside ISR : 0
00:00:00.885395 E1000#1: IMS raised ints : 0
00:00:00.885397 E1000#1: Interrupts skipped: 0
00:00:00.885399 E1000#1: Masked interrupts : 0
00:00:00.885401 E1000#1: Early interrupts : 0
00:00:00.885403 E1000#1: Late interrupts : 0
00:00:00.885405 E1000#1: Lost interrupts : 0
00:00:00.885407 E1000#1: Interrupts by RX : 0
00:00:00.885409 E1000#1: Interrupts by TX : 0
00:00:00.885411 E1000#1: Interrupts by ICS : 0
00:00:00.885413 E1000#1: Interrupts by RDTR: 0
00:00:00.885415 E1000#1: Interrupts by RDMT: 0
00:00:00.885417 E1000#1: Interrupts by TXQE: 0
00:00:00.885419 E1000#1: TX int delay asked: 0
00:00:00.885421 E1000#1: TX delayed: 0
00:00:00.885423 E1000#1: TX delay expired: 0
00:00:00.885425 E1000#1: TX no report asked: 0
00:00:00.885427 E1000#1: TX abs timer expd : 0
00:00:00.885429 E1000#1: TX int timer expd : 0
00:00:00.885431 E1000#1: RX abs timer expd : 0
00:00:00.885433 E1000#1: RX int timer expd : 0
00:00:00.885435 E1000#1: TX CTX descriptors: 0
00:00:00.885436 E1000#1: TX DAT descriptors: 0
00:00:00.885438 E1000#1: TX LEG descriptors: 0
00:00:00.885440 E1000#1: Received frames : 0
00:00:00.885442 E1000#1: Transmitted frames: 0
00:00:00.885444 E1000#1: TX frames up to 1514: 0
00:00:00.885446 E1000#1: TX frames up to 2962: 0
00:00:00.885448 E1000#1: TX frames up to 4410: 0
00:00:00.885450 E1000#1: TX frames up to 5858: 0
00:00:00.885452 E1000#1: TX frames up to 7306: 0
00:00:00.885454 E1000#1: TX frames up to 8754: 0
00:00:00.885456 E1000#1: TX frames up to 16384: 0
00:00:00.885458 E1000#1: TX frames up to 32768: 0
00:00:00.885460 E1000#1: Larger TX frames : 0
00:00:00.885462 E1000#1: Max TX Delay : 0
00:00:00.885480 E1000#2: Interrupt attempts: 0
00:00:00.885482 E1000#2: Interrupts raised : 0
00:00:00.885484 E1000#2: Interrupts lowered: 0
00:00:00.885486 E1000#2: ICR outside ISR : 0
00:00:00.885488 E1000#2: IMS raised ints : 0
00:00:00.885490 E1000#2: Interrupts skipped: 0
00:00:00.885492 E1000#2: Masked interrupts : 0
00:00:00.885494 E1000#2: Early interrupts : 0
00:00:00.885496 E1000#2: Late interrupts : 0
00:00:00.885498 E1000#2: Lost interrupts : 0
00:00:00.885500 E1000#2: Interrupts by RX : 0
00:00:00.885502 E1000#2: Interrupts by TX : 0
00:00:00.885504 E1000#2: Interrupts by ICS : 0
00:00:00.885506 E1000#2: Interrupts by RDTR: 0
00:00:00.885508 E1000#2: Interrupts by RDMT: 0
00:00:00.885510 E1000#2: Interrupts by TXQE: 0
00:00:00.885512 E1000#2: TX int delay asked: 0
00:00:00.885513 E1000#2: TX delayed: 0
00:00:00.885515 E1000#2: TX delay expired: 0
00:00:00.885517 E1000#2: TX no report asked: 0
00:00:00.885519 E1000#2: TX abs timer expd : 0
00:00:00.885521 E1000#2: TX int timer expd : 0
00:00:00.885523 E1000#2: RX abs timer expd : 0
00:00:00.885525 E1000#2: RX int timer expd : 0
00:00:00.885527 E1000#2: TX CTX descriptors: 0
00:00:00.885529 E1000#2: TX DAT descriptors: 0
00:00:00.885531 E1000#2: TX LEG descriptors: 0
00:00:00.885533 E1000#2: Received frames : 0
00:00:00.885535 E1000#2: Transmitted frames: 0
00:00:00.885537 E1000#2: TX frames up to 1514: 0
00:00:00.885539 E1000#2: TX frames up to 2962: 0
00:00:00.885541 E1000#2: TX frames up to 4410: 0
00:00:00.885543 E1000#2: TX frames up to 5858: 0
00:00:00.885544 E1000#2: TX frames up to 7306: 0
00:00:00.885546 E1000#2: TX frames up to 8754: 0
00:00:00.885548 E1000#2: TX frames up to 16384: 0
00:00:00.885550 E1000#2: TX frames up to 32768: 0
00:00:00.885552 E1000#2: Larger TX frames : 0
00:00:00.885554 E1000#2: Max TX Delay : 0
00:00:00.885571 E1000#3: Interrupt attempts: 0
00:00:00.885575 E1000#3: Interrupts raised : 0
00:00:00.885577 E1000#3: Interrupts lowered: 0
00:00:00.885579 E1000#3: ICR outside ISR : 0
00:00:00.885581 E1000#3: IMS raised ints : 0
00:00:00.885583 E1000#3: Interrupts skipped: 0
00:00:00.885585 E1000#3: Masked interrupts : 0
00:00:00.885587 E1000#3: Early interrupts : 0
00:00:00.885589 E1000#3: Late interrupts : 0
00:00:00.885590 E1000#3: Lost interrupts : 0
00:00:00.885592 E1000#3: Interrupts by RX : 0
00:00:00.885594 E1000#3: Interrupts by TX : 0
00:00:00.885596 E1000#3: Interrupts by ICS : 0
00:00:00.885598 E1000#3: Interrupts by RDTR: 0
00:00:00.885600 E1000#3: Interrupts by RDMT: 0
00:00:00.885602 E1000#3: Interrupts by TXQE: 0
00:00:00.885604 E1000#3: TX int delay asked: 0
00:00:00.885606 E1000#3: TX delayed: 0
00:00:00.885608 E1000#3: TX delay expired: 0
00:00:00.885610 E1000#3: TX no report asked: 0
00:00:00.885612 E1000#3: TX abs timer expd : 0
00:00:00.885614 E1000#3: TX int timer expd : 0
00:00:00.885616 E1000#3: RX abs timer expd : 0
00:00:00.885618 E1000#3: RX int timer expd : 0
00:00:00.885620 E1000#3: TX CTX descriptors: 0
00:00:00.885621 E1000#3: TX DAT descriptors: 0
00:00:00.885623 E1000#3: TX LEG descriptors: 0
00:00:00.885625 E1000#3: Received frames : 0
00:00:00.885627 E1000#3: Transmitted frames: 0
00:00:00.885629 E1000#3: TX frames up to 1514: 0
00:00:00.885631 E1000#3: TX frames up to 2962: 0
00:00:00.885633 E1000#3: TX frames up to 4410: 0
00:00:00.885635 E1000#3: TX frames up to 5858: 0
00:00:00.885637 E1000#3: TX frames up to 7306: 0
00:00:00.885639 E1000#3: TX frames up to 8754: 0
00:00:00.885641 E1000#3: TX frames up to 16384: 0
00:00:00.885643 E1000#3: TX frames up to 32768: 0
00:00:00.885645 E1000#3: Larger TX frames : 0
00:00:00.885647 E1000#3: Max TX Delay : 0
00:00:00.885665 E1000#4: Interrupt attempts: 0
00:00:00.885668 E1000#4: Interrupts raised : 0
00:00:00.885670 E1000#4: Interrupts lowered: 0
00:00:00.885672 E1000#4: ICR outside ISR : 0
00:00:00.885673 E1000#4: IMS raised ints : 0
00:00:00.885675 E1000#4: Interrupts skipped: 0
00:00:00.885677 E1000#4: Masked interrupts : 0
00:00:00.885679 E1000#4: Early interrupts : 0
00:00:00.885681 E1000#4: Late interrupts : 0
00:00:00.885683 E1000#4: Lost interrupts : 0
00:00:00.885685 E1000#4: Interrupts by RX : 0
00:00:00.885687 E1000#4: Interrupts by TX : 0
00:00:00.885689 E1000#4: Interrupts by ICS : 0
00:00:00.885691 E1000#4: Interrupts by RDTR: 0
00:00:00.885693 E1000#4: Interrupts by RDMT: 0
00:00:00.885695 E1000#4: Interrupts by TXQE: 0
00:00:00.885697 E1000#4: TX int delay asked: 0
00:00:00.885699 E1000#4: TX delayed: 0
00:00:00.885701 E1000#4: TX delay expired: 0
00:00:00.885703 E1000#4: TX no report asked: 0
00:00:00.885705 E1000#4: TX abs timer expd : 0
00:00:00.885707 E1000#4: TX int timer expd : 0
00:00:00.885709 E1000#4: RX abs timer expd : 0
00:00:00.885711 E1000#4: RX int timer expd : 0
00:00:00.885713 E1000#4: TX CTX descriptors: 0
00:00:00.885714 E1000#4: TX DAT descriptors: 0
00:00:00.885716 E1000#4: TX LEG descriptors: 0
00:00:00.885718 E1000#4: Received frames : 0
00:00:00.885720 E1000#4: Transmitted frames: 0
00:00:00.885722 E1000#4: TX frames up to 1514: 0
00:00:00.885724 E1000#4: TX frames up to 2962: 0
00:00:00.885726 E1000#4: TX frames up to 4410: 0
00:00:00.885728 E1000#4: TX frames up to 5858: 0
00:00:00.885730 E1000#4: TX frames up to 7306: 0
00:00:00.885732 E1000#4: TX frames up to 8754: 0
00:00:00.885734 E1000#4: TX frames up to 16384: 0
00:00:00.885736 E1000#4: TX frames up to 32768: 0
00:00:00.885738 E1000#4: Larger TX frames : 0
00:00:00.885740 E1000#4: Max TX Delay : 0
00:00:00.885753 E1000#5: Interrupt attempts: 0
00:00:00.885756 E1000#5: Interrupts raised : 0
00:00:00.885758 E1000#5: Interrupts lowered: 0
00:00:00.885759 E1000#5: ICR outside ISR : 0
00:00:00.885761 E1000#5: IMS raised ints : 0
00:00:00.885763 E1000#5: Interrupts skipped: 0
00:00:00.885794 E1000#5: Masked interrupts : 0
00:00:00.885797 E1000#5: Early interrupts : 0
00:00:00.885799 E1000#5: Late interrupts : 0
00:00:00.885801 E1000#5: Lost interrupts : 0
00:00:00.885803 E1000#5: Interrupts by RX : 0
00:00:00.885805 E1000#5: Interrupts by TX : 0
00:00:00.885807 E1000#5: Interrupts by ICS : 0
00:00:00.885809 E1000#5: Interrupts by RDTR: 0
00:00:00.885811 E1000#5: Interrupts by RDMT: 0
00:00:00.885813 E1000#5: Interrupts by TXQE: 0
00:00:00.885815 E1000#5: TX int delay asked: 0
00:00:00.885817 E1000#5: TX delayed: 0
00:00:00.885819 E1000#5: TX delay expired: 0
00:00:00.885821 E1000#5: TX no report asked: 0
00:00:00.885823 E1000#5: TX abs timer expd : 0
00:00:00.885825 E1000#5: TX int timer expd : 0
00:00:00.885827 E1000#5: RX abs timer expd : 0
00:00:00.885829 E1000#5: RX int timer expd : 0
00:00:00.885831 E1000#5: TX CTX descriptors: 0
00:00:00.885833 E1000#5: TX DAT descriptors: 0
00:00:00.885835 E1000#5: TX LEG descriptors: 0
00:00:00.885837 E1000#5: Received frames : 0
00:00:00.885839 E1000#5: Transmitted frames: 0
00:00:00.885840 E1000#5: TX frames up to 1514: 0
00:00:00.885842 E1000#5: TX frames up to 2962: 0
00:00:00.885844 E1000#5: TX frames up to 4410: 0
00:00:00.885846 E1000#5: TX frames up to 5858: 0
00:00:00.885848 E1000#5: TX frames up to 7306: 0
00:00:00.885850 E1000#5: TX frames up to 8754: 0
00:00:00.885852 E1000#5: TX frames up to 16384: 0
00:00:00.885854 E1000#5: TX frames up to 32768: 0
00:00:00.885856 E1000#5: Larger TX frames : 0
00:00:00.885858 E1000#5: Max TX Delay : 0
00:00:00.885873 E1000#6: Interrupt attempts: 0
00:00:00.885876 E1000#6: Interrupts raised : 0
00:00:00.885878 E1000#6: Interrupts lowered: 0
00:00:00.885880 E1000#6: ICR outside ISR : 0
00:00:00.885882 E1000#6: IMS raised ints : 0
00:00:00.885884 E1000#6: Interrupts skipped: 0
00:00:00.885886 E1000#6: Masked interrupts : 0
00:00:00.885888 E1000#6: Early interrupts : 0
00:00:00.885889 E1000#6: Late interrupts : 0
00:00:00.885891 E1000#6: Lost interrupts : 0
00:00:00.885893 E1000#6: Interrupts by RX : 0
00:00:00.885895 E1000#6: Interrupts by TX : 0
00:00:00.885897 E1000#6: Interrupts by ICS : 0
00:00:00.885899 E1000#6: Interrupts by RDTR: 0
00:00:00.885901 E1000#6: Interrupts by RDMT: 0
00:00:00.885903 E1000#6: Interrupts by TXQE: 0
00:00:00.885905 E1000#6: TX int delay asked: 0
00:00:00.885907 E1000#6: TX delayed: 0
00:00:00.885909 E1000#6: TX delay expired: 0
00:00:00.885911 E1000#6: TX no report asked: 0
00:00:00.885913 E1000#6: TX abs timer expd : 0
00:00:00.885915 E1000#6: TX int timer expd : 0
00:00:00.885917 E1000#6: RX abs timer expd : 0
00:00:00.885919 E1000#6: RX int timer expd : 0
00:00:00.885921 E1000#6: TX CTX descriptors: 0
00:00:00.885923 E1000#6: TX DAT descriptors: 0
00:00:00.885925 E1000#6: TX LEG descriptors: 0
00:00:00.885927 E1000#6: Received frames : 0
00:00:00.885928 E1000#6: Transmitted frames: 0
00:00:00.885930 E1000#6: TX frames up to 1514: 0
00:00:00.885932 E1000#6: TX frames up to 2962: 0
00:00:00.885934 E1000#6: TX frames up to 4410: 0
00:00:00.885936 E1000#6: TX frames up to 5858: 0
00:00:00.885938 E1000#6: TX frames up to 7306: 0
00:00:00.885940 E1000#6: TX frames up to 8754: 0
00:00:00.885942 E1000#6: TX frames up to 16384: 0
00:00:00.885944 E1000#6: TX frames up to 32768: 0
00:00:00.885946 E1000#6: Larger TX frames : 0
00:00:00.885948 E1000#6: Max TX Delay : 0
00:00:00.885961 E1000#7: Interrupt attempts: 0
00:00:00.885964 E1000#7: Interrupts raised : 0
00:00:00.885966 E1000#7: Interrupts lowered: 0
00:00:00.885968 E1000#7: ICR outside ISR : 0
00:00:00.885970 E1000#7: IMS raised ints : 0
00:00:00.885971 E1000#7: Interrupts skipped: 0
00:00:00.885973 E1000#7: Masked interrupts : 0
00:00:00.885975 E1000#7: Early interrupts : 0
00:00:00.885977 E1000#7: Late interrupts : 0
00:00:00.885979 E1000#7: Lost interrupts : 0
00:00:00.885981 E1000#7: Interrupts by RX : 0
00:00:00.885983 E1000#7: Interrupts by TX : 0
00:00:00.885985 E1000#7: Interrupts by ICS : 0
00:00:00.886008 E1000#7: Interrupts by RDTR: 0
00:00:00.886011 E1000#7: Interrupts by RDMT: 0
00:00:00.886013 E1000#7: Interrupts by TXQE: 0
00:00:00.886015 E1000#7: TX int delay asked: 0
00:00:00.886017 E1000#7: TX delayed: 0
00:00:00.886019 E1000#7: TX delay expired: 0
00:00:00.886021 E1000#7: TX no report asked: 0
00:00:00.886023 E1000#7: TX abs timer expd : 0
00:00:00.886025 E1000#7: TX int timer expd : 0
00:00:00.886027 E1000#7: RX abs timer expd : 0
00:00:00.886028 E1000#7: RX int timer expd : 0
00:00:00.886030 E1000#7: TX CTX descriptors: 0
00:00:00.886032 E1000#7: TX DAT descriptors: 0
00:00:00.886034 E1000#7: TX LEG descriptors: 0
00:00:00.886036 E1000#7: Received frames : 0
00:00:00.886038 E1000#7: Transmitted frames: 0
00:00:00.886040 E1000#7: TX frames up to 1514: 0
00:00:00.886042 E1000#7: TX frames up to 2962: 0
00:00:00.886044 E1000#7: TX frames up to 4410: 0
00:00:00.886046 E1000#7: TX frames up to 5858: 0
00:00:00.886048 E1000#7: TX frames up to 7306: 0
00:00:00.886050 E1000#7: TX frames up to 8754: 0
00:00:00.886052 E1000#7: TX frames up to 16384: 0
00:00:00.886054 E1000#7: TX frames up to 32768: 0
00:00:00.886056 E1000#7: Larger TX frames : 0
00:00:00.886058 E1000#7: Max TX Delay : 0
00:00:00.886534 GIM: KVM: Resetting MSRs
00:00:00.887317 ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={872da645-4a9b-1727-bee2-5585105b9eed} aCompOnent={ConsoleWrap} aText={UDPTunnel: Failed to start the UDP tunnel server (VERR_PDM_HIF_OPEN_FAILED)}, preserve=false aResultDetail=-2852
00:00:00.887512 Console: Machine state changed to 'PoweredOff'
00:00:00.895327 Power up failed (vrc=VERR_PDM_HIF_OPEN_FAILED, rc=E_FAIL (0X80004005))
粉丝:5人 关注:1人
虚拟盒子有问题,重装一下官网最新的hcl
qujl 三段
请问该问题已经解决了吗,我也有相似的问题
用的是官网最新的HCL
