f100-c-g3 v7 sslvpn通过inode访问不了资源
2021-11-10提问
  • 1收藏,702浏览
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
v7 sslvpn,inode 连接成功并获得虚拟IP地址(10.5.2.2),但ping不通内网资源10.200.49.193,在v7上用ping -a 10.5.2.1   10.200.49.193  ,是可以ping通的.
 version 7.1.064, Release 9524P33
 sysname H3C
 clock timezone Beijing add 08:00:00
 clock protocol none
context Admin id 1
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 password-recovery enable
vlan 1
vlan 43
vlan 230
controller Cellular1/0/0
interface NULL0
interface Vlan-interface43
 ip address 10.200.43.251 255.255.255.0
interface Vlan-interface230
 ip address 10.200.230.251 255.255.255.0
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip address 192.168.0.1 255.255.255.0
 combo enable fiber
 ip address 10.200.47.251 255.255.255.0
 gateway 10.200.47.253
 ip address 10.200.210.101 255.255.255.0
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 43
interface GigabitEthernet1/0/5
 port access vlan 43
interface GigabitEthernet1/0/6
 port access vlan 230
interface GigabitEthernet1/0/7
interface SSLVPN-AC1
 ip address 10.5.2.1 255.255.255.0
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/1
 import interface GigabitEthernet1/0/3
 import interface GigabitEthernet1/0/8
 import interface GigabitEthernet1/0/9
 import interface GigabitEthernet1/0/10
 import interface GigabitEthernet1/0/11
 import interface NULL0
 import interface Vlan-interface43
 import interface Vlan-interface230
security-zone name DMZ
security-zone name Untrust
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/2
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 authentication-mode scheme
 user-role network-admin
line class usb
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 Vlan-interface43 10.200.43.253
 ip route-static 10.200.43.0 24 Vlan-interface43 10.200.43.253
 info-center source FILTER logfile deny
 ssh server enable
acl advanced 3000
 rule 0 permit ip
radius scheme radius
 primary authentication 10.200.49.190 key cipher $c$3$P9G92KU3YfJcVuTyOCP0K7QUpn2O4FKqUA==
 key authentication cipher $c$3$bSEeT5XcFSoPYh/2ity+Tnj8v0sTaAIO8w==
 user-name-format without-domain
 nas-ip 10.200.43.251
domain sslisp
 authorization-attribute user-group segroup
 authentication sslvpn radius-scheme radius
 authorization sslvpn radius-scheme radius
 accounting sslvpn none
domain system
 domain default enable sslisp
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group segroup
 authorization-attribute sslvpn-policy-group segp
user-group system
local-user admin class manage
 password hash $h$6$TAc2YqE44dNheERZ$TmnSmRaB22tBhMbnRNWlvvkPpliFj14PkQhi37kFAWfi8ghjxrsZjSKMKyRNAsNiDx4tEBJmDPsZ9RSkAZrbjw==
 authorization-attribute user-role level-3
local-user yetech class manage
 password hash $h$6$cuyH1+Pvj2qrtYKZ$aMv8MmKP4qw9Ac3izxitlYKZxf6jRdGce4TC6EDBW0Srx/xGv1B6grGbz3rlhXhocs9UAny50jXfGT99Mwa9pw==
 service-type ssh terminal https
 authorization-attribute work-directory slot1#flash:
local-user hawk2 class network
 password cipher $c$3$9Ygy+CBuClaktigSQRzqn4C5aratU3cKiyQ=
 service-type sslvpn
 group segroup
pki domain yetsslvpn
 undo crl check enable
 ssl version ssl3.0 disable
ssl server-policy ssl
 pki-domain yetsslvpn
ssl client-policy sslclient
 prefer-cipher dhe_rsa_aes_256_cbc_sha rsa_aes_256_cbc_sha dhe_rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha rsa_3des_ede_cbc_sha exp_rsa_des_cbc_sha rsa_des_cbc_sha rsa_rc4_128_md5 rsa_rc4_128_sha exp_rsa_rc4_md5 exp_rsa_rc2_md5
 prefer-cipher rsa_aes_128_cbc_sha256 rsa_aes_256_cbc_sha256 dhe_rsa_aes_128_cbc_sha256 dhe_rsa_aes_256_cbc_sha256 ecdhe_rsa_aes_128_cbc_sha256 ecdhe_rsa_aes_256_cbc_sha384 ecdhe_rsa_aes_128_gcm_sha256 ecdhe_rsa_aes_256_gcm_sha384 ecdhe_ecdsa_aes_128_cbc_sha256 ecdhe_ecdsa_aes_256_cbc_sha384 ecdhe_ecdsa_aes_128_gcm_sha256
 prefer-cipher ecdhe_ecdsa_aes_256_gcm_sha384
 undo server-verify enable
 session synchronization enable
 session synchronization http
 ipsec logging negotiation enable
 ike logging negotiation enable
 ip https enable
inspect logging parameter-profile url_logging_default_parameter
 loadbalance isp file flash:/lbispinfo_v1.5.tp
sslvpn ip address-pool userpool 10.5.2.2 10.5.2.200
sslvpn gateway sslvpngw
 service enable
sslvpn context ctx1
 gateway sslvpngw
 ip-tunnel interface SSLVPN-AC1
 ip-tunnel address-pool userpool mask 255.255.255.0
 ip-tunnel log connection-close
 ip-route-list 49193
  include 10.200.49.193 255.255.255.255
 policy-group segp
  filter ip-tunnel acl 3000
  filter web-access acl 3000
  filter tcp-access acl 3000
  ip-tunnel access-route force-all
  ip-tunnel access-route ip-route-list 49193
 default-policy-group segp
 aaa domain sslisp
 log user-login enable
 log resource-access enable
 sms-imc address 10.200.49.190 port 8080
 sms-imc enable
 service enable
sslvpn log enable
security-policy ip
 rule 0 name any-any
  action pass
return
粉丝:17人 关注:1人
AC口没加安全域,所以不通。SSLVPN可以理解成如下两个过程。
1.拨号过程,外网到网关接口的过程,策略是外网到本地也就是local就行。
2.访问内网过程,外网流量到本地进行封装,封装是在AC口操作,逻辑上可以认为这个报文是AC口进来,然后访问内网,因此要AC口到内网的策略放通。AC口也需要放入安全域。
就是这个原因,太感谢了!!!
zhiliao_M5sIkc 发表时间:2021-11-11
粉丝:7人 关注:8人
看下终端路由是否下发成功了
路由下发是成功的,10.200.49.193 255.255.255.255 在链路上10.5.2.2
zhiliao_M5sIkc 发表时间:2021-11-10
路由跟踪一下 看看到哪没了
zhiliao_9n4HJp 发表时间:2021-11-10
全是*号,看不到
那就终端带源去ping 看看到哪不通 看看能不能ping通内网资源的网关地址呢
